Question about Gateway Media Center 610XL PC Desktop
Video does not work
I have seen a lot of people who have issues with the power supply for this unit. My power supply works great, however, I get NO video whatsoever. I have tried re-installing the video drivers, using Gateway's Driver Update Utility (which did update the drivers, but did not give me video). I have ran the computer into a monitor so that I could use it and the sound will still play out of the speakers that are attached to the Gateway. At first the video was flickering off and on pretty frequently but now when I turn it on the screen is black and I can't get any type of picture of out of it. I have ran spyware and virus protection and that did not help. Any ideas? Thank you for the help.
  • sethmiller82 Feb 03, 2008
    Let me further describe the situation:
    I can run the computer in Safe Mode and when I boot it up windows will start normally. It will display in safe mode. It seems that the only time that it starts to flicker is whenever I use windows to open a file, click the start button, open a folder on the desktop, etc. Meaning that it will display Windows in Safe Mode all day long as long as I am not running any apps or opening anything. When I restarted Windows after running it in safe mode it attempted to display reguarly, and for a few seconds was actually displaying. Then it went back to the same symptoms I was experiencing before, and then completely cut out again within about two minutes.
  • SPIKEONBASS May 06, 2008
Posted on May 06, 2008
  • 1,554 Answers
It sounds like the Lcd inverter board is bad in the monitor
as you turn on the computer if you see no video at all and the screen stays black all the time then the inverter or the power to the inverter is bad.
you need to have the lcd monitor checked out.
the flickering off and on is the usual symptom for this.
Posted on Feb 03, 2008
  • Karl Whisenand
    Karl Whisenand Feb 03, 2008
    so it runs in safe 800x600 60 hz mode but still crashes when you load the video with any info.
    I would assume then that it may just be the driver ,
    Go the the ATI site and get the ati uninstall driver
    run it in same mode and remove the drivers. reboot.
    reinstall the ati drivers and see what happens.
Polaroid TDAC-02212 will not turn on. The red light is on and turns to blue momentarily when the power button is pushed. The screen will flash a little then back to off, with the red stand by light.
It may fix it with a new power supply but personally I'd recycle it...that wasn't a good set when it was new, lots of issues, Ive personally never seen a good Polaroid TV, they should have stuck to cameras as they were great back in the day.
Dec 10, 2017 | Polaroid Televison & Video
Tv turns on but no picture or sound, power light blinking
How many blinks does the light do? Or is it constant?
Jun 16, 2007 | Toshiba 27DF46 27" TV
My element tv has no picture. (it can be seen with flashlight test) will a power supply repair kit fix this issue?
This is usually not the power board. the LED strips fail and you have 55 LED bulbs in the back light. It is not an easy fix because the display is glued to the bezel and if you don't take extreme care when working on it, you crack the LCD display.
Jan 19, 2017 | Element Televison & Video
I boot up my Sytab10st tablet and "infotmic" comes on the screen then shuts down. How can I fix it.
Sylvania Systab10st Tablet:
So I see A LOT of people have posted about this issue of the INFOMTIC splash screen appears and then powers off and yet I have not seen one viable answer except "Hold the power button/Volume..." I have done this and to no avail. Is there anything else I can try before I use it as a rectangular frisbee?
I have tried holding the power with the volume up
holding the power with the volume down
Holding the power continuously
Running the battery completely out and then recharging
I don't know what happened to this thing. It worked fairly well then one day it just won't load the Android screen.
Any help will be greatly appreciated!
Oct 03, 2013 | Sylvania Sytab10st 10-inch Tablet Black
This is the strangest thing I've ever seen. I have a Gateway FPD1975W TFT Monitor and its always worked great. The other day it went into a sleep mode via windows, and now it wont boot up the input...
Your monitor problem is causes by the power supply. What is happening is the power supply voltages are not stable, just enough to power the unit up. When you connect it to a video signal the power demands slightly increase and the power supply can't handle it. This is a very common problem with LCD after a few years of use. The issue with the power supply is the capacitors have started to fail. These parts are used to filter the output voltage and when they start to fail the outputs start rippling hence the problem you are having. Here is a link to a repair article that shows how to repair the Gateway FPD1975W monitor.
I hope this helps you get back going.
Sep 20, 2011 | Gateway FPD1975W 19" LCD Monitor
Power on/off not respond, what can i do ? my screen Samsung SyncMaster 920N
This may due to power supply is not connected properly or power supply itself gone bad. check and repair/replace the power supply may solve your problem.
Revert back for assistance.
Jan 20, 2010 | Samsung SyncMaster 920N 19" LCD Monitor
Power issues
I have had this problem myself for a while now. If I turn it off and on rapidly, it sometimes works after a short to long while. It tends to be accompanied by a buzzing or popping sound, like electricity arcing.
In researching, I have seen that it's likely a loose ground connection, should be fairly easy to solve... I hope.
Currently looking to see if there's a way I can get into it and do it myself.
Sep 30, 2008 | Polaroid TLA-01911C TV
Projector power supply
Hi there
Finding parts for this unit might take a while as DELL has left the Projector market.
Mar 31, 2008 | Dell 2300MP Multimedia Projector
Icant get my dreamcast to turn on.
Power supply issue. I see this a lot. Many times the pins where the power supply module connects to the main board get dirty and build oxide. You need to open your unit and take out your power supply unit and clean the pins. If that does not work, I can sell you a good DC power module to solve your problem.
Feb 27, 2008 | Nintendo Game Boy Advance Console
Unusable video signal
e-mail me or call me 520-248-4242 any time
Dec 11, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Gateway Media Center 610XL PC Desktop Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
