Question about Sharp R-820B Convection/Microwave Oven
Waveguide cover I have problem with my Sharp R- 820B. Waveguide cover.
  • Anonymous Mar 18, 2014
    waveguide cover
    waveguide cover
  • Sharp Master
  • 9,098 Answers
If it's damaged and cleaning won't take care of it, you can buy a new waveguide cover from Tritronics at http://www.wehaveparts.com
We have the full service manual at our site for your convenience:
http://www.microwavedisplay.com/r820bc_bk_bw_sm.pdf
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 09, 2008
I have a Sharp Carousel Microwave R-1460A. The disk on the ceiling, opposite the warming plate and about the same size, has severe burn marks (probably from food splatters). Any idea what that part is
see this indication and fix it. God bless you
  1. Waveguide coverSparking and arcing in a microwave can be caused by a damaged waveguide cover. Try removing the waveguide cover to see if the problem persists. Once removed, the waveguide cover can be inspected for burns, which will indicate if this is the issue. If the waveguide cover is burnt or will not stay in the proper spot it will need to be replaced.
  2. Cavity/Rack supportIf sparking or arcing in your microwave is near a rack support, any exposed metallic area can be covered with a microwave cavity support. It is also recommended to replace the rack supports in this situation to ensure the issue is resolved.
  3. Cavity paintIf sparking or arcing in the microwave is visible on the side walls, the paint covering the metallic areas could have worn off or chipped. This can possibly cause pitting in the side walls or ceiling. If this is the case, it can be repaired with microwave cavity pain
Nov 08, 2013 | Sharp R-1460 Microwave Oven
Is it dangerous to use the microwave without a duct cover
Yes, the waveguide (duct) cover protects the waveguide and the magnetron from damage caused by grease and food particles getting on them.
The waveguide cover (also called a spatter shield) is usually about the size of a playing card and often held in place by a plastic rivet.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the area is charred or chipped, the area will first have to be sanded smooth and cleaned and dried thoroughly.
If the cavity metal of the oven is cracked or split, you can use a small amount of steel-based epoxy such as JB-WELD to patch the crack or hole.
Once that dries thoroughly, you can sand it very smooth.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced.
It provides critical protection for the magnetron.
You can order a new waveguide cover form
Encompass here.
Jun 06, 2011 | Sharp R-216 800 Watts Microwave Oven
I have a Sylvania Microwave oven Model # SM81004/SM81001 1.0 cu.ft. It started sparking during reheating a plate of food only after about 1 Minute. The metal plate on the right side looks like it has a...
You should replace the waveguide cover, the plate you refer to. They are fairly cheap and easy to replace.
www.espares.co.uk or www.cpc.co.uk most appliance repair services can get them.
Mar 08, 2011 | Sharp R-820B Convection/Microwave Oven
I REQUIRE A WAVEGUIDE COVER REPLACEMENT SHARP
Here's a link to the parts listing at searspartsdirect.com:
http://www.searspartsdirect.com/partsdirect/part-model/Sharp-Parts/Microwave-Parts/Model-R120DK/0958/0123245?searchedModel=r-120d&blt=
The list also includes helpful schematic diagrams that you can print for future troubleshooting.
if you need further assistance, please post back and let me know. I hope this helps you.
Nov 03, 2010 | Sharp R-120D Microwave Oven
How do I install a waveguide in a Sharp microwave oven? The old one burned through because of corrosion beneath it. I sanded it & repainted with rust preventative paint. I don't want to break it during...
If you mean the waveguide cover, those are almost always mica or plastic.
They would normally install by sliding them into slots in the cavity or ceiling, and sometimes they are held in pl;ace with a plastic rivet, too.
If a waveguide cover is damaged, it should be replaced with a new one, not repaired in any way.
Arcing will occur, which can damage your magnetron, waveguide, and / or chassis.
If you mean the waveguide itself, which channels the microwave energy from the magnetron to the cooking cavity, that cannot be removed or replaced. They are welded in place. If the waveguide is bad, the oven has to be replaced.
We have quite a few Sharp service manuals which cover disassembly and parts lists, etc. If we have it, I can point you to a link to download it free.
Feel free to contact me directly with your model number.
William E. Miller
prototech@usa.net
May 25, 2010 | Sharp Microwave Ovens
Sharp R-520LK is arcing. Should I just replace the waveguide cover?? I tried cleaning it, but it was like paper and now there's a small hole in it.
Quite often this is due to grease or food particles stuck somewhere in the cavity of the oven or stuck on or behind the waveguide cover.
The metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the metal is chipped or charred, the area will first have to be sanded smooth and cleaned and dried thoroughly.
If your waveguide cover is burned or damaged, it will need to be replaced. It provides important protection for the magnetron.
You can order Sharp parts from Encompass here or you can call them toll-free at 866-779-5835.
Jul 19, 2009 | Sharp R-520LK Microwave Oven
Sharp r-820BC sparks
It may also be in the area of the turntable support, coupler, or motor.
The waveguide cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron.
We have the service / repair manual for this model and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
Most computers will open this document automatically, but you may need the free Adobe Reader
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
Jun 08, 2009 | Sharp R-820B Convection/Microwave Oven
Sharp R403 microwave internal electrical short/fire
This is a simple problem & solution.
Since your waveguide cover is damaged, it will need to be replaced. It provides important protection for the magnetron.
Jun 03, 2009 | Sharp R-403HW Microwave Oven
RE: Sharp Platinum R630DS Microwave. Has arcing up in the top area of the cavity.
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
You can find exploded views by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
Aug 09, 2008 | Sharp Microwave Ovens
Sharp R-820B Convection/Microwave Oven Logo
347 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
