Question about LG KG220 Cellular Phone
Lg mobile battery indicator
My LG KG110 mobile.When i charge battery after sometime stop chargeing again i insert charger charging start then again stop charging this process continous.
Please help me
  • 168 Answers
Have you tried a different plug? Sounds like the plug might be bad. If you have a car charger, and a house charger, I would try both. IF one charges, and the other one doesnt, you have your answer. If you have trouble with both, then either you have 2 bad plugs, or the socket on your phone might be bad.
Either way, your local phone dealer can check them out in seconds, and some places won't even charge.
Good luck
Posted on Feb 03, 2008
I have charged the phone put the sim in it and no life
Please make sure that the charger was properly plugged in the electric socket and that it was also properly attached to the mobile.Take out the battery for 10 seconds and then insert it again. Charge the mobile again.
Aug 16, 2011 | LG Prada KE850 Cellular Phone
A friend just gave me an lgcu720 phone. the phone is nice except for the fact that when ever im charging it it switches off (while still charging) and says insert battery. im not able to switch the phone...
Hello.
Bring it to a mobile phone store and inquire for a charger. Test it if it will charge your battery the way it should be, before buying it. If it doesn't charge properly in the store, then ask for new battery and test it also before buying it. That way you will know which is malfunctioning: battery, charger or both.
Jul 21, 2011 | LG CU720/ Shine 900mAh Lithium Battery...
Battery not charging and overheating very quickly
actually.. our indian electricity as 240volt and 50 hertz..
and united states electricity as 110volt and 60 hertz.. i think you aware of this...this makes changes i think..if u r not aware try google search abt electricity IN america and india...
1.take ur mobile and go to LG showroom nearby and ask about this problem..
2.and we can have better converter for this type of mobiles...
"try asking in famous electrical and electronics shop.."
if the battery is suddenly discharging thats seems to be duplicate battery .. try buying original battery that cost more....
"DONT FORGET TO RATE THE SOLUTION "..
Apr 15, 2010 | LG KC910 Renoir Cell Phone
I had phone on charge all night and it still is not charged up fully yet. any ideas
1. change battery and check
2. change charger and check.
3. check charger cable if well inserted.
Feb 21, 2010 | LG Vu CU920 Cellular Phone
Wont charge
hello,
try to use the charger on another phone to see if works, if it does it means its not the charger.
then try to remove the battery and reinstall it, the try to charge again with phone off.
or you can try another charger on the phone, if it doesn't charge it must be the charging connection port on the phone that has a problem.
thank you.
Jan 07, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
I can't charge my lg mobile on the mains or on the computer
It seem the charging port is faulty, you need to replace it for your lg mobile to charge again.
Also confirm if the lg mobile charger is still working so the we can both be sure it the charging port.
Take care.
Dec 04, 2009 | LG Shine KE970 Cellular Phone
My LG VU charges just fine sometimes, and other times it will say its charging and drain the battery, and other times it wont register that its charging at all.I have 2 house chargers, and one car charger...
well about the arrows being upside down, some phones like this one the charger goes in up side down like for example the katanas. But about the charging issue check in the back of the phone and look for a red or white sticker or maybe pink. if its red then thats indicating that it has been water damaged and if its white then that indicates that if might not be but if you look in the charge port and check if it has like some green and white corosion in it. If you would like some help with this just e-mail me at Purelatina2004@yahoo.com
Jun 15, 2009 | LG Vu CU920 Cellular Phone
Battery Wont Charge
either the battery is drained so its not getting charged. remove the battery from the cell and check out.or the charger is faulty so need to replace the charger.sometimes pressing the pin of charger in to the cell gets connected internally and the charging starts try it.other wise that two above things need to be checked.
Mar 02, 2009 | LG ALLTEL AX275 Cellular Phone
LG shine wont charge
Zoe-
The charger port is going bad. It happens over time The symptom of this is you have to hold it into place.
The first step is to contact your carrier to see if it is covered under warranty. If it is, great get it replaced.
If not, you have 3 options:
1. you can get the charging port repaired. The cost is about 50 dollars. I recommend Cellulardr.com
2. you can get a new phone. cost ???
3.Youcan get an external battery charger to charger the battery separate fromphone. An extra battery is a good idea as well so you canhave one charging at all times. The best and cheapest place to buy a new charger for yourshine is ebay. They run about 5 dollars shipped. Check out thefollowing link for the selection.
LG Shine Battery Charger
I hope that helps
Jan 31, 2009 | LG Shine CU720 Cellular Phone
LG KG220 Cellular Phone Logo
143 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
