Remote Controls
Problem for Remote Controls
Generic problem for all Remote Controls
Gfm remote code
By neesea on Feb 03, 2008
I need the remote code for my Comcast remote. I purchased a 20" gfm lcd digital tv.
Thanks,
Neesea
Same Problem
Jan 08, 2009
-   I will never buy this brand of TV again. You cannot use any other remote with this TV and have full functionality except for the OEM replacement which is 30 bucks. Too much for the amount I paid for this TV. I will just go and buy a new one from another company.
Customer service doesn't even offer to replace. They send you right to Remotes.com to purchase a new remote.
I am upset because I cannot use my cable remote now and without the OEM I cannot access the AUX channels, so it is only good for hooking up to an old VCR.
-   Guest
Oct 10, 2008
-   I have a GFM TV , I have Dish TV, anyone know of any codes that will work for my remote?
I have tried Funai, Goldstar, I even contacted a dish rep, still no luck.
any help?
-   Guest
Sep 29, 2008
-   i need the code for gfm for the comcast remote-   steveellenbu
Aug 26, 2008
-   I have the same problem with my 15" GFM,
one person said to try the codes for Funai, I tried those also, those codes did not work either
we need help
G-------   tenbrink2
Aug 05, 2008
-   Some one help us -   Guest
Best Solution
posted on Oct 05, 2008
Helpful)
kristiev
Rank: Apprentice
Rating: 91%, 6 votes
I have a 26" GFM DVD/TV combo (v7tvdvd26) and used the LG codes listed for my cable box remote. I went through about 3 LG codes until I found one that works.
I've also read that Goldstar and Funai codes might work with GFM.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Oct 28, 2008
Helpful)
Guest
Rank: Apprentice  Televisions & Videos  Expert
Rating: 0%, 0 votes
after much research looking for codes and remotes to my daughters gfm tv, i have found that there are no codes. u can buy replacement remotes at remotes.com aka 1800remotes. they are a little pricey, but nothin u can do if the company does not want to help. if u can get the company to help it takes about 6-8 weeks just for them to get them from china then they ship it to u so could be 12 weeks all together. gfm sucks!!!!!!!!!!!!!!!!!
Solution #3
posted on Aug 05, 2009
Very Helpful)
htimsnitsirk
Rank: Apprentice
Rating: 100%, 2 votes
11963 worked for my GFM with Comcast univeral remote
Was this helpful?
Yes
No
Solution #4
posted on Dec 11, 2008
Somewhat Helpful)
riccola
Rank: Apprentice
Rating: 75%, 2 votes
call the gfm customer support line at 866-845-9436
Was this helpful?
Yes
No
Solution #5
posted on Nov 03, 2008
Somewhat Helpful)
patru1ka
Rank: Apprentice
Rating: 75%, 1 votes
I have recently had the same problem. I found GFM's 800 number and decided to call them to see if they could help. What I found out is that there 24 support is only open from 8am to 8pm est. I'm beginning to wonder if this was a bad investment
Was this helpful?
Yes
No
Solution #6
posted on Dec 14, 2009
Not Rated)
Noobius
Rank: Apprentice
Rating: 100%, 1 votes
Okay, Here it goes again, for a three digit code for a gfm sdtv is 520, the four digit code, is 0171. these are both listed under sylvania, so try sylvania codes. The last code works on a comcast remote.
Was this helpful?
Yes
No
Solution #7
posted on Nov 08, 2009
Not Rated)
iszabella
Rank: Apprentice
Rating: 0%, 0 votes
where can i get the codes for a gfm universal remote
Was this helpful?
Yes
No
Solution #8
posted on Apr 07, 2009
Not Rated)
sherrygarcia
Rank: Apprentice
Rating: 0%, 0 votes
If you have Time Warner Cable you can follow these steps with your TWC remote.
To Search for Codes
If none of the codes listed for your device work,
you can search through the code library for a valid
code. The remote automatically selects the proper
code.
1. Turn on the device.
2. Press and hold the SELECT key and the
appropriate mode key (AUX, VCR, TV, or
CBL) until the mode keys blink twice. For
example, to search for a TV code, press and
hold SELECT and TV.
3. Using the remote control keypad, press 9 9 1.
The mode keys blink twice.
Note:Be careful not to press these keys too
quickly. As you press each digit, the mode
key should blink.
4. Point the remote toward the device, and press
The remote automatically tests each code in
its library, beginning with the most common
codes. The mode key blinks once each time
the remote transmits a new code.
Note: Each of the code libraries contains
fewer than 100 codes. The mode key blinks
twice when it reaches the last code in the
library.
5. As soon as the device powers down, press
the SELECT key.
6. Verify that the new code is correct by
pressing the Power key.
7. Did the device power on again?
• If no, go back and repeat step 4.
• If yes, press SELECT to lock the code.
To Identify Programmed Codes
You can find out which code you used to program
your device by following this procedure.
1. Press and hold the SELECT key and the
2. Using the remote control keypad, press 9 9 0.
key should blink.
3. Press 1; then, count the number of times the
mode key blinks. That number indicates the
first digit in the code. For example, 4 blinks
indicates the first digit in the code is 4. If the
mode key does not blink, the digit is 0.
Comments:
Apr 07, 2009
- I did not know how to add on 4 to point the remote towards the device and press play
Was this helpful?
Yes
No
Solution #9
posted on Feb 22, 2009
Not Rated)
kittyocat
Rank: Apprentice
Rating: 0%, 0 votes
0189
Was this helpful?
Yes
No
Solution #10
posted on Jan 26, 2009
Not Rated)
topidea
Rank: Apprentice
Rating: 0%, 0 votes
Logitech
Comments:
Jan 26, 2009
- Logitech Harmony 520 Universal Remote had no trouble finding my GFM 26" HDTV model VO7LCD26. This is a pricey solution at about $100 at Meijer but I had tried an RCA UR, "guaranteed to work on any set" and even a GFM brand UR !
The Logitech 520 programs thru your computer, using dvd software & a USB cable (both included) and so takes some time to set up. But it works!
Comcast was no help at all. Meijer said Sylvania, Symphonic, Emerson or Funai codes might work...not for me! They sent me this photo of the ONE GFM set for which no code exists: 01232009178.jpg
Was this helpful?
Yes
No
Popular Solutions for Remote Controls
Questions and Unsolved Problems for Remote Controls
Answer
hi i need a controller for a koss ipod deck model ksspi3300-4 do you have?
Answer
Need a remote controller for model Nec N-1416
Answer
broken my sanyo remote control, and i bought a new universal remote and it dont work. how do i find... (More)
Answer
living solutions giant remote needs code for sanyo tv
Answer
i have urc4640 remote need code for emerson dvd/vcr
8 Other Users Have The Same Problem - Continued
Comment by kramey311, posted on Jul 26, 2008
need remote code for GFM 36" LCD
Comment by dvy11220, posted on Jul 04, 2008
I need the code for my GFM digital flat screen TV in order to use my Time Warner cable remote. They don't have it and I can't seem to find it anywhere.
Thanks,
Comment by crownsbroyal, posted on Apr 09, 2008
I'm also looking for a code for that remote. I would like to try and use my Panasonic home theater remote instead of the one that came with the TV. I can't seem to find the code anywhere, it is not listed anywhere I can find.
Describe your Remote Controls problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Remote Control Experts
Top Audio & Video Equipment Repairmen
in Baltimore, MD
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
