Heating & Cooling Logo
Anonymous Posted on Jan 04, 2010
How do you change a wick in a dyna-glo rnc 95-c4?
How do you change a wick in a dyna-glo rnc 95-c4 kerosene heater
  • Anonymous Jan 04, 2010
    P dont think we are talking about the same model
Anonymous
Level 3:
President:
  • Master 570 Answers
  • Posted on Jan 04, 2010
Anonymous
Master
Level 3:
President:
Answers
570
Questions
Helped
148862
Points
1647
Make sure to be very careful!
Colin Stickland
Level 3:
  • Master 22,516 Answers
Colin Stickland
Master
Level 3:
Answers
22516
Questions
Helped
6989911
Points
66324
Long time since i changed a wick ,turn the wick housing anticlockwise to remove it from the fire ,then turn know backwards till old wick drops out ,then push new one up and wind the knob as you lightly push it up so the wheel picks the new wick up`and then winds it above the level of the housing to where it should be .dont forget to let it soak up the fuel for a couple of hours before lighting it .
Need to see pictorial instruction on how to replace wick in a Dyna Glo RMC-95-C2 kerosene heater
I think the Dyna-glow RMC95 series of heaters are equivalent to DH2300 series heaters.
In any event, the wick you purchased should have ahd the installation instructions included with the wick.
If it didn't or you tossed it, Here's a link to the DH-2300 series heater's Owners Manual, which may help you.
http://www.yourheater.com/DH2301-3%20owners%20manual.pdf
Good luck. Be sure to wear rubber gloves when you try to install the wick. Particularly, if you still have kerosene in the tank.
3helpful
2answers
I just replaced the wick, cleaned up the heater and filled with new K-1 kero. The heater (Dyna-Glo RMC-95-C7) is emitting black smoke worst than ever. The wick is burning a little unevenly.
Either the wick was improperly installed or you may not have allowed enough time for the wick to soak in the kerosene and become evenly distributed. Check the placement of the new wick and allow time (several hours) for the wick to absorb the kerosene.
1helpful
Wick not burning properly and smells
You need to use pure kerosene do not use died or color kerosene it depletes the wick faster and causes a distinct odor. Pure kerosene should be clear.
Can not location a source for igniter plugs for my Dyna-Glo RMC 95 kerosene heater
Below is a link to eBay where you can purchase an igniter for you heater:
http://cgi.ebay.com/Kerosene-Heater-Replacement-Wick-Igniter-1183017-NEW_W0QQitemZ390095252633QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item5ad37d2c99
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
Kerosene heater
Dyna Glo 95 c4 Manual
http://www.owneriq.com/mdownloads/8979e0af-dfee-45f1-a8ba-c05c2f5ed4a8.pdf
4helpful
Help
Top Heating & Cooling Experts
Paul Carew
john h
