Question about Soltek SL-75FRN2-RL Motherboard
Overclocking ? can you O.C this M.B ???
    Scholar:
  • 119 Answers
Here you are..they say is quite well overclockable
http://www.ocinside.de/go_e.html?http://www.ocinside.de/html/results/mainboard_soltek_sl75frn2rl.html
Posted on Feb 03, 2008
  • 4,889 Answers
Yes you can over clock it up 3200+
Overclocking
There are many issues to consider when overclocking and the first is to be sure that you have extra cooling for your processor. On this motherboard I do not recommend overclocking but since ASUS says that it can be done I will try to give you some places to get information on your A7V880 system. If you do not have your user's manual, you can go to the link below and download one.
http://www.asus.com/Motherboards/AMD_Socket_A/A7V880/#download . Leave the OVER_VOLT1 jumper on the motherboard on the default of pins 1 & 2. Refer then to section 2.4.5 on pages 2-21,22 of the User's Manual for Jumper Free configuration overclocking settings. In BIOS Setup I suggest a CPU Multiple of 10 or less. If you choose to use the AI Overclock Tuner instead, a setting of [Overclock 20%] or less would be best. The VCORE Voltage setting will depend on the specs for the CPU that you are using. If you don't know leave it at Auto. As I said before, overheating of the CPU is a problem in overclocking and you can monitor the temperature via the Hardware Monitor. Refer to section 2.5.6 on page 2-26 of the manual. Modern cpu overclocking normally does not exceed 20% safely unless you are willing to spend a lot of money on liquid cooling and frequent replacement of damaged processors. I would be interested in hearing whether you decide to overclock or continuing with your present settings.
Nov 27, 2011 | ASUS A7V880 Motherboard
I have a intel dg31pr motherboard with e7200 processor.i want to overclock it.plz help me............
Overclocking is something you should only do if you are fairly experienced with computers. Most motherboards that overclock are made for overclocking as are the processors used. Good overclocking requires a balance of increased FSB, multiplier, increased voltage to the ram and sometimes the processor as well, and excellent cooling. It is easy to burn out your system by overclocking. There are many things you should know first. For that reasion alone it is impossible for me to tell you how to overclock it.
But, go to www.extremeoverclocking.com. This is a site made for people who want to overclock. Read and browse through the forums. You will also find some excellent by the numbers guides there. Sigh up and jump in. When you perform your first overclock, come back and tell me. I've been overclocking since 2002.
Sirwriter
Nov 05, 2009 | Intel DG31PR Motherboard
How do I overclock my cpu
Hello
Some CPU's overclock with diffirent methods, so, you do not specify which you are using, so, i googled step by step guide to overclock CPU. I found detailed instructions on how to overclock different systems. Hope this can help you.
Best regards.
Sep 30, 2009 | Dell Computers & Internet
How to overclock 945GCT-M2/1333 motherboard
Try getting an overclockers BIOS. ECS motherboards don't usually offer the best overclocking support.
Sep 30, 2009 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Overclocking
Overclocking is set from the BIOS configuration. Not all BIOS allows overclocking, it may need a BIOS upgrade.
Check the ASUS WEB site for your model motherboard.
Overclocking the CPU (ie running at a higher clock speed) and increasing Frontside bus speed will give better performance BUT there is a downside too, if you overclock too high you could overheat the CPU and it could fail.
Sep 01, 2009 | ASUS P5GC-MX/1333 Motherboard
Overclocking locked on 945gct-m2 mobo
There is no overclocking settings for this motherboard, the CPU speeds and core settings are automatically determined. You may be able to find a modified bios somewhere, but i would strongly suggest this not be done. A bad bios, or bad flash can essentially turn the motherboard into an expensive paperweight.
May 30, 2009 | Intel Computers & Internet
Overclock an Intel E6300 on a GA-8I945GZME-RH motherboard
You need to check your BIOS. If you can overclock you will see a selection for CPU and speed in BIOS. If not there then your motherboard does not allow you to overclock your CPU.
Rate this solution.
Jan 09, 2009 | Intel Core 2 Duo E6300 / 1.86 GHz...
Overclock a black edition 5000 x2
@johnhercus26
pls let me remind you that overclocking voids your pc's warranty.you will need to enhance the cooling solutions for the device you will overclock plus the cooling solutions for the CPU case, every time you overclock, more heat is produced by the device you are overclocking. also you have to make sure you have power headroom..., a higher wattage CPU power supply. plus the risk that you may toast your pc or lessen its usable life. overclocking is for advanced users so pls take extra caution if you will do it.. for guide and instructions pls click here and goodluck! >>> http://www.pcstats.com/articleview.cfm?articleID=1804
Oct 23, 2008 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Overclocking
are you sure that your pc is built for overclocking? dont be risky it might get you trouble on your pc. i suggest that you shouldnt overclocking it and besides your processor is high ed.
CHARCOIS
Aug 24, 2008 | Intel (P42000400256SK478) Pentium 4, 2 GHz...
Overclocking failed
Hi, If you have overclocked: 1. CPU or motherboard not up to it - run at default speed; or 2. Memory - try using other memory; or 3. Video Card - see if you can run the Video card at default speed and not with overclock speed; or 4. You may need to up the CPU B+ a bit. If not overclocked: a. Set BIOS/CMOS to default settings; or b. Disable any overclocking feature (even if not used); or c. Lower you CAS latency. Hope this be of some help/idea. ood luck and kind regards.
Sep 01, 2007 | ASUS P5RD1-VM Motherboard
Soltek SL-75FRN2-RL Motherboard Logo
60 people viewed this question
Top Soltek Computers & Internet Experts
clar4444
Level 1 Expert
Paul Bade
Iqbal Husain
Iqbal Husain
Are you a Soltek Computer and Internet Expert? Answer questions, earn points and help others
