Question about Dell 2300MP Multimedia Projector
2300MP has a white vertical bar to the right
Been using the projector for a while, but it has just started to display a thick, flickering vertical bar to the right of the screen.
resync did not help
  • cmathew149 Feb 03, 2008
    I am so glad I did not see your response earlier :)
    I opened up the box, blew into it, and everything is back to normal. I think it is either dust or a loose connection somewhere
  • Anonymous Nov 29, 2008
    VERTICAL LNES WHITE
Eureka! I had the flickering band on my projection as well. Removed the lightbulb, sprayed some compressed air through the box. Problem Solved! Love simple fixes.
Posted on Nov 06, 2008
    Genius:
  • 3,587 Answers
Not a happy situation. sounds like video drivers are kaput, or the system files are corrupted. Other possible is the actual hardware is compromised.
Posted on Feb 03, 2008
  • Patrick Michaels
    Patrick Michaels Feb 03, 2008
    ahh..the old dust bugs again? you may want to keep this in mind for future, when considering the area around the projector. Those units inhale anything nearby, with that cooling approach, especially from bottom of unit.
Any advice on what board I should replace if the left half of the screen is no good, just showing white and black vertical bars? Right half is fine. Is the panel kaput?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 29, 2015 | Panasonic TH-37PH9UK 37" Plasma Display -...
Dell 2300mp
Replacing the lamp module requires special considerations:
  1. Turn off the projector.
  2. Wait 30 minutes for the projector to cool down and then unplug it.
  3. On the bottom of the projector, loosen the two screws on the lamp cover and then remove the cover.
  4. Loosen the two screws on the lamp module and pull out the module.
  5. Insert the new lamp module and tighten the two screws.
  6. Install the cover and tighten the two screws.
  7. Turn on the projector. If the lamp does not turn on after the warm-up period, try reinstalling the lamp again.
  8. Press enter on the projector or on the remote control to open the on-screen menu.
  9. Press the up (c00589410.gif ) or down (c00589411.gif ) arrow to select Setup and then press the right (c00589412.gif ) arrow.
  10. Press the up (c00589410.gif ) or down (c00589411.gif ) arrow to select Reset lamp hours and then press enter .
Jun 18, 2008 | Dell 2300MP Multimedia Projector
Dell 2300 MP Verticle lines distorted image
light engine or bulb is gettingbad ok how many hours on bulb fans clean ect thx nick
Feb 11, 2008 | Dell 2300MP Multimedia Projector
Vertical bar about 3/4" from top to bottom of monitor
panel is done. economical to repair. new panel is about 90 percent the cost of the tv new
Jun 03, 2009 | Fujitsu Plasmavision PDS-4233 42 in....
Dell 2300MP
resync button,i think,but seems too easy...
Apr 30, 2008 | Dell 2300MP Multimedia Projector
Dell 2300MP shows no connection after 15 min of work
that's a clear indication that you have a major heating issue inside the box..the internals are apparently overheating, as it will work after cooling down, right?
Mar 07, 2008 | Dell 2300MP Multimedia Projector
Large white vertical bar thru picture during projection
Two reset attempts to factory settings seems to have been the fix.
Feb 01, 2008 | Toshiba TDP-S8 Multimedia Projector
ViewSonic N1700w with Black stripe on right side of display
Sounds to me that you have a bad connection/wire to the CCFL bulb on that side of the display. Should be an easy fix, do it your selfer thing.
Dec 27, 2007 | ViewSonic NextVision N1700w (Black,...
Poor image being displayed
Hi guys
You will be looking at either repairing or replacing the Mainboard where all the colour processing is done.
Sep 27, 2007 | Dell 2300MP Multimedia Projector
Vertical line on optoma projector
I have the same problem. Read another blog and they suggested that the tilt of the color wheel could be a problem. I have not had the opportunity to test it, but it may be right as the last time it was used it was okay until the "picture" was elevated (read: the machine was tipped up further). This would be an easy fix if this is the answer... just wanted to pass it on...
Sep 26, 2007 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Dell 2300MP Multimedia Projector Logo
255 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
