Question about Panasonic KX-T7730 Corded Phone
Cacelling forward Dear Sir/Madam Could you please advice me, how i can cancel forwarding on KX-T7730. For your information i have forwarded the incoming calls to an extension but now i want to cancel it but i don't know how. Please advice Thanks
    Novelist:
  • 106 Answers
To remove forwarding, lift your handset, push the FWD/DND key and dial 0. Here is the quick manual for that model - http://service.us.panasonic.com/OPERMANPDF/KXT7720.PDF
Posted on Feb 04, 2008
  • irivera74 Jun 03, 2011
    Same Problem but on a KX-TS500W model ...can u help?
Want to know how we can divert our Panasonic KX-T7730 to a mobile number
What you want to do is to activate the call forwarding feature offered by your phone company. Different phone companies have different procedures. With many companies you dial *72 then at the second dial tone dial the number to forward to. This number has to answer the call to activate call forwarding.For precise instructions please contact your telephone company.
Apr 25, 2012 | Panasonic KX-T7730 Corded Phone
How to cancel dnd cancel
The Panasonic 77xx series phones was first delivered with the TA series systems, but the phone is both forward and backward compatible with 7 different prefix phone systems and about 18 different models.
In a TA series, from the intercom, press FWD and dial 0#. It will turn BOTH Forward and Do Not Disturb off, so if you are forwarding calls to VM, you'll have to reset it.
Carl
Jul 04, 2011 | Panasonic KX-T7730 Corded Phone
How to remove FWD/DND FROM A PANASONIC KX-T7030X PHONE
Press intercom button
dial *71
choose the call forwarding type to cancel as follows
dial 0 for internal and external calls
dial 1 for external calls only
dial 2 for internal calls only
dial 0 to cancel call forwarding
press speaker to end
Jan 18, 2011 | Panasonic KX-T7730 Corded Phone
Respected Sir/ Madam, Kindly help me. we are using Panasonic KX-T7730. I need to divert call for my mobile. how i can do this. i need this help badly. Thank You . Best Regards, Kiftheen.
you will need to dial *7102 9 phone number #
this will forward all your calls
external call forwarding needs to be enabled on your system and you really need ISDN lines
To forward calls ringing a group of phones - from a phone within the group dial
*7141 +group number - 9+phone number #
to cancel this dial *7141 +group number
Nov 13, 2010 | Panasonic KX-T7730 Corded Phone
I have a Panasonic KX-T2355 telephone. How do I cancel call-forwarding?
Since the phone is just an instrument, you'd cancel CF the same as you would do if you had a 2500 plain phone on the line. Try 73# or *73 or consult with the dial tone provider for Call Forward Cancel instructions.
Carl
Oct 01, 2010 | Panasonic KX-T7730 Corded Phone
How do I program the phone to ring on an incoming call? The ringer is on.
The solution will depend on why the phone is not ringing. Do you have a good cable? (Can you get a dial tone and make outgoing phone calls?) If you don't have a dial tone, use another phone to check if the phone is the problem or if the jack is at fault.
Next is the phone forwarding calls or in the "do not disturb" mode.
If the problem is one of the above, which model of the Main Unit do you have, KX-TA624 or KX-TA1232?
If the unit is in the "do not disturb" mode, to cancel: pick up the handset, press Program then 0 followed by # with the TA624. For the other model, press Program followed by 0 . Then hang up the handset. For this the manual says press the FWD/DND button not the Program button. I'd check both.
To cancel Forwarding, except for Follow Me Forwarding, pick up the handset, press FWD/DND and then 0 and # (TA624) or 0 (TA1232) then hang up the handset. To cancel Follow Me Forwarding: pick up the handset, press FWD/DND then 8 followed by the extension number. Then press # for the TA624 and hang up; just hang up the handset for the TA-1232.
I hope this helps.
Sep 23, 2010 | Panasonic KX-T7730 Corded Phone
Call forwarding
Lift the handset, press the FWD/DND button, dial 2 and the extension you want your calls to forward to, you should get a comformation tone, hang up the handset.
Cancel the fordwarding by lifting the handset, press the FWD/DND button, dial 0 , get tone, hang up.
Good Luck
Jul 30, 2008 | Panasonic KX-T7730 Corded Phone
CALL FORWARD
hi prabipm,
just follow this instruction.
1.lift hand set or press sp-phone
2.press fwd/dnd botton
3.press 0 and # sign
hope this help...
Jul 23, 2008 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7730 does this phone have answer machine?
try using the call forwarding feature, you can forward it to your cellphone.
Jul 03, 2008 | Panasonic KX-T7730 Corded Phone
Forwarding a call
Lift handset, dial 3 or 6 ( depending on model) - key outside line access code - key phone number (eg mobile)- key # - hang up
Dec 18, 2007 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7730 Corded Phone Logo
760 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
