Question about LG WM-1832C Front Load Washer
Westinghouse Mastermind 7kg front loader washing machine
I have a Westinghouse Mastermind 7kg front loader washing machine that has a few probs. For starters it will continue to fill and unless I intervene and drain some water to commence the cycle it will continue to fill. Also it is inconsistent with draining and sometimes will and sometimes won't. Any thoughts?
  • 1314 Answers
SOURCE: washing machine dosnt spin dry,
remove the front panel and check for obstructions in the drain pump also on some models there is a catch screen in the tub to pump hose if you have a shop vac pull the water out of the drain hose first as there will be water in the unit
Posted on Jun 03, 2008
SOURCE: I have a mastermind 708
Ihave a mastermind 708 7kg front loader and the SE is flashing and machine wont work can you help please? Thankyou
Posted on Nov 22, 2008
SOURCE: error on Westinghouse mastermind 708 front loader washing machine
This happend to me once, and it was in relation to a blocked intake filter.
- Check that the intake houses are not cloged and the small filter under neath is clean (Use an old tooth brash)
- Also check the opening on the front bottom left of the machine. (Open with a flat head screw driver)
. My one had coins in it. Note: drain with the small pipe into a backet so when you open it you don't have watter everywere.
Posted on Feb 06, 2009
SOURCE: westinghouse mastermind 700 flashing HE
I just had to lighten the load. I think that HE means heavy. It works fine now.
Posted on Aug 24, 2009
SOURCE: Westinghouse Front Loader LF708C
You will find that the pressure sensor sampling tube is blocked with soap deposits. Needs to be cleaned out for the sensor to work properly.
Posted on Sep 06, 2009
I have a Westinghouse Mastermind 711 Front Loader Washing Machine which is flashing OE and the clothes inside are very wet. Can you please let me know what this flashing OE means....Many Thanks, ELena
Hello & Welcome to FixYa
OE is a drain error and is displayed when the washer is unable to drain water. Please check the drain hose and drain pump filter for any clogs to clean the error. Please get back to me if you have any other questions.
Kevin
May 27, 2011 | Westinghouse Washing Machines
Westinghouse mastermind 700 flashing HE
Aug 24, 2009 | Westinghouse Washing Machines
SE shows on the display
Water Sensor Error. You need to have this changed as it has failed
Aug 15, 2009 | Washing Machines
Bendix aw1054 front loader wont fill as continually pumps water
If the pump is on all the time, then you definately have a timer and or control board prob, the only other possibility is if the drain outlet hose is to low.
This will cause the water to syhon out , thereby giving the impression that it is pumping out all the time.
To check this, try lifting the drain hose higher, and see if that solves the prob.
Plz rate my solution.
thanks.
Jan 12, 2009 | Tricity Bendix AW1054 Front Load Washer
I have a mastermind 708 7kg front loader and SE is flashing and maching won't work can you help please
Aug 03, 2008 | Washing Machines
Washing machine dosnt spin dry, front loader westinghouse mastermind 708, 7.5 kg
Jun 03, 2008 | Washing Machines
Westinghouse 798 front loader 7kg washing machine
God Sir
I am mr Yapi Antione from abidjan i am dealing with all washing marshing i saw your profle and i am intrested to to know the pris list of all the marshing in your company
i will like to haer from you as soon as posible
yours representetive
Mr Yapi Aantoine
you can reply me in this my email adress
yapiantione@yahoo.com
Or
Call me 0022501307526
Apr 04, 2007 | Zanussi FJS1225W Front Load Washer
LG WM-1832C Front Load Washer Logo
109 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
