Question about RCA D52W19 52" Rear Projection Television
Broken d52w19 your past posts have given me some hope of fixing my rca nightmare. have you figured out a cost of repair? also, with so many folks in the same boat, do you know if rca will pony up the parts as a recall?
  • tvcrazy Feb 18, 2008
    sorry about the virus. everybody around here has been sick too. i need to know how to find the components. is there some place i can get a schematic to find the fl231? i can find the power supply and everything that looks like a fuse checks good.
FL231 looks like a capacitor located right in front of flyback transfomer, this number you should be able to read on chassis, as soon as i can i will find out where to ship deflection board and cost of replacement this is what i might do to fix customers sets.sometimes shipping board is cheaper then you knocking yourself out trying to fix it.
Posted on Feb 18, 2008
  • RCA Master
  • 5,138 Answers
Hi ,here is some of the tips found on www.repairworld.com no convergence- replace fuse FL231 near flyback or in front of flyback also solder flyback pins alot of these sets have poor connections,they are having alot of trouble from ribbons that connect from bottom tuner broad going to convergence broad also connectors that ribbons plug into so far there is more infor on the HD52w59 .The next set i get in my shop the first thing is to solder power supply broad,then see what happens so far the 2 sets i have now i havent been able to fix,but im not quiting untill i fix them or throw them back to customers.
Posted on Feb 05, 2008
  • ladywinn
    ladywinn Feb 17, 2008
    Sorry that i havent been back in touch ive been sick with bad stomach virus. I have found out a little more about these sets power supply number # 264104 rca HD52w59 but this guy should have replaced FL231 this would have fixed his problem on your set have you found out anything or is it still down.?
  • ladywinn
    ladywinn Feb 18, 2008
    well some how i must have forgotten to sign in advice on this problem showing my reply, but as Guest.
RCA HD TV D52W19 does not turn on
Replace CP150 , CP120 and CP114. You can get the repair kit at www.tvrepairworld.com that has the capacitors and detailed instructions. Look under the RCA repair kits catagory.
Aug 27, 2009 | RCA D52W19 52" Rear Projection Television
RCA D52W19 "crackles" and smells like its burning
Hello pmzone_guard, This problem is quite common in this TV it's due to a capacitor in the power supply being overloaded. The chassis model is a ITC222. The capacitor is located on the deflection board which is part of the power supply and should not be touch by someone that does not have TV Repair Experience, due to the fact that this area of the TV is the most dangerous. I would suggest having a qualified TV repair technician do the repair on this TV. If the problem is just that one capacitor the part will cost about $2.50 at the most, so the charge will be the cost of the part plus the labor involved. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Jun 14, 2009 | RCA D52W19 52" Rear Projection Television
MY RCA MODEL NUMBER D52W19 WONT TURN ON!
Hello , I believe this may be a HV/LV power supply problem since this is a common issue in this RCA ITC222 chassis, I posted this earlier and I beleive that it can help you, Hello This is a common problem with the ITC222 chassis, I would check CP120, CP140, CP150 to see if they are bad I suspect CP150 is the one that is bad. Its value is 2200uf 16VDC. It is located on the same board as the IHVT and is in between the Heat sink in the middle of the board. I would also like to say that if possible you should get a qualified TV Technician to repair this set for you, due to the nature of this problem and the dangerous voltages present. I hope this helps, Shuttle83 http://www.electron-age-technologies-llc.com
May 17, 2009 | RCA D52W19 52" Rear Projection Television
RCA 52' Projection TV Model 52W19B Need help with bulb replacement
bulb? what model do you have....is this a d52w19? if this is a rca itc222 chasis unfortunatly it has no bulbs.. it should have tubes and these are not fesable to change
Oct 07, 2008 | RCA D52W19 52" Rear Projection Television
3d image/sinking effect
This is a convergence problem. Ther are either bad connections at the convergence ICs or the ICs are defective. If you can solder, you can repair this yourself. Try resoldering the pins on the ICs first. If that fails to resolve the problem, replace the ICs. These ICs are large, black and attached to a heat sink. They should be marked STKxxx. Figure on $20 for each one. There will be 2 of them.
Keep us posted.
Dan
Jun 02, 2008 | RCA D52W19 52" Rear Projection Television
My RCA D52W19 makes a sizziling sound and sparks. Where can I find the part to fix it? Do I need to replace entire circuit card aor just the part and what is the price range for this repair. Thanks
thats a flyback a tech shop will cost between 4and5 hundred dollars to fix it or I can post a link where you can buy a new flyback for your tv for under 50 dollars and get free online tech support to do your repair its an easy repair to do takes about 25mins that chassis is famous for bad flybacks and hv splitters post me a picture of the part that sizzles cause it could be either one
Apr 09, 2008 | Televison & Video
RCA D52W19 52 in. Rear
open it up and see if any liquid is spilled on the boards, most squeals are from the high voltage transformer and or splitter
Jan 17, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W19 power problem
these set is what i like to call VAlue sets.. you can get these for 800 at walmart. If you smell something theres a good chance its what is called a flyback transformer... i repair that averages about 300 to replace. Caution it may be more. DANGER, Do not attempt repair of set unless qualifed to do so tv generte high and leathal voltages.
Jan 01, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W19 SPARKS IN REAR
Was there actually power when the Television was sparking? I would suggest replacing the power module and having someone test the voltage coming out of the plug it was plugged into did it trip the breaker?
Jan 30, 2007 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
119 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
