Question about Toshiba SD-K510 DVD Player
A DVD got stuck in the dvd player and the door does not open to allow me to remove it.I was able to play the DVD that got stuck in the player a few days ago but now nothing works (play, eject etc) with the remote or the dvd buttons. I turn the DVD power is stays on for a couple of seconds and then the power goes off. I followed te manual's correction action and turned on/off the power , disconnect diconnect the poewr plug but nothing changes. Thanks for any help you can provide. Mike
  • Anonymous Feb 06, 2008
    If you get a small paper clip, there should be a small hole in the general area where u put the DVD in. After you locate it just put the paper clip in it a pull and the opening should be able to be pulled out.
Unplug dvd player, hold down open button, then while continuing to hold down open button, plug dvd player back in.
Posted on Mar 16, 2008
Why doesn't the open/close button on DVD player of DVD/VCR combo work?
Assuming there is not a forgotten tape stuck in the VCR side, the mode selection logic has gotten all confused. On the VCR side, a tape is grabbed and loaded to be played. There probably is an EJECT button that is enabled for later use. The DVD side is disabled so no buttons work. On the DVD side, the open/close button is enabled (if no VCR-side problem is detected), allowing you to place a DVD in the tray and close it to play. The VCR side is disabled so no buttons work. That's the theory. From your description a sensor on the VCR side may have failed or been damaged, causing the player to keep reverting to VCR and preventing use of the DVD side.
Sep 21, 2015 | Emerson EWD2204 DVD Player/VCR
Disc door won't open. DVD in will still play. How can we make the door open
try to re start the power first to reset the supply in which the door unable to open and then push the open/close button to open the door. if still won't open maybe their is an stuck up at mechanical part, so turn off the player then use a Phillip screw driver to loosen the screws and to remove the cover of the DVD player .you can now access the disc mechanical assembly of your DVD player, remove the CD first and then check if the plastic gear is mis aligned or the the drive belt is broken.much better if you can apply silicon grease in plastic gear for smooth operation.then make sure the open/close button is ok, good luck and good day.
May 03, 2011 | LG Televison & Video
A dvd is stuck in the dvd player
something stuck our dvd-door.
1. open the dvd
2. remove the thing that block our dvd door (like paper, tissue, paperclip)
or
maybe our dvd mechanic door had block by dust
-----basicaly, clean it.
in my case. I knock the upper top of the dvd door hard (but not by hammer, by my hand) while i push open button (the menu open/'open' word is display at the menu). if u're lucky, the dvd door will open
Sep 29, 2009 | Hitachi 46W500 46 in. TV/DVD Combo
Can't open the DVD door. Wen I turn on the DVD Player, it starts reading a DVD that's stuck inside, and after a while e turns off alone. The door doesn't open and it seems to have some process runing that...
you'll have to remove the top and remove the disk that way. there's a top bracket on the dvd drive to remove before you can get to the disk. and unplug the unit first!!
Aug 12, 2009 | Philips DVDR3330H DVD Player/HDD Recorder
Door to open dvd seems to be stuck
try turning unit up side down and try again.
Mar 15, 2009 | Philips Magnavox DVD/VCR Dual Player
The disk tray won't open. There is a dvd in the tray and I played it back but, when I tried to eject it, the tray door would not open.
check if something is blocking the door to open.if no then the gears in the internal area are either worn out.apply the oily substance in the sides of the dvd gears to make it move frequently.
thanks.
Oct 29, 2008 | Lite On Televison & Video
DVD player door won't open
took out the dvd player and inverted it and pushed the advance disk button . There was a disk stuck between the disk slots. The door opened and I removed the disk.
Sep 20, 2008 | GPX D2816 DVD Player
Dv-c503 pioneer dvd player
the magic eye on the door opener in been obtruated by something .. like a small object stuck on a cd or someone might just open the door and let something in it .. stuck on the slidetrack ..and interfer with the sensor .. maybe kids???
Dec 30, 2007 | Pioneer DV-C503 Multi-disc DVD Player
Can't get dvd out
Search your manual for "manual open", or some override. Sometimes there is a hole in the bottom of the player that lets you slide a knife in a push the door open a little bit. Should have something written on it, like "emmergency". I can't say it will work after that though. Sansui no longer makes most of the products marked "sansui", they sold the rights to use the brand name. I think orion makes it's basic level TV and Video equipment, and they tend to break after you take a few steps out of the store. Hope it works out for you.
Jun 13, 2006 | Sansui VRDVD4001 DVD Player/VCR
Toshiba SD-K510 DVD Player Logo
273 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
