Question about Dishwashers
Diplomat intergrated dishwasher error code FA
Good Day,
I have a diplomat intergrated dishwasher, if I select a programme and clos eth door the cycle startes, I hear the drain pump kick in and I can hear the unit draining, this goed on for about 2 minutes then the unit starts to beep at me, if I open it the start light if flashin, the pre wash light is on and there is the error code FA in the LED dispplay, I do not have any codes in the manual and the internet does not seem to have the manual any where either.... I also have a diplomat intergrated dishwasher, if I select a programme and close the door the cycle startes, I hear the drain pump kick in and I can hear the unit draining, this goed on for about 2 minutes then the unit starts to beep at me, if I open it the start light if flashin, the pre wash light is on and there is the error code FA in the LED dispplay. Please,please,please help:(
  • Anonymous Mar 22, 2014
    Error code f7 with continues to beep and program goes back to rinse
  • 4,889 Answers
FA is a problem with the tubidity sensor. By holding down the power button, it stops, but just repeats everytime you try a new wash cycle. So keep doing it and you can atleast use it. If you want to go one step further and find a permanent solution try feeling around in the sump (where the filter slots in) being careful for any broken glass. Other than that it will probably be a strip-down job to examine the internal hoses and the pump; not a DIY job to be honest.
Posted on Feb 03, 2008
    Genius:
  • 3,422 Answers
The wash cycle finishes too early and
the p / 6 indicator light flashes
(fault code F A appears in the
display)
– the drain hose is kinked
– the drain pump is blocked
* Turn the program selector to the f
*STOP" position (the fault code goes
out).
* Correct the fault.
* Pump away the water and start the
program again (see additional
program "DRAIN" and "Switching
on").
Goodluck,
Please don't forget to rate me as fixya..
Diplomat ADP8342 won't fill with water
Assuming the water tap is open and the water pressure is correct, it is likely the inlet water valve in the dishwasher is faulty. If you hear a click at the time the cycle starts but still there is no water then the inlet valve needs to be replaced. Also check the inlet hose for any kinks or blockage of the filter attached to the tap inlet.
The inlet valve looks like this item
Diplomat ADP8342 Solenoid Valve
Aug 05, 2014 | Dishwashers
Diplomat dishwasher
It is likely the door switch is faulty and not letting the dishwasher start the cycle. Need to have the full model number and make of dishwasher to advise further.
Apr 11, 2014 | Dishwashers
Dishwasher not working but deeping twice
This is just a guess but it sounds like there is a flow meter on the drain hose somewhere that is bad.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Dec 10, 2013 | Dishwashers
My Diplomat dishwasher ADP8352 keeps stopping
Switch off the machine at your plug end and switch ON.
Check incoming water flow. Check and fill rinse-aid liquid in the dispenser. Check dish washer salt dispenser and fill.
These are the only actions an user can try.
May 27, 2010 | Dishwashers
Diplomat dishwasher bleeping showing FA
We have just experienced an FA audible error on our Diplomat ADP 8332 dishwasher...after pulling the dishwasher out and removing the low front panel we found the drip tray full of water. We tipped the dishwasher onto it's front and removed the drip tray and found a float pressure switch...it appears that once the drip tray is full the float switch activates and causes the FA fault (prevents the dishwasher from continuing) drain off your drip tray replace all covers and you should be good to go!!
Sep 16, 2009 | Dishwashers
Diplomat Dishwasher ADP8352 Will not complete wash Cycle
My Diplomat ADP8352 when running a cycle it will run for ages, doesn't seem to get hot. If i switch off the m/c then switch it on again it dumps the water left in the m/c?
any ideas?
Jan 04, 2009 | Hotpoint 18 in. DC28 Slim-Line Built-in...
Diplomat adp 8520 dishwasher no hot water
two things to check
check continuity thru heater
remove outer door panel and check for faults in wiring loom
get back to me is these are both ok
Nov 14, 2008 | Dishwashers
Will not Complete a Wash Cycle
hello.
Please consider examine the control panel and the circuit of the machine maybe some connection setting is lessen.
melnavz
Mar 18, 2008 | Dishwashers
Dishwashers Logo
3,599 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
