Question about Magellan RoadMate 2200T GPS Receiver
GPS 2200T Just Quit Today
My less than 1 year old failed to turn on today 2/02/08. Worked yesterday. Kept DC plug in for car. This morning, would not turn on. Wrote Magellan for solution. Uggg!
  • 1 more comment
  • chefrby Feb 03, 2008
    MY GPS 2200T WORKED JUST FINE UNTIL THIS MORNING WHEN I TURNED IT ON, THE TOUCH SCREEN JUST DOESN'T RESPOND.  I THOUGHT THAT IT NEEDED TO BE CHARGED, SO I CHARGED IT, THEN I PRESSED THE RESET BUTTON, THEN WHEN I SELECTED THE NAVIGATOR TOUCH SCREED BUTTON, I DID NOT GET ANY RESPONSE.
  • schnick Feb 17, 2008
    Tried to charge, tried reset. Does not respond to anything. Won't turn on.
  • kerae Mar 25, 2008
    My MAgellan RoadMAte 2200T stopped turning on- I haven't even had it for a year. Tried recharging it... tried to reset,.. and no luck.
    Problem Solver:
  • 8 Answers
I followed similar instructions, however I pulled the battery connector off the main board for a few minutes, reseated it, and she booted! back in business!! mine also about a year old, but after the firmware upgrade was a little flakey, time goes off sometimes, etc.
Posted on May 18, 2008
My 2200T developed similar problem and shut down and when attempting to start it, I received “low battery message”. After getting a run around from the manufacturer (out of warranty by a month), I decided to take a look myself. This does not men that I encourage just anyone to do this and if you break the unit more seriously I am not responsible. The process is as follows:
Unscrew the back panel (six screws), gently remove it (be careful of the speaker wires attached to the PC board). You do not have to remove the back panel any further than to get access to the power outlet (where you plug in the power supply). On the inside of the unit, on top of the outlet is a thin copper plate, it is likely that it was bend up with use and lost contact with the plug. Gently bend it inwards using a small screwdriver (be careful not to break it). That should do it. Your unit should be getting the power and battery should charge now.
Posted on May 02, 2008
MY GARMIN STREETPILOT C310 WORKED THIS MORNING, BUT NOW WILL NOT SWITCH ON?
It is also 7+ years old. in technology years that is like 140 years old. retire it and get a Nuvi.
Remember that time you went to start your car and it worked yesterday but today it would not start... bad stuff happens.
If you are holding out hope, try leaving it plugged into the car or outlet
try holding the power button for a long time (30 sec)
try plugging it into a computer and see if anything happens.
Mar 22, 2015 | Garmin GPS
TomTom Go730 worked great yesterday, is a brick today. Battery charged, reset per TT website instructions, nothing. Any suggestions?
not much to do with that unit, check with a volt meter to verify that power is present at the plug cord charging, if all your efforts fail and the unit is dead your trouble is in the unit itself, this unit is not serviceable by any one other than one with knowledge and equipment to repair this unit, check for warranty if not obtain a new one,,,?Sorry
May 18, 2012 | Tomtom GO 730 Car GPS Receiver
Microwave will not heat
The problem is the magnetron, "heart of the microwave oven" or the inverter board if 7 years old or less.
Apr 19, 2012 | GE Spacemaker Over-the-Range Microwave
WONT TURN ON , TRIED TO RESET AND IT STILL WONT WORK, UNTIL THIS TIME IT ONLY WORKED IF IT WAS PLUGGED IN.
its probably not charging...very common problem with this and many others.
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (upto ten seconds) until it starts..if that fails
the following magellan 2000,2200t,2500,3000,3100,3140,4000,4040,4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get it repaired, here
or buy the port here
if you need further help, just let me know.
Oct 07, 2009 | Magellan RoadMate 2200T GPS Receiver
I have an rca L42WD22YX5 that just went to a blank screen yesterday. The screen keeps reading unusable signal. It is only 14 months old.
i had this happen last year, now my tv is messed up again. when we had the problem with the unusable signal, the tv repair shop told us it was the main motherboard that caused it. ended up paying $250.00 to have it fixed. Now, our tv is broke again, this morning turned it on, got the green light, then just started flashing red, hasnt worked any at all today, reset it and everything. My suggestion, if you can afford to buy a new tv, do it, because I called the repair shop again this morning about the new problem, they said after the 1 year warrentt from rca runs out all they do is tear up. My tv isnt even 4 years old, bought it at the end of 2007, now its tore up twice, going to purchase a samsung in the morning from brandsmart. Good Luck!
Sep 29, 2009 | RCA L42WD22 42 in. LCD Television
Plugged in; worked yesterday; 8 months old. today: nothing. black screen, no sound.
try to run virus scan , then try to reinstall the operating system
Aug 07, 2009 | Acer Aspire One PC Notebook
My thermostat quit working
Does it have batteries that need replacig. I think so. good luck.
May 31, 2009 | Honeywell Programmable Thermostat Heater
MAGELLAN GPS WILL NOT POWER UP
the folowing advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050 and 6000t
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
due to some dubious "experts" on fixya, im not permitted to help you directly, but please follow the link above to get further help.
let me know if you need more help or info
bill
Sep 24, 2008 | Magellan Maestro 4040 GPS Receiver
Magellan RoadMate 2200T GPS Receiver Logo
53 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
