Denon CD door jammed
The door of my Denon cd player will not open or close. There is no cd inside. Anything I can try?
  • schramee Feb 06, 2008
    Although my problem is not fixed it worked like a charm for one of my friends!
  • Anonymous Mar 14, 2014
    CD door opens slowly, get stuck on return; when closed recognition lights go on - read '0' and the list of tracks is 1 through 20 but does not read or play cd
  • 168 Answers
If you are comfortable taking the cover off, you can try removing the cover and then try to help the tray out the same time you are hitting OPEN/Close.
IF you are not comfortable removing the cover then, you can try to take a credit card (Actually, if you have any of those JUNK credit cards that the CC companies send out as trial offers, those work the best, and who cares if you bend those, they get tossed anyway) and bend an edge at a 90 degree.. (about 1/8" of the edge) so it makes like a small ledge. try to fit it inbetween the top of the door, and then see if you can open it up. Some players have a seperate door, and some trays are attached to the door. You might be able to help it out or unjam the tray this way.
And in the Future, with any other CD/DVD Players, use your remote control or the open and close button to open and close the tray, and NEVER Push on the tray itself. If I had a dollar for every dvd player tray that Ive fixed because of this, I would be buying bill gates dinner. (not really, but you get my point)
Good luck.
Posted on Feb 03, 2008
The cd player will not open when you press the open close button
unfortunatly the mechanism is jammed up for one reason or the other reason #1 a cd is stuck inside #2 the gear just wore out and or it was forced closed by hand instead of pushing the eject/load button..you can try to gently pry this door open while pressing open/eject button that works 40% of the time..if it does not work? it can then be deemed broken out of order.
it's worth a shot trying to pry it open but beware this could either work or really destroy the door/mech/player comes down to this "do you feel lucky" sadly? that's where we're at with this one.
Mar 20, 2014 | Electro Brand Nostalgic Stereo CD Music...
When ejecting a cd the housing would open and close right back sometimes. How can this problem be fixed?
It sounds like the open switch inside the door is dirty & cannot make a connection when the CD door opens. Clean the switch & it should function properly. Otherwise, replace that switch.
Jan 08, 2011 | Denon DCD-3000 CD Player
CD carousel won't rotate. Opens and closes fine, but will not change discs in either the open or closed position.
gears may have something obstructing them. Check and clean with dustaway. Gears may be broken jammed or slipping belt.
Apr 06, 2010 | Denon DCM-360 5-Disc CD Changer
CD jammed inside player
Remover the player's cover. That will give you access to the player's internals and therefore also the CDs. That is the only way to go about a problem like the one you are facing.
Disconnect the player from the mains supply before doing this.
Good luck.
Nov 09, 2009 | Technics SA-AX530 Receiver
Denon CD player DCD 920. When using the open/close button once, the CD-door opens but when it is open, without any waiting time, it immediately closes again. If i operate manually the open/close switch on...
Off the power, and plug off the switch, and try opening it manually. DO NOT force open it. I don't think it would close back since it has no electricity already.
Oct 14, 2009 | Denon Audio Players & Recorders
Cd changer is jammed in denon dcm 360 5 cd changer
Simply remove the outer casing and remove the jammed disc
Nov 28, 2008 | Denon DCM-360 5-Disc CD Changer
Having a problem with my CD Player's drawer
This has to do with a mini switch inside the door mechanism that it pushes once but with the bounce phainomenon in electric pulses it thinks that you pushed the cd door inside manualy and it tries to close the door. Try replacing this mini switch. this will solve your problem.
Apr 15, 2007 | Denon DCD-425 CD Player
326 people viewed this question
 Grubhead
Grubhead
