Question about Kenmore 46462 Front Load Washer
Kenmore 46462 powers off during spin cycle - no lights
If I hit "Drain and Spin" it seems to drain fine, but when it starts to spin, all the lights blink, then it powers off. Reducing/re-balancing the load doesn't seem to help.
  • erniez Feb 05, 2008
    This one was kind of obscure and hopefully, rare. I discovered that the
    wiring harness to the front control panel was not secured in the
    plastic clip. It had come loose and was resting against the interior
    frame that supports the drum. After a year and a half of use,
    eventually due to vibration, one of the wires had rubbed through the
    insulation, causing an intermittent short.
    Recommendations - first check the clean-out for the pump behind the
    bottom front panel. If that seems clean, take the top panel off off the
    washer and inspect all wires and connectors closely.
I cleaned out the pump under the front bottom panel
Posted on Apr 11, 2008
Kenmore HE2 flashing lights
did the technician point out wat needs to be repaired
Aug 24, 2008 | Kenmore 46462 Front Load Washer
I have a Kenmore HE3t washer than continues to stop during the cycle and flash the F2 error code even after cleaning out lines, hoses, trap, boot and replacing the drain pump.
It is possible that the brushes on the motor that spins the drum are worn down. The drum will start and stop when this happens. Check the brushes.
Nov 07, 2013 | Kenmore Washing Machines
Maytag Performa PAV920AWW makes squeeling sound when agitating/spinning. Water does not drain completely during spin.
Sounds like brake is partially engaged. There is s kit that may fix that. Part # 12002213.
Sep 19, 2017 | Washing Machines
Basket does not spin during rince cycle
does it drain/this will tell you if you did the lid switch correct-mike
Jul 17, 2009 | Kenmore 22422 Top Load Washer
The washer does not spin during washing cycle or drain & spin cyc
I can a very simple part called the motor can find the part at It costs 13.95. I am fixing my washing machine today, as this happened before and was the answer. Goodluck
Apr 11, 2009 | Kenmore 46462 Front Load Washer
Kenmore HE2plus wont spin...F-21 error
Apparantly the F21 error means there is a drain problem...I removed the drain hose from the output in the wall and held it down at ground level and let it drain into a pot...I ran the rinse, drain and spin cycle while I did this but before I hit the start button I hit the 2nd rinse button to turn off the rinse portion of the cycle. It seems to be draining fine now.
Jul 01, 2008 | Washing Machines
Kenmore HE2 Front Loading Washer
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Feb 24, 2008 | Kenmore 46462 Front Load Washer
Kenmore 46462 Front Load Washer Logo
91 people viewed this question
Sal De
 Brian Main
Brian Main
