Question about Acer Aspire 3680 Laptop
Same Weird Problem,
Hi Melnavz,
I use your step-by-step and I have the same weird problem. Weird because when I plug the AC adapter, the laptop start right now... without press the power on switch. At this point, the LED power flash green and orange without stopping.
If I stop the laptop, the LED power stay green and the battery led stay off.
What's the problem ???
Thank's in advance
Claude Vincent (cvincent_@sympatico.ca)
    Genius:
  • 1,226 Answers
Is the laptop display a windows or black out
Black out?
Please stop the laptop by pressing the power button until it stop.
remove the battery
remove the memory and then after 15 minute insert back the memory and install the battery.
If the system display windows, and the problem is always start when plugging the ac power. maybe the battery of the laptop is damage.
Please try go to bios setup and then at the power option, find the restore the "last state" something like that and the set it to "off: option.
Posted on Feb 03, 2008
Samsung Laptop Shuts Down Unexpectedly
It may be overheating. Try using a vacuum cleaner hose on the air vents, that will help to clear the ventilation for the radiator.
Jan 18, 2014 | Samsung Computers & Internet
How to dismantle
google for "service manual s2210" filetype:pdf.
Nov 24, 2013 | Fujitsu Siemens LifeBook S2210 Laptop AC...
Hi, my laptop crashes when the ac adaptor is plugged in yet it will charge the battery fine when the laptop is shut down.
Problem description: The laptop shuts off when AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
Possible cause: 1. Power adapter failure.
2. Motherboard failure.
Possible troubleshooting steps and repair solution: First of all, test the power adapter. Make sure the adapter outputs correct voltage. It's possible that the output voltage is not correct and the laptop shuts down to prevent the damage. Test your laptop with another known good power adapter.
If the problem still exists, even after replacing the adapter, most likely it's the motherboard failure. Replace the motherboard.
Resource: Acer Laptop AC Adpaters
Mar 20, 2011 | Acer Computers & Internet
It won't turn on
Hi. Try theses simple steps:
Remove the Battery
Remove the AC Adapter
Press/hold down power button for 10 seconds
Plug AC Adapter in and turn the computer on
If the system doesn't turn on still then there's a problem with your motherboard. and it might need replacement.
Jun 06, 2010 | IBM ThinkPad T40 2373 Notebook
My daughters Toshiba satellite l505d will not boot up correctly. It starts but then nothing happens. What do I need to do. Have already taken battery out and restarted. Any help would be helpful.
Try the following.
1. Remove battery and plug in the AC Adapter and check if it works
If yes - Battery is defective
If no - Motherboard Problem/AC adapter
2. Check the AC adapter LED indicator if its lighted or not(double check by a multitester)
If lighted - it works properly
if not - replace
3. Try to reinstall WINDOWS operating system by the use of the installer CD
4. Reformat your computer and install necessary drivers and applications
Thanks. Cheers!
Apr 15, 2010 | Toshiba Satellite L505-S5966 Notebook
Screen flicker (only when ac power is removed)
Hi there
yes its the graphic drivers that needs installing, i must also tell you that when you remove AC power from the laptop it will go into power saving mode and you will notice that the screen dims a little, this is normal and nothing to worry about
Kind regards and please don't forget to rate us
Dec 12, 2008 | Acer Aspire 4315 Notebook
Noise coming from AC adapter
There is a possibility that the power managment sestem in the computer has malfunctioned and is back feeding and burning up the supplies. You will need to take this in for a professional diagnostic to find out if you have a back feed problem. A back feed problem is rare, but not unheard of.
Jul 16, 2008 | Sony VAIO VGN-N130G/W Notebook
Power will not turn on??
Try this:
1. unplugging the power cable
2. removing the battery
3. plug in power cable
4. switch on and start up
If this works, shut down, unplug and replace the battery.
Hopefully your problem is resolved.
John (Computer Tuition, Blackpool)
Nov 08, 2007 | Compaq Presario 900 /1500 Series EVO...
Acer Aspire 3680 Laptop Logo
139 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
