Question about Cameras
Kodak Easy Share zoom digital camera
My camera doesn't start. I turned on --stays on for a few seconds flashing green and a few seconds flashing red and it goes off.
    Brigadier General:
  • 6,966 Answers
Most problems of this symptoms indicates either:
1. Weak battery; or
2. Internal fault (which can either be hardware or software).
Initially, pls try removing the batteries for an hour or so hopefully doing a reset and will work from thereon.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Feb 03, 2008
  • Louie  Role
    Louie Role Feb 03, 2008
    Hi again,
    Batteries - it may be necessary to clean the battery terminals and/or the contact points inside the battery compartment. In some cases, it may be necessary to gently bend the contacts with the objective of putting a bit more pressure to the battery terminals. There are instances where the batteries will no longer accept a charge, you can try replacing them.
    Hardware wise - Common problems are stuck or inoperable lens. This may be due to dirt, dust, grime or the likes. You can try cleaning with a soft brush and/or a can of compressed air.
    Software - If all of the above does not prove to be corrective, you may need to upgrade/update/reload the firmware. Unfortunately this is only done in authorized service centers.
Problem with kodak z650 camera wont stay on
Hello Francine, Sounds like internal fault, need to have service check,may be too costly to repair.
Best Regards, Russell
Jan 21, 2013 | Kodak EasyShare Z650 Digital Camera
I have the kodak easy share c913 my camera turns off when i try to use the zoon button
please make sure that you're using fresh batteries. remove battery then press and hold power button for 30 seconds. reinsert batery and try to power on and use zoom functions
Sep 06, 2010 | Kodak EasyShare C913 Digital Camera
I dropped my camera and it won't turn on!
OoW repair: 48,44 pounds
Alternative Trade up: Where you trade your old camera to a new camera for 25-30% less than market price.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 01, 2009 | Kodak Easyshare 1725043 M893Is Digital...
Kodak Easy Share V1003 -Screen stays a grey blue color.
A new screen is availably from virtualvillage dot com for about $45. I replaced one last week. It only takes 20 minutes and a small screwdriver. The ribbon cable is held in by a flip up lock at the main board.
Aug 06, 2009 | Kodak EasyShare V1003 Digital Camera
My Easy Share (Z730) is in the open position & will not close.
VERY COMMON WITH EASY SHARE. There are only a couple things you can really do. FIrst, try removing the memory card and try it. Than if that dosen't work. Try holding power button while gently wiggleing the zoom.
May 30, 2009 | Kodak EasyShare One Digital Camera
Battery will not continue charge after a few seconds
Run the battery all the way down until completely dead and then try recharging. Nickel metal hydride (NiMH) batteries don't develop a "memory" quite like the old nickel cadmium (Ni Cad) batteries, but this seems to work when my cell phone won't hold a charge for more than a day.
Mar 16, 2009 | Kodak EasyShare Z760 Digital Camera
I have Kodak Easy Share CX7430. I have put in new
Enilra, sounds to me like you might have the button that takes the photo stuck in the down position. Without turning on the power, put you finger on the button and press down on it while you move wiggle your finger around. Get a good look at the button and see if You Can See If The Button is returning to the UP Position. Withour seeing your camera in person this would be my guess.
Feb 19, 2009 | Kodak EasyShare One Digital Camera
Camera will not stay on
C653 Camera worked great, went to take a pic and it went dead red light and green light flashes, but no action, changed batteries still same ... any ideas
Thanks Gord
Mar 28, 2008 | Kodak EasyShare C653 Digital Camera
Kodak Easy Share M753
the answer can be found on pages 39 & 40 of the User's Guide for the Kodak EasyShare M753/M853/MD853 zoom digital camera
Feb 28, 2008 | Kodak EasyShare One Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
