Question about Ovens
Kenmore wall oven model 911.4088816
The oven heats up to the desired temp, but sometimes shuts down periodically. The display reads the set temp, but actual temperature could much lower. The oven may run ten minutes, or a couple of hours, before doing this.When it does occur, there appears to be power from the relays, but the elements will not heat, even when put on broil. Is there temp cut-out that may be acting up, or possibly a control board, or relay board? My wife kinda wants it going for Christmas dinner.
Sort of the same problem. The upper oven seems to heat, and the "Pre-Bake" comes on. It will heat for a while and then, sometimes, will just completely shut itself off. It does this only some of the time. Last time (yesterday) I decided to be stubborn and would turn it back on every time it would turn off. After five or six times, I went to open the oven to check inside, and I was locked out. It wasn't like a cleaning cycle lockout, where the door won't budge. I could open it maybe half an inch, then it is locked. I don't know how to make it open. (Open the door, HAL) OK, I lost the stubborn contest, but why is it doing this and how do I fix it? By the way, it seemed to start this after the last time I did the self-cleaning cycle, if that might have anything to do with it. What can I do? By the way, the bottom oven works fine. It's two+ years old, and I can't find a model number.
    Problem Solver:
  • 10 Answers
Www.kenmore.com/shc/s/s_10154_12604_Kenmore_Cooktops%2C+Ranges+%26+Ovens_Wall+Ovens
Try to identify which oven you have and try to get a manual from the same source
Posted on Feb 03, 2008
Bottom oven isn't heating to desired temp. Considering swapping the heating elements to see if one is faulty - thoughts?
try thermostat first. verify heating elements operational, if so check if tstats are same. swap if so, If not jump out tstat and see if higher temp achieved.
Sep 20, 2015 | Thermador PODC302 30" Double Electric Wall...
Kenmore elite dual fuel range model # 790.75503- My power was cut off and since my oven won't heat (display shows on, but doesn't heat - stays at 100 degees) - also my burners won't ignite (unless I t
It could possibly be you are not getting 240 volts to the range. The top igniter may be getting a current back through the other side of the 240 circuit and that is why it works when the oven is turned on but the oven will not be getting power to heat. Have the 240 circuit checked or make sure the circuit breakers are reset correctly.
Feb 09, 2014 | Ovens
Oven Won't Heat To Desired Temp / Burner Quits Working Sometimes
The temperature sensor in the oven needs to be replaced. Here is the part to order. As far as the top element, lift the top up and look for lose or broken wires on the element. Keep me posted.
Nov 20, 2012 | Magic Chef Ovens
Error message f4 fan lt electric double oven model 49425 & 49429
Every fault code I am able to find concerning F-4 period has to do with bad oven sensor. This is the probe coming through the wall inside the oven to read oven temp and to regulate it. Hope this helps. Rick
Mar 04, 2010 | Ovens
Amana wall oven will not heat with new ERC
the heating element needs replacement.that the only solution.its common in this ovens as the heating element breaks down in between so it never heats up.
Mar 03, 2009 | Amana AOES3030 Electric Single Oven
Kenmore oven doesn't keep heat
im going to assume it is gas.. you may have a bad ignitor.. it is not gettin hot enough all the time to ignite the gas.. eventually it will not lite it at all..
Feb 15, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 911.30464, 30465, 30469.....Wont ignite at all
there is a second ignitor for the oven unlatch bottom panel remove heat panel there is your burner and ignitor
Jan 15, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Kenmore electric oven
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired temp.to cook. Can you tell me what my problem is? Thanks. Doug.
Dec 02, 2007 | Ovens
Oven shuts off by itself
When your oven reaches the desired temp. it shuts down then turns back on again after it cools down a couple of degrees and cycles like this during the complete baking cycle. If your ignitor or oven valve is getting weak it would cause this symptom.
Oct 31, 2007 | GE JGRP20 Gas Single Oven
Ovens Logo
577 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
