Question about HP Compaq FS7600 17" CRT Monitor
Problem with monitor
My CRT monitor's display is curved in on the sides, and the menu options for correcting this are not responding. Furthermore, the width of my display is too wide, and that menu option is not responding as well. Other menu options are working, however.
Anybody have any ideas on what the cause of this problem is and how I may be able to fix it?
    Brigadier General:
  • 6,966 Answers
Your post/description indicates a "pincushion" problem; the width problem is as you have stated.
There are two (2) possible reason for these problems:
1. component failure in the horizontal section of the monitor. These components could either be a diode, a capacitor or a resistor. In some cases there are trimpots in the PCB that can be adjusted to correct these problems;
2. component/connection failure in the controller section.
Of the two, I tend to suspect #1 as highly likely the case. Repairs such as this would require that you be familiar and comfortable working with electronic components and circuitry, the use of a DVM and a soldering iron. Should this be not to your liking, your next best bet would be to seek the services of a qualified professional.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Feb 03, 2008
  • Louie  Role
    Louie Role Feb 04, 2008
    Hi again,
    Glad to be of some assistance and appreciate the rating.
    Cheers.
I hv lg 700s studioworks crt monitor... i hv set a resolution of 1280*1024, but now m not able to control some of its functions like its width size...width has gone out of the monitor, it isnt getting
Hello
Select reset option by monitor menu, set it to default first. Then try to adjust the width and height of the screen. If this does not help you, try other resolutions set by the system.
Nov 26, 2011 | LG Studioworks 700S 17" CRT Monitor
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
The view on my monitor is very truncated - about two inches top and bottom are not filled
Press the MENU button on the monitor and adjust the width and height of the picture to full screen.
Oct 10, 2009 | LG Computers & Internet
Samsung CRT monitor Horizontal width control
unfortunately there is really no way to fix that what happened is that the crt is no longer responding to the menu best bet would to purchase another one.
Feb 12, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Vertical pinch on left hand side of crt
You mean the picture on the left side is curved out? Or is it restricted to the very top and very bottom?
If you have the curve problem, look in the menu and see if there is a pincushion control and a pin cushion balance. Adjust the balance until both sides curve the same, then adjust the pin cushion control to remove the curve.
If you are only having the problem in the corners, look in the menu for a corner correction control and play around with it to see if it corrects your problem. If the monitor has no OSD (on-screen-display), then it may be too old to have these controls. You may have to open the unit and see if there are any physical adjustments (little potientiometers). You might want to leave this to someone who knows what they are doing since the high voltage circuit can have 25-35 kV. Considering the price of CRT monitors, you might be able to find a new one for under $50.
Jan 22, 2009 | NEC MultiSync XV17 17" CRT Monitor
Less H-width for higher resolutions
this is not the electronic problem, this monitor is made to support such (800x600) resolution.
Dec 17, 2008 | Compaq 7500 17" CRT Monitor
IBM E54 CRT Monitor - Exceeds the Display Width
1. first replaced the TIP 122 fet. back side of lot.
2. change the 424j / 1600v pf.
3. IRF 630 ( after power output section )
Nov 17, 2008 | IBM E54 15" CRT Monitor
Screen is distorted
hi there, Below the monitor, on the center are option button, you can explore that in adjusting your screen display. You can widen the display, or tweak it depending on the angle that you need to. Just press the center button and choose from the menu.
Oct 25, 2008 | Dell E771p 17" CRT Monitor
Monitor width distorted
Components in the deflection circuit CHECK those.
Jul 08, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Problem with Studioworks 563 monitor
LG Studioworks 563N Monitor horizontal width is exceeding out of screen and not able to adjust it along with pincushion through menu. IRF S630A Transistor replaced, no effect. Pl. help.
Nov 18, 2007 | LG Studioworks 563N 15" CRT Monitor
HP Compaq FS7600 17" CRT Monitor Logo
91 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
