2002 Chevrolet Impala Logo
Posted on Jan 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2002 impala - service vehicle soon light appears at random intervals. put a code scanner on the car and no codes returned. opening/closing trunk seems to make message disappear....what is going on?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 05, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1411
Points
Thank you people do not understand that the check engine light and the service light are different
Anonymous
Level 3:
  • Master 2,841 Answers
Anonymous
Master
Level 3:
Answers
2841
Questions
0
Helped
1223362
Points
9607
Service vehicle soon is not the same as Check Engine. This is a reminder to perform some regularly scheduled maintenance based on your mileage. Could just be an oil change. Look in your owner's manual to find out.
2answers
2002 Chevrolet impala 3.8 why would the abs light be on
To find out why you need to have code's checked .
Ive got a 1983 Subaru GL wagon, Automatic trans. non turbo. My problem is that the brake fluid, stop lam, and A.T. Oil temp warning lights on the dash stay on constantly. I noticed that whenand if they...
Yes it may be the wires are shorting or its actually the problem with instrument cluster.
Also get the vehicle scanned for any error codes stored in computer this will confirm whether is short circuit issue or actual problem:------
I suggest you few help links with accurate solutions to refer/go through:----Click the link below:------
Battery and brake Warning lights on Dash
http://alltypesofpartsreplacing.blogspot.com/2012/10/battery-and-brake-warning-lights-on-dash.html
--------------2002 Ford Windstar: Brake Warning Light ON dash? http://schematicsdiagram.blogspot.in/2012/06/2002-ford-windstar-brake-warning-light.html
-------------ABS & Brake warning lights remains steady on dash? http://schematicsdiagram.blogspot.com/2011/12/abs-brake-warning-lights-remains-steady.html
-----------Chevrolet Tahoe Hood open warning on dash and alarm sounds? http://schematicsdiagram.blogspot.com/2011/12/chevrolet-tahoe-hood-open-warning-on.html
-----------2005 Chevy Impala: Service Vehicle Soon Warning Light? http://whoisbyme.blogspot.in/2012/06/2005-chevy-impala-service-vehicle-soon.html -------------- Malfunction Indicator Light ON http://whoisbyme.blogspot.in/2012/06/malfunction-indicator-light-on.html
-----------Car Runs Fine But Check Engine light is ON?
http://whatisbyme.blogspot.in/2012/05/car-runs-fine-but-check-engine-light-is.html
Check engine light with codes P2195 and P2197?
http://howtobyme.blogspot.in/2012/01/check-engine-light-with-codes-p2195-and.html
How to Read Codes from Check Engine Light? http://schematicsdiagram.blogspot.com/2011/12/how-to-read-codes-from-check-engine.html
-------------These will help.Thanks.
1helpful
Code po480
Fan 1 controll circuit no dtc definition not found refer to vehicle service manual is what my scanner says but you will need to have the car put on an OBD//EOBD scanner to check it out properly
3helpful
2answers
I to reset the service engine soon light on a 2002
You will need a OBD II scanner to erase the code from the ECM.
1helpful
Service Engine Soon remains on
you have a problem somewhere in vehicle. put a obd 2 scanner to read codes, and after fixed the check engine light can be turned off with scanner. if no access to scanner, any auto parts place will scan car for no cost. especially at auto zone. carl,
2answers
Service engine soon light on.
This is a light which indicates that the odometer mileage is approaching a service interval. The service intervals are in the owner's manual.
The concept is you take the vehicle to the shop for routine preventive maintenance (and the mechanic resets the light until the next service interval approaches).
Charlie
2helpful
2answers
Service engine soon after a transmision problem repair
These two events are probably not related. The serviceengine-soon light just means that the vehicle mileage is approaching a service interval.
The concept is when this comes on the vehicle is taekn to the shop for its routine service and the mechanic resets the light.
If you have an owner's manual you'll find the service intervals -- the mileage is approaching one of those intervals.
Charlie
Charlie
2helpful
3answers
Unlock antitheft code for 2004 chevy impala
Radios in the 2004 Impalas are tied to the vehicle's VIN through the computer, so it may be somewhat difficult to get the code. However, the following steps should work:
1. Press and hold the buttons for presets 1 & 4 (may be 2 & 3). The word "SEC" should show.
2. Press the "MIN" button. "000" should be displayed.
3. Press the "MIN" button again to have the second two numbers appear. Record these numbers.
4. Press the "HR" button for the first two numbers to appear. Record these numbers. -- Note: Your number sequence should be the numbers from the "HR" button followed by the numbers from the "MIN" button.
5. Call 1-800-537-5140. This will get you to the GM unlock code automated line. Ignore the prompt and enter "202108#". Next enter your code (remember, HR then MIN) followed by the * key. For example, 1234*. A 3 or 4 digit code will be given to you. If you get a code such as 0532, drop the zero when entering it into your radio.
6. Enter the code into the radio IAW the applicable manual.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
