I have a 50PQ30 and after about a half hour of it running the Top half of my picture goes away, leaving the bottom half with a picture. Does not happen all of the time, just once in awhile.
Re: I have a 50PQ30 top half of picture goes away.
There is a bulletin concerning issues of this nature. It is recommended to install several clips on the inside of the unit. I would recommend that you contact LG.
I have had a few HP printers that seem to get confused when something doesn't go according to plan. I eventually learned to switch everything off and walk away for half an hour.
If you wish to get some details; visit the site linked here. Pull up older posts. https://electronicshelponline.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Half of it goes away in the first 30 years, leaving 0.5mg. Half of that goes away in the second 30 years, leaving 0.25mg. Half of that goes away in the third 30 years, leaving 0.125mg after 90 years.
Hello: Seem you are in zoom mode, try hitting the format putton on the televisions remote and if you are using a cable box and using HD check for a picture format or aspect button on it also. You will want to be on 1080i normal or stretched. The cable box and television will use different modes for aspect, try using only one of the remotes when changing aspect ratio buttons or screen size.
remove the back wall leave the unit to run half hour open and see if coil have frost all the way from the top of the coil to the bottom if the coil is full you have adefrost problem could be your timer defrost thermostart or heater
I have a 51" magnavox plasma. after about one half hour the bottom half of the picture goes black, and u can still see the top half of the picture. what can that be
