Question about HP Color LaserJet 2600n Printer
RE: printing hello ther, i purchased hp color laserjet 2600n, i installed the prog in my laptop n printed some paper glossy n normal, before it did print bt nw the comand is in been accepted, on the printer it appears "printing document" then after few seconds it appears "ready" n the document is not printed.... please assitst me in how to print, do i hv to change the settings according to paper.
    Genius:
  • 1,554 Answers
You can change it on the fly as you print or
go to the start/settings/printers/ (then open your printer )
on the printer menu at the top ....
select printer /printer preferences and make the changes you want
Posted on Feb 03, 2008
I have a HP Color laser jet 2600n printer. I have tried different Glossy paper, marked for laser jet, but still get bad smudges on my prints. these smudges are still visible on the next ordinary prints...
You need to ensure that you are telling the printer that and your print driver that you are using glossy paper as this will change the speed that the printer prints at and ensure better bonding.
May 23, 2011 | HP Color LaserJet 2600n Printer
Hello I have an HP 2600n and would like to print on 5x7 paper, is this a possibility with this printer? it seems that it will pull the paper through but nothing is printed
Copied this from the specification on HP site.
It would appear not to take 5 x 7. It's the 7" is to small, 8.5 is the smallest.
Media sizes, std.
Letter, legal, executive, No. 10 envelopes, Monarch envelopes
Media sizes, custom
Tray 1, 2, 3: 3 x 5 to 8.5 x 14 in
Media types
Paper (plain, letterhead, prepunched, bond, color, rough, preprinted, recycled), HP Color Laser Glossy Photo Paper, HP Color Laser Glossy Brochure Paper, HP Color Laser Matte Brochure Paper, HP Color Laser Matte Photo & Imaging Paper, HP Color Laser Soft Gloss Presentation Paper, HP color laser transparencies, labels, envelopes, cardstock
Nov 30, 2010 | HP Color LaserJet 2600n Printer
Up to what weight paper can I use in my HP Color Laserjet 2600n
Usually you can print up to about 60lb paper. You may be able to go as high as 90-110 (card stock) if the paper print path is straight thorugh. If you printer has a rear paper door then you can try heavier paper. Usually 40-60 is safe for printer without a rear door/heavy paper path.
The problem is that the heavier paper cannot bend around the rollers inside. So if it is setup to allow heavy paper it runs through flat and out the back instead of curling around and out the top as normal.
Apr 17, 2010 | HP Color LaserJet 2600n Printer
Can't print to HP 2600n over network
The LaserJet 2600N has a built-in print server and can be connected to the local network (normal ethernet cable) directly. While printer sharing via Windows should work, I found it much more convenient to access it without the need of a hosting computer - you do not need to switch on the desktop PC for printing from the Laptop, for example, its also printing faster.
Jan 25, 2010 | HP Color LaserJet 2600n Printer
Messy print when using glossy paper.
ok. sometimes the ink for hp if its not photo ink will do that. go to your printing settings/preferences and adjust your ink out put to less and dry time to more. you may have to adjust a few times to get the right balance. if you dont want to set it up for all printing you can also change settings when your ready to print. . just follow same steps when you are going to print. but you have to do it everytime you want to print a photo. also make sure to set your paper selection to glossy photo paper
Apr 24, 2009 | HP Color LaserJet 2600n Printer
Gray background where printo on glossy paper 130g/m2
hello
this sounds like a bad black ink cart, or the fuser rolls built into the printer are dirty.
you can swap out a black cart to test that theory, you can also just print a single blank page (no text or graphics) onto a piece of glossy paper and see if there is anything there after its gone thru the printer.
if the piece of paper has stuff on it it had to come from the rollers inside the printer.
service required,unless your comfortable changing out parts in your printer.
norm
Nov 06, 2008 | HP Color LaserJet 2600n Printer
Black smugs on any glossy print
check the fusing area. (where the paper is heated)there is an adjustment for envelop . set it to normal because the pressure on fixing unit is too loose.
Jul 11, 2008 | HP Color LaserJet 2600n Printer
2600N: glossy paper
Is this HP glossy paper? I would think that laser printers have a hard enough time handling any glossy paper as it is because you run the risk of the gloss burning as the paper goes through the printer so you might have to use the paper recommended by HP.
Here are the specs of the accepted paper.
http://shopping.yahoo.com/p:HP%20Color%20LaserJet%202600n%20Laser%20Printer:1991823169:page=details
Good Luck!
Hope this helps!
Mar 07, 2008 | HP Color LaserJet 2600n Printer
Adhesive jam
Some adhesive still on the transfer or fuser. Try a cleaning page, or some manual cleaning with dry towel-paper if adhesive signs are visible on transfer. Do not try fusing unit because very delicate silicone film inside.
If stain are of a single color, (p.es. magenta) you must change this cartridge.
Dec 24, 2007 | HP Color LaserJet 2600n Printer
HP Color LaserJet 2600n Printer Logo
59 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
