Question about Canon Pixma iP6600D InkJet Photo Printer
Printer went downhill fast
I used to print full crisp photos all the time and as of late my printer is printing pixalated and blurry photos? I have gone through the whole cleaning and tried everything the manual asks me to do and still no good photos?
    Genius:
  • 1,554 Answers
Well that means a new print head then.
I would take it out and clean it as it doesn't work anyway
I see one on ebay for 45 includes shipping
this is what is looks like
http://www.precisionroller.com/i_canon-pixma-ip6600d-print-head_96ca/H0294/
Posted on Feb 03, 2008
6ya staff
SOURCE:
I have kodak 6850 print,i replace head 3 years ago,now my printer make at funktion like blurry print,than it okey for some time,now it start again, and now it onley make blurry pics
Can we assume you have checked the printers settings ?
Ie set it to the highest resolution, set it to photo mode (as opposed to text), set the paper type to glossy .Still having Problem Then follow Us For
Kodak Printer Support
Mar 12, 2014 | Kodak Photo Printer 6850 Thermal
I have a 2410 HP printer and it prints very very very slow. Can you help me? Email address pretty111comcast.net
I have the exact same model of printer, I find that it prints faster if you go into printing preferences and change the print quality to fast draft or fast normal. You can also set the printer directly by pressingcopy twice then press3 for copy quality, then select 3 for fast.
Doing both should produce faster printing for your documents. (NOTE : This will not suggested if you are printiing items that need to have crisp clean printing as the faster it prints the less detailed the printing is.)
Jul 22, 2012 | HP PSC 2410 All-In-One InkJet Printer
My Brother MFC-3240C printer does not print crisp images. Colors are washed out and lines run though the images. I reinstalled the CD and no luck. Can you tell me what to fix?
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there. Better than throwing the printer.
Good Luck
RK
Nov 25, 2009 | Brother MFC-3240C All-In-One InkJet...
When scanning a picture, the picture comes out faded even if the picture is clear and crisp.
Most scanners allow you to chose what resolution that you want to scan the photo at and you may have selected too low a resolution, for example for the web. If you want the highest resolution scan you need to select the TIF option if its there. If not, select the highest number available.
When you say its "faded", do you mean when it prints out or when it shows on your computer screen? If its when it prints, obviously it could be a printer ink issue or maybe your printer is set to "fast print", which gives poor resolution and may look how you explain.
Sep 12, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Printing every few lines blurry, but not every line.
Printer head is clogged, be sure to clean it until you get the solid lines
Jul 11, 2009 | Epson Stylus R380 InkJet Photo Printer
BLURRY PRINT OUTPUT
The head probably needs aligning.
An interum fix is to turn off bi directional printing in the preferences.
This could possibly solve the problem.
Jun 10, 2008 | Brother DCP 115C All-In-One InkJet Printer
Color printing
I removed the ink tanks then I removed the print head very carefully.
I rinsed the print head with the cleaner that comes with my refill
bottles, let it dry and carefully reinserted the print head. I "cleaned"
the nozzles and ran nozzle check and it worked fine.
I no longer trust this iP5000 printer for photos so I have purchased a new
Canon iP6700D which is great. I will use both printers...only using
the new one for photos only.
The main thing I have learned from my Canon printers is not to clean
the print heads as often due to that "Absorber almost full" message!
I still like the Canon for the ink capacity and separate tanks.
Your site has been so helpful! Thank you!
Mar 25, 2008 | Canon PIXMA iP5000 InkJet Photo Printer
Printer issues
If you are using Glossy paper, when you go to print make sure to go into the printer Properties from the Print dialog box and select Glossy paper in the type. This will put the printer into it's highest print quality mode.
So from most windows applications, it would be :-
CTRL-P (to print with dialog box for changes)
Click on Properties
Select a Media type of glossy photo paper
Select standard or high print quality.
p.s. you may need to experiment which if the media types gives you best quality for the paper your using, unless it's Canon paper and then just match it up.
Oct 29, 2007 | Canon Pixma iP6600D InkJet Photo Printer
Canon Pixma iP6600D InkJet Photo Printer Logo
88 people viewed this question
Clive
Clive
old marine
old marine
Ekse
