GE WHDVH626fWW Door Locked, but not
My 6 month old GE Adora washing machine's display states the door is locked, but the door is actually wide open. When I try to close the door and start a load, the door lock clicks a few times and nothing happens. I unplugged the washer for a few minutes, and now the display is blank and nothing happens. Any thoughts?
  • paghorashy Dec 28, 2008
    My problem is almost the same other than I can close the washer door and the waste pump comes on and will run for some time I have ran water into the wash tub and it will pump it out with no issue. It will stop pumping and then it will click 3 to 4 times I am not sure then it will stop and go to pause on the control pannel. with door locked indicator. I have unpluggend the machine with no reset. I have cheked the inlet and out let for pump and it is clear I cheked the large black in my case hose that comes off the wash basket it is clear no obstructions. My water supply is good . I ran it into a bucket. My thougt is that there is a master reset needed what is the series of buttons to push it my be a faulty acuator also. Thaks Pasha
Mine was doing the same thing. Upon closer investigation the drum seal was torn near the door locking mechanism, and when water got on the locking mechanism it shorted it out until it dryed. Then it would work again. You can check this by pulling the seal back on the locking side of the door to see if its torn.
Posted on Aug 04, 2009
    Genius:
  • 1,554 Answers
As most these washers use the same control board.
try some of the troubleshooting you see here :
http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
The main relay (black one on the right of board ) may be at fault in your issue.
these boards have bad solder joints in most all cases.
If its still in warranty it time to call them.
If you open it please post pics.
Posted on Feb 03, 2008
Ge adora WHDVH626FWW makes clunking noises when spinning, bearings seem ok
Could be a broken Hub Spoke, My Kenmore broke at the spokesand bearing e.of drum,
Sears replaced all parts as the were still uder warrenty. Less than 10 years old, would have been over $1,000 cost otherwis.
Sep 30, 2012 | GE Wh12x10309 Heater for Adora Front Load...
GE Adora door locked after power surge and can't get it to unlock and come on
You probably need to replace the door lock mechanism. Try unplugging it and then plug it back in. If that doesn't work, you probably need a repairman, or someone with more electronic feature knowledge.
Dec 24, 2009 | GE WSXH208A Front Load Washer
GE model WHDVH626FWW Front load washer won't run, can't open door
your drain pump is likely clogged,and is equipped with a clean out port. remove lower cover by 3 phillips screws on bottom front. you see the drain pump up front to the right. If there is a lot of water left in machine then have bucket/pan avail and plenty of towels. wet dry shop vac helps. you can open door and remove clothes from here. reach up on right side to where the latch is on inside (you have to go by feel) and find small round pull tab on bottom of latch/lock asm, and pull down, this will unlock door. carefull of water level when opening door.
to fix problem, unscrew cap on pump asm. water will pour out, and a tray will slide out with debris clogging pump. look inside housing for remaining ****. using finger check impeller area on right..
reassemble. machine should work perfect now. Pump is designed to be cleaned out and will not void warranty. newer machines have access port cut in panel for this clean out area.
Apr 26, 2009 | GE Washing Machines
Door wont lock
I solved my own problem...
The machine stopped due to either a heavy load or clogged drain. I cleaned the drain (by taking pannel off the front of the machine). Then, the machine wouldn't cycle and it said "door locked" but the door wasn't locked. Basically, you have to let the machine finish a complete cycle (whether or not it actually does anything). Every time the start/pause button flashes, push it to have the machine try to start. This will eat away at the time. Eventually it will finish the cycle and say 0:00. Now it should run. This can take up to 2 hours so be patient!
Mar 28, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Ge Adora front load washer not working
I don't know how you could have got it into diagnostics mode by accident - - but here's how it goes . Hit the power button until there is NO display . Unplug and wait a minimum of 30 seconds , plug back in and within 30 seconds hit SIGNAL button then DELAY START button then SIGNAL button again then DELAY START button again. door should lock and display t01 It is now in test mode . There are 14 different test it can run through in this mode , but all we are trying to do is check for error codes now and maybe get you back to normal, So turn the knob one click clockwise and hit the START/PAUSE button and see if any error codes come up. To exit the diagnostic mode - hit signal button then delay start button then signal button then delay start button and you are out of service test mode and back to normal
Sep 30, 2008 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Ge adora whdvh626fww not filling with water and locks door
Can you take a look at the pump to see check why it is able to pump-in water ? Motor is still good as you can hear it trying to pump-in water.
GE Energy Star WBVH5200 Front Load Washer
My GE Energy Star Front Load Washer is reading 5.9 instead of 59 minutes and not washing clothes. We cleaned the filter and still no luck. Please help.
Jul 30, 2008 | GE Energy Star WCVH6260F Front Load Washer
GE Energy Star WCVH6260F Front Load Washer: door locking problem
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Mar 12, 2008 | GE Energy Star WCVH6260F Front Load Washer
Display not lighting up
1/I suspect2 possible options ,the heat sink in door switch is failing to give 100 % contact any more giving a reduced power supply to circuitry - replace 2/ or power/start button fails to connect .remedy - replace switch , make sure power is turned off first or get service provider to replace it .
Jul 18, 2007 | GE Energy Star WCVH6260F Front Load Washer
Washing Machines Logo
568 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
