Question about Sony Ericsson P990i Cellular Phone
P990i: touchscreen stick borken into two pieces and stucked in the hole accidentely
Dear Experts
The touchscreen stick is broken into two pieces and stucked in the back side hole. would you please help me in taking out this stick. since my phone is now not under warrenty, I have tried to open the case , but was unsuccessful. could you also help me how to open this case and remove the stick.
Thanks for your help in advance.
Kumar
  • KUMAR4 Feb 11, 2008
    I got one more problem, my flip keypad is not working, it is not because of this problem i suppose...
    President:
  • 1,017 Answers
If you still have the other half of the stylus, put a tiny spot of super glue on the end of it and push it in the slot. Wait 10 minutes and gently try to pull the complete stylus out. Failing that use a tooth pick, flatten one end and do the same as described above.
Go easy on the glue it's much stronger than it appears, you don't want to glue the whole stick in the hole.
Posted on Feb 04, 2008
  • Raysagem
    Raysagem Feb 11, 2008
    The flip pad not working won't have anything to do with the stylus.
    The connection has probably loosened or broken, try to operate the flip pad at a slightly opened angle. If it works, the problem is a connection broken. It's repairable but best left to a specialist.
Juki straight stitch upper needle broken off and stuck.
You could try to pull it down with a magnet or see iff it will stick to some blu tack and pull it out with that.
Nov 02, 2012 | Juki DDL-8300
Tip
Replace DELL Laptop Keyboard Key
Sometimes with Dell laptops, the keys on the keyboard gets stuck or damaged or fells off the keyboard. There are many different ways to repair your broken keys. Just put your mind to it and you will be able to repair it yourself.
You can place an order to replace your broken key or you can repair it you have all the parts intact.
You should have a key cap, 2 or more retainer clips (plastic pieces), which goes under the key cap.
Following is the installation guide to replace and repair Dell laptop key.
To install your key on your laptop keyboard, start out by observing your metal plates on the keyboard.
Always be sure to look at the metal keys because they differ in every keyboard.The larger metal hooks can be at the top, bottom, right or left side. The position of the metal hooks determines the position of plastic pieces.
Here you can see that it has one large metal hook at the top and two metal hooks at the bottom.
Take the larger plastic piece and observe that it has two larger sticks at the bottom, two holes at the middle and two shorter sticks at the top. The bottom sticks are going to go into the bottom metal hooks. The smooth part faces away from the keyboard.
Take the smaller plastic piece and observe that it has a small bar at the bottom, two sticks at the top and two sticks at the middle. The sticks in the middle are going to go into the middle holes of the larger piece and the bar is going to click on to the top metal hook. The smooth part faces away from the keyboard.
Place the smaller piece on the larger piece and insert its sticks to the holes of larger piece.
Push it evenly to insert completely. Get a thin object or blade and stretch the plastic pieces upwards so that it clicks together.
Take your letter key, put it in the middle and push down evenly from all four sides.
You’ve just repaired your Dell laptop keyboard.
Source: LaptopKey
on Dec 16, 2009 | Computers & Internet
My p990i phone the fip is broken and it is remained as if the flip is closed and i cannot use the other functions.......how can i flip open if the flip is broken.....
You need to dismantle the back panel and unscrewing 6 screw using a T6 precision screw driver to be able to release the front panel,but be careful cause the keypad flex connector is attach on the board interface and be careful cause touchscreen and LCD is also connected. On the upper panel,remove the keypad panel by inserting a flat screw driver on each side at the bottom of the front panel.if done,remove the adhesive at the back of the keypad interface and you will see the keypad flex connector,if the parts is still ok,gently remove the flex cause it is fitted by a strong adhesive.the you can replace or if not put an adhesive on a broken part.
good luck....
Jun 20, 2011 | Sony Ericsson P990i Cell Phone
The memory stick pcb has fractured into two pieces
The cruzer does not need the case to work, just be careful how u handle it connect to your computer and get your data. hope this helps
Jun 13, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Web cam has a red tint and grid lines.
if it is borken try to stick it with feviquick tightly other wise purchase a new onel
Jan 11, 2010 | Creative Labs WebCam Live!
My p990i touchscreen is not responding
my touchscreen is not working what should i do?
Oct 30, 2009 | Sony Ericsson P990i Cellular Phone
Reg Touchscreen
first of all calibrate ur touch
then if not works
please change ur touch pad
Sep 20, 2007 | Sony Ericsson Bluetooth handset pink...
Sony Ericsson P990i Cellular Phone Logo
202 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
