Question about Fellowes 3011001 Shredder
Paper not shredding
The jaw accepting paper seems to be too sensitive and stops working too often
  • beerboy1943 Feb 09, 2008
    Device will not accept paper. But It will run backwards
  • 57 Answers
Replaced the main board and the eye sensor if possible.
Posted on Feb 24, 2008
Make sure the cutting rollers are oiled frequently.
Posted on Feb 04, 2008
My Black & Decker Shredder #BD-61 all of a sudden does not work. I used it tonight, but the next time I tried it does not work. The lights come on in both positions, but
On some shredders when both the forward and reverse LEDs are on it can indicate either a jam or a full receiver bag/ container (the area that the shredded paper is fed into).
Try the following steps:
  1. ) unplug the power
  2. ) open up the shredder (see 1 on diagram)
  3. ) empty out all the shredded paper (see 2 on diagram)
  4. ) check that the shredding jaws (both the entrance and exit) are clear of any shredded material (see 3 on diagram)
  5. ) put everything back together
  6. ) plug power cord back in
  7. ) force the shredder into reverse (see 4 on diagram)
Hopefully you should hear your shredder motor running. If it is switch it to automatic and try shredding again
Jan 24, 2015 | Shredder Office Equipment & Supplies
Omnitech shredder ot-nxc10pa
You must first unplug it and look inside the shredding blades, especially around the spot usually near the center, where there is a pressure button. When paper hits it, it starts shredding. Chances are some pieces of paper have jammed just over it stopping paper from hitting it and switching it on. I have had to use long tweezers to work the jammed bits out... Once clear it will work again. Also using shredder oil every 50 sheets through will help it cut easier , and jam less frequently. Do not put too many sheets through together in a bunch. No staples...
Aug 23, 2014 | Office Equipment & Supplies
Shredder No Longer Does
Office shredders, even the heavy-duty ones, tend to jam up over time and have to be cleaned up to restore operation. If you have removed all jammed paper bits and still get erratic operation, the shredding process may have bent or broken some internal parts. It is not economically practical to try to repair. Better to buy a replacement.
Dec 27, 2013 | Royal Jaws Shredder
Not shredding properly, perferrating the paper but not actually tearing/shredding it.
A bearing may be worn, or moved out of place allowing the cutting shafts to move apart a little...remove about 5 screws from the bottom and the top will come off and you can see whats going on...if you need parts call Royal at 1-800-524-0799
Sep 17, 2010 | Royal Jaws Shredder
Good morning-my P50CM shredder motor seems to be working fine (same noise as usual) in both forward and reverse, however it wont accept paperfor shredding .I have removed as much cut paper between the...
You shredder needs a new shredding head. I'm sorry to say. You will be better off getting a new shredder. I am a senior level shredder technician in CO. I have seen this problem many times and it is an expensive repair. Hope this helps. If you have further questions please respond.
Aug 25, 2010 | Fellowes P50CM Shredder
My jaws shredder appears to get overheated every now and then and just stops running, is this normal? also, when I shred alot of paper sometime it will gets jammed and I have to go back and forth on the...
Remember this is a "consumer" shredder NOT a commercial shredder..... if you shred for 5 minutes you should give the machine 10 minutes for the motor to "cool-down"...it will not hurt if you also shred some paper with shredder oil poured onto the paper so that the oil lubricates the cutting blades...lastly; if the shredder is rated to a Max. of 10 sheets(as an example.)..you will have fewer problems if you only shred about 70 % of that number. ***Think of your car...it will go 100m.p.h.....but how long will it last if you drive it at its maximum speed all the time.????
Jul 17, 2010 | Royal Jaws Shredder
I have a Royal JS2 shredder not working
I have the same problem with my machine. It started when I turn the switch to the midle before the machine was completely stopped. I took the lid off to have a look the inside. I believe that it is a problem with the elctrical part of the machine and therefore I cannot fix ti by myselve.
Nov 24, 2009 | Kitchen Appliances - Others
Royal 10X confetti shredder
More than likely, there is a lot of paper debris jammed between the cutters and strippers. If you are handy, try the following.
Disconnect the power.
Disassemble the shredder from the lower bin to access the cutting head. Clear the head of all debris with a small screw driver or ice pick. Reassemble and oil the cutters with shredder oil, being careful not to get any oil on the optics. This should solve the sluggish problem. Oil on a regular basis, before every use.
Jan 06, 2009 | Royal 10X Shredder
Fellowes 3011001 Shredder Logo
90 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
