Question about Samsung V20 XTC 1800 Notebook
DVD Drive How do I remove the DVD rom drive? I've taken the screw out from underneath but there seems to be more too it...... any help welcome
    Novelist:
  • 77 Answers
1. Turn off laptop and disconnect all cables. Close lid tight and turn your laptop upside down on one layer of a soft cloth (to avoid scratching case).
2. There should be many screws visible beneath the laptop. ONE of them (only one) will be located in a line from the center of CD, about 12.5-13.5cm (5 inches) towards the center of laptop. Remove that screw (may require a TORX or other special screwdriver). If there is no such screw, then ignore all the rest of this and go to a shop. Your CD must be disassembled to remove the CD. Otherwise, proceed to step 3 if you successfully located and removed the screw.
3. Now, look at the face of the CD tray. There will be a small hole in there somewhere near the eject/open button. Press a small straightened paper clip into the hole gently and STRAIGHT, not at an angle.
4. You should hear a light click, and the CD will open. Gently return the laptop to normal, right-side-up.
5. Gently pull the CD tray out, and gently pull until the whole CD case comes out.
Posted on Feb 04, 2008
    Genius:
  • 3,587 Answers
Once the screw is removed, you may need to insert the tip of the screwdriver, behind a small curved plate, where screw went in. Also, on outside of the laptop, there is usually a small button/tab key, which may be pressed in, then retracted, to pull the DVD drive out of it's bay.
Toshiba Satellite M35X-S1142 dvd rom
if you want to remove it from the laptop there will be a screw or screws on the bottom of the laptop on or under one of the covers.it will be about 4 inches in from the edge of the dvd drive.
Oct 15, 2012 | Toshiba Satellite M35X-S1142 Notebook
Acer Aspire 4310 -- DVD ROM not working! It was started when i inserted a dvd on dvd drive and it stucked up. It was about 3 days when the dvd was removed by using a needle. Then all it started not to...
HI,
Welcome to FixYa. I believe that you are having problem with your DVD ROM, here's how you can fix your problem.
1. Click on START
2. Type REGEDIT on the search bar on START Menu or the Run Box
3. Expand HKEY_LOCAL_MACHINE
4. Expand SYSTEM
5. Expand CurrentControlSet
6. Expand Control
7. Expand Class
8. Click {4D36E965-E325-11CE-BFC1-08002BE10318}
9. Look for the Upper Filters / right click on it / click on Delete
10. Look for the Lower Filters / right click on it / click on Delete
11. Restart PC
12. Try you CD / DVD ROM
Hope this will help.Thank you for using FixYa.
Mar 20, 2011 | Acer Computers & Internet
Need to remove the cd/dvd drive in Toshiba Satellite A135 S4527 l
Most notebooks have a quick release button underneath for the CD-rom. There may also be a screw holding it in place. It's unlikely that you would have to remove your keyboard to take the dvd drive out.
May 06, 2009 | Toshiba Satellite A135-S4527 Notebook
Aspire 3050 laptop
I've taken a lot of drives out of laptops and usually they are easy to remove and just have a button you need to press to pop them out or they are held with a single screw underneath around the center back of the drive. Those two possibilities should have you covered, and I have rarely found optical drives to be difficult to remove from laptops.
Sep 24, 2008 | Acer Aspire 3000 Notebook
Removing/replacing dvd rom drive
Hi Jerry
I have written down steps on how to remove the DVD-Rom drive for you.
Toshiba notebooks most screws are marked.
F4 - flat-head screw 4mm long
B6 - button-head screw 6mm long
F16 - flat-head screw 16mm long
B8 - button-head screw 8mm long
When you are taking apart a laptop you'll have to deal with lots of screws. Keep everything organized. I keep them in small cups separated easier to find and don’t get lost.
1. Remove the laptop battery
2. Carefully lift off the securing strip at the top of the keyboard.
3. Remove the keyboard securing strip.
4. Remove all screws securing the laptop keyboard.
5. Disconnect the keyboard cable from the system board. Lift the edges of the connector first and then carefully disconnect the keyboard cable.
6. Remove screws securing the power switch board.
7. Disconnect the USB cable from the system board \motherboard
8. Lift off the power switch board.
9. Remove all screw from the support plate.
10. Remove the DVD drive securing screw.
11. Slide the DVD drive to the right and remove it.
12. Slide in the new DVD drive and follow this backwards.
Hope this helps it is not hard just have to take time an becareful when removing the securing strip at the top of the keyboard to get to screws.
Any questions I will be glad to help answer for you.
Bill
Jun 24, 2008 | Computers & Internet
Replacing dvd/cd-rom drive on gateway laptop
Without knowing your specific laptop, look underneath about 5 inches from the edge where the drives slides in. You should see a screw there but not holding a panel.
Remove that one screw, pop the drive open and give it a gentle pull, it should just slide out.
Most laptop drives are the same with the exception of the faceplate and the bracket (surround) that is attached to the bare drive.
This is removable and can be transferred to another drive. Careful not to lose any of those tiny screws =)
Apr 09, 2008 | HP Pavilion dv6000z Notebook
INSTALLATION OF DVD ROM DRIVE FOR TOSHIBA SATELLITE A45-S150
Underneath your satellite there should be either a spring loaded lock to unlock/release the drive, or there could be a panel to remove that will expose a single screw that holds your optical drive in place. Releasing the drive with whichever locking mechanism is securing it should allow you to remove and install the new drive (if it's a screw, don't forget to replace it after the new drive is installed).
I hope this helps, and Good Luck.
Feb 22, 2008 | Toshiba Satellite A45-S150 Notebook
Replacing DVD/RW-R drive on HP ze2000
very simple, just remove the casing then disconnect the wires from power supply colored yellow,black,red (connector) to dvd rom, then disconnect the cable ribbon to dvd rom unscrew the dvd to the casing then slide out the dvd rom backward( if you are facing the cpu) bfore you install the replacement, you need to check your dvd rom which you have taken out and compare the jumper orientation to your new dvd rom. if the old one is in cable select or in primary or in slave just follow the old one. now if you are finish checking the jumper orientation, you may proceed in installing your dvd rom on casing, install back the screw on bothe sides and all the connectors. power on thats it your finish just proceed to the my computer and check if this appears in it or in the device manager. i hope that this helps you, any questions or clarifications feel free to ask me.
Nov 22, 2007 | Computers & Internet
Samsung V20 XTC 1800 Notebook Logo
130 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
