Hp printer officejet 5510
Change my black cartridge all lifht on my printer are flashing error message reads print cartirdge error. I need to print this job for a meeting on tomorrow what can I do?
  • 4 Answers
To fix this problem, you need to go back to the store where you bought the new cartridge, they need to replace it. You have to make sure that you have the same label of the cartridge and have them test it if possible so you don't have to go back if needed.
Hope this helps!
Posted on Feb 03, 2008
HP OfficeJet 5510 All-in-One print slowly -
Hi
you need to replace your cartridges
one of it will stop printing and a message will come in
you monitor "cartridge error" and it must be replaced
In case I had help you pls vote me
Nov 06, 2010 | HP Officejet 5510 All-In-One Thermal...
I've tried trouble shooting "print cartridge error" plus print still in queue message. I've cleared both but messages still returns with copy, fax and scan lights blinking.I've tried the posted fixes but...
I had this exact error not to long ago. There was nothing in the book to help. I just finally changed my black ink cartridge. That stopped the error message.
So if you haven't tried that, put in new cartridges. Hope this helps.... :0)
Apr 26, 2009 | HP Officejet 5510 All-In-One Thermal...
I have a HP officejet 5510. I just put in a new HP cartridge
Like any other mass-produced parts, there will be some defective printer cartridges and it sounds like you have one. Since the first cartridge worked there's no reason to suspect a printer problem. I would suggest taking the cartridge back to the store where you purchased it and explain the situation. Since dud parts go back to the manufacturer, maybe they will exchange it for you as defective.
Apr 22, 2009 | HP Officejet 5610 All-In-One InkJet...
Hp officejet 6110
If machine does not print the colors it cannot align. Try changing the color and try again
Apr 03, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP Officejet 5510 error "Remove & check color cartridge
Re: OfficeJet 6310 Tricolor (93/95) Cartridge Stops Working After Replacing B/W (92) CartridgeOptions
04-26-201210:27 PM
1. Remove all cartridges and turn off printer
2. Unplug printer and wait one minute
3. hold down # and 9 while plugging power cord back in.
4. Wait a few seconds, then press the power button.
5. Display should read "Full Null Reset"
6 Only install color cartridge. Close cover
7. Wait for machine to ask for black cartridge, then open cover and install black cartridge.
8. Close cover
9. Alignment page should be printed automatically.
Mar 16, 2009 | HP Officejet 6310 All-In-One InkJet...
Printing message problems
its not an ink problem but a mechanism problem many things can lead to this: say bad film, week rollers and etc so loos the nprinter n make sure all the mechanism are in place.
May 15, 2008 | HP Officejet 5510 All-In-One Thermal...
HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
  5. Close the print-carriage access door.
Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Mar 18, 2008 | HP Officejet 5510 All-In-One Thermal...
130 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
