2wire Router
Problem for 2wire (1000-400108-001) Router
2wire Wireless router not working w/Comcast cable modem
By PFSLeader on Feb 03, 2008
I can get connected to the internet just fine with the ethernet connection to my laptop, but when I connect the ethernet cable to the back of the 2wire the middle light turns red because of no broadband link. My computer finds the wireless network just find, but there no internet conection. I am doing something wrong?
Clarification Request
Posted by donc81 on Feb 06, 2008
i have cable internet. It works ok with the ethernet cable to the laptop but i want it to work with the wireless router!
The router is a 2wire..... when i connect it up, the green lights flash and then the dsl light flashes green, then red a few times alternately.
What is the prob and how do i sort it out?
thanx
Posted by russ1eftel on Feb 03, 2008
how is your network setup?
whats connected to what?
Same Problem
Mar 31, 2009
-   this sucks -   Guest
Mar 30, 2009
-   my 2 wire router broadband link light doesnt not stop blinking and my internet isnt working -   Guest
Feb 26, 2009
-   Need to use ATT wireless router with Comcast cable internet-   Guest
Feb 13, 2009
-   i used to have att internet connection. but now i am crossing over to comcast cable internet which is not wired.
1) can i use the att's wire2 wireless modem to make the comcast connection wireless? 2) how? 3) any other solution to make comcast cable wireless
-   Guest
Dec 21, 2008
-   I have the same problem... I am trying to use 2wire router on comcast connection-   immadmohsin
Solution #1
posted on Feb 06, 2008
Somewhat Helpful)
mansnes
Rank: Wiz
Rating: 85%, 65 votes
You may need a crossover cable between the router and your laptop.
Comments:
Feb 06, 2008
- For donc81 - do you have cable internet or DSL? You should only need one or the other. You should have a DSL modem OR a cable modem, but not both.
If it is DSL, which is carried over your existing phone line, you should connect the DSL modem to the phone line with a regular phone cord. After connecting the DSL modem to your phone line, connect your computer to the DSL modem via the Ethernet cable - bypassing the wireless router just to test the Internet connection. Are you able to connect to the Internet? If so, then the problem lies with the configuration of the wireless router, if not, then there's a problem with your DSL connection.
Was this helpful?
Yes
No
Solution #2
posted on Jul 16, 2009
Very Helpful)
davismymiss
Rank: Guide
Rating: 92%, 3 votes
Forget about chaining the att modem to the cable modem. If you want wireless than just go on Craigs List and purchase one router for like 30 bucks and call it a day. Lets put it this way...I JUST got comcast after ATT wireless. I have two pc's in my home but my modem from comcast only has one port for an ethernett cable. It's sadly obvious that I have to throw a router in the loop just to get my other rig online :(
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #3
posted on May 06, 2009
Very Helpful)
Jaycifer
Rank: Guide
Rating: 98%, 5 votes
Its almost impossible to connect a 2wire DSL router with a Cable modem. They dont go hand in hand.
Although you can connect the outgoing ethernet wire from the modem in the last ethernet plug on the back of the router and then have the ethernet connections coming from the router. But not wireless. and if you find a way, contact me at jneal2k9@hotmail.com
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #4
posted on May 14, 2009
Somewhat Helpful)
halfbreed13
Rank: Apprentice
Rating: 75%, 1 votes
I have done cable to 2wire dsl modem then to wireless but only with a MSI US-54G Wireless stick. I have been trying to get my laptop to connect but cannot get it, pisses me off been at it for 4 days.
Was this helpful?
Yes
No
Solution #5
posted on Nov 07, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
kjgvjhbb
Popular Solutions for 2wire Router
Questions and Unsolved Problems for 2wire Router
Do you recommend 2wire (1000-400108-001) Router?
Answer
Answer
I have a dovetail jig but dont know how to use it
Answer
My 2wire modem keeps saying cannot find an ATM thing and no matter what I do it will not conect to... (More)
Answer
how to get chatspace workin on a netgear 2wire router
Answer
no power to router even after unplugging and resetting.....light is red
24 Other Users Have The Same Problem - Continued
Comment by bosulli5, posted on Nov 13, 2008
trying to plug my ethernet cord into a 2wire router to create a wireless network. it won't work!
Comment by keriedge, posted on Nov 08, 2008
I can connect to my other 2 computers thru the 2wire router but I don't have wireless access. I have or had before switching to cable internet, 3 computers networked. 2 wired and one laptop wireless.
Comment by Guest, posted on Nov 02, 2008
all of a sudden my laptops and my wii did not get internet
Comment by hydotek, posted on Oct 28, 2008
we have a hardwired network as well as a wireless network, but each time i detect the wireless, and i connect to it , ti tells me to put in a paraphrase/password which i do, but i still says connected with limited access. what do i do with the router. the dsl link light is on but red. other lights blinking green, it just does not connect to the internet. how do i reset the password on the 2wire router?
Comment by Guest, posted on Oct 15, 2008
same problem
Comment by mothzombie, posted on Sep 18, 2008
just had comcast installed, and now the two lights on my 2wire router (At&T) are flashing Red (DSL and Internet) However, my network shows up in the wireless networks, but I can't browse or anything on the net.
Comment by vadalap, posted on Aug 24, 2008
How to connect 2wire wireless router (AT&T Modem) to Timewarner modem.
Comment by Guest, posted on Jul 16, 2008
broadband link light is steady red all other lights are green no internet connection
Comment by 1706, posted on Jun 27, 2008
I have 2wire dsl/wireless modem, I have switched to time warner camble for my internet. I can't connect cable modem and to my 2wire/dsl router.
any advice?
Comment by Guest, posted on Jun 20, 2008
Same problem ,different (netgear) router
Comment by Guest, posted on Jun 12, 2008
I'm having the same problems, I have no connection on computer or laptops
Comment by onerace, posted on Jun 05, 2008
red light shows up on broadband link
Comment by Guest, posted on Jun 05, 2008
the red light shows up on the broadband link
Comment by lost2wire, posted on May 21, 2008
I have the same problem. Anybody knows how to configure the 2wire dsl router to make it work ?
Comment by thania, posted on May 18, 2008
I just have problem with cable connection between 2wire modem and PC, but the wireless still working fine. It working with cables and wireless before, anyone know what going on, let me know thanks.
Comment by Guest, posted on Apr 16, 2008
How can the 2wire wireless router be configured to work with the cable modem? I have the exact same problem as the others. The internet directly to the computer works fine but when the ethernet cable is plugged into the 2wire it says it can't find the broadband connection.
Comment by Jen P, posted on Mar 24, 2008
I am having the same problem. In response to the answer posted below, I have a cable connection and am attempting to connect my existing cable modem (which does not have a wireless router) to a 2wire DSL router. Although my laptop finds the connection, I cannot connect to the Internet and keep receiving a "DSL Failed to Connect" error.
Comment by federriko, posted on Feb 28, 2008
can't connect to the internet on my macbook via 2wire router
Comment by donc81, posted on Feb 04, 2008
my 2wire router wont connect me to the internet. The ethernet cable into my laptop is working but once i setup the router it wont work. . the dsl light flashing green twice and then red quite fast.
I have the ethernet cable from the cable modem into the router and the phone line from the router into the phone line..... y wont it work? please help!
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For 2wire Router:
Top Router Experts
Rank: Guru Guru
Solutions: 3597
Experience: Semi retired, was network administrator, proficient with hardware, software, networks, CAD systems
Ask Me
Find more Router Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
