Question about Jl Audio 500/1 Car Audio Amplifier
500/1 v2 and one kicker VS12L7
I JUST BOUGHT A 2ohm KICKER VS12L7 WITH A SOLO-BARIC SUBWOOFER ENCLOSURE....SINCE ITS A 2ohm SUB WOULD IT WORK OKAY WITH A JL AUDIO 500/1 V2 AMP OR SHOULD I HAVE BOUGHT THE 4ohm INSTEAD?
  • labitomaximu Feb 18, 2009
    settings for jl audiio 500/1? with kicker L7
    Problem Solver:
  • 6 Answers
It will work fine. This amp is stable to 1.5 Ohms, but is designed to put out about the same amount of power at 2 or 4 Ohms (unique).
Posted on Feb 12, 2008
Cant get the bass i want.
Try checking the specs on the amp. It might not be able to drive a 2ohm load. just a suggestion.
Mar 31, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Only one voice coil is working on my L7 10" sub? All connections look good. 2 2ohm subs wired to 2ohms with a Kicker zx1000.1 mono amp. why?
If the tinsil wires all look good then chances are you broke a lead in the coil, the only way I know of to fix this is to order new voice coils and a new spider and replace them..
There are places on the web to order parts, you just need to take good measurments of the parts and relay them to the stores.
Nov 19, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
How do i wire my solo-baric L7 12"
how should i wire my s12 L7 2 ohm dual voice coil to my JL 500/1 amp
Sep 15, 2009 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
I have my l7 solo baric on series mode they sund
Hello rigo11785,
The MTX Thunder 1501D is stable at 1ohm and outputs 1,500 watts RMS into that impedance. An L7 with 2ohm DVC's would present a 1ohm load if wired in parallel and would allow the amp to produce more power than into the 4ohm series load. The problem is that the L7's maximum power handling rating is only 1,000 watts RMS, so if you wire the coils in parallel, you'll very likely overdrive the sub and perhaps damage it. Now, if you bought another L7 and ran the voice coils in series and the subs in parallel, that would be a 2ohm load and well within their power handling capability.
With that amp and sub, I'd recommend leaving the voice coils in series.
Hope this helps.
Jul 28, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Wire my kicker
This will help you :)
Below is a link to the subwoofers manual where is clearly states how to wire it all up, it includes both the 2ohm DVC and 4 ohm DVC models.
Click Here for the L7 Solo Baric Manual
Jan 23, 2009 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Solo x 10 dual 2 ohm smells burnt and smoke
there is no such speaker as a solo-X L5.
The Solobaric L5 is 450Watts RMS and 900 Peak.
Check your documentation, and no warranty except Massive Audio covers Burned Voicecoils as it is deemed customer abuse.
If it is a typo, and not an L5, your combination (as long as each is level matched) should be ok to run on that sub. When wiring it as you describe, the two amplifiers need to be identically matched in order for both coils to play at the same level.
Seek professional installations so your warranty is intact.
Dec 21, 2008 | Kicker Solo-Baric L5 Car Subwoofer
SOLO BARIC L7 15 SUB
no as the the voice coil has been burnt out there is no way u can repair them. didnt you test the subs out before you bought them? remember if u buy used den allways check em out!
Jul 12, 2008 | Kicker Solo-Baric L5 Car Subwoofer
Wiring my kicker solo-baric 15's
The best you can do is connect the dual 2 ohm voice coils of each respective sub in series (4 ohms total per sub) and then connect each sub to one channel of the amp. This will give each sub 1000W, which is the rated maximum from Kicker.
Mar 13, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Jl Audio 500/1 Car Audio Amplifier Logo
202 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
hoyzee1
Morne Olivier
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
