Dear Tori, Greetings from New Zealand! You have not supplied much info - so we'll start from the beginning...SAFELY Remove web-cam connection - (I presume it is a USB connection?) - by R-clicking on the little icon - usally green - in the systray by the clock, & following instructions. Have you installed the web-cam "driver" software from the cd that came with the web-cam? If not then do so. Plug in web-cam USB & wait until pop-ups notify you that web-cam device is detected & ready to use. L-Click on "START" > All Programs > Web-cam program. If this option does not work/is not available, then OPEN "My Computer" & click on web-cam icon. This should start web-cam software & you SHOULD see your smiling face on screen! If Nothing works - then you will have to make a note of the model & contact Gateway for support. I hope that this helps! GBU! - Bruce.
you should be able to go through the card manufacturer and get "recovery software" that will help you get the pictures back off the card. It is likely that the card has gone bad.
1**. Double click my computer then double click USB Video Device. You can see your self then. If the USB Video Device not showing there then you have to install the cam first.
2. Power On the laptop/PC & after ready your OS for work just put your Webcam driverdiskin DVD/CD RW/ROM. when its open, that time just select webcam driver and install it as per your operating
system(Vista or XP). So do it, and after finish installation ,restart the laptop. Your will see your cam is ready for use.Then follow again the first instruction.**
3. When you confirm after viewing your self in cam , then stop it. Now login on messenger & click to connect the cam from messenger. If any doubt then then ask me a again. Thanks & waiting for your feed back.
your cam come's with data cord or USB BUS hub drive which can be easily connected to an y pc or note book pc or laptop but first see that you install the driver & software on your system for proper working or function of cam on the PC or Laptop after installing connect the cam to USB cable then it will automatically show each & every content on your PC or Laptop & their is the option of deleting every thing you need to erase so till then see your hope that it help you out ......!
1. Go to: http://www.intextechnologies.com/webpages/download-driver.aspx 2. Under the "Download Drivers" section, click "PC Web Cam". 3. Find & click your web cam's model. 4. Click "Win XP/Vista". This will start the download of your web cam's drivers.
try to relocate your cam away from monitor, speakers or from pc. there maybe interference coming from these units. you may also try moving the cam cable and check for loose or intermittent connections. try removing/ reinserting the cable several times, this will gonna clean the pc to cam contacts
