Question about Fisher and Paykel GWL11 Top Load Washer
GWL 11 started leaking
6 year old machine just started leaking.  water appears to be dripping off drive motor and gets worse with successive use.  Is it drive and where can i get replacement part.ThanksTim
  • 1 more comment
  • ryanimals Mar 31, 2008
    gwl 11 has leaked fairly consistently since i got it. it was a gimme from a relative and i ignored the problem for too long. it mostly leaked during the spin cycle until yesterday. it leaked over nite and when my companion went to use the machine today, it just shut off after filling for 1-3 minutes. afraid the leak got worse and shorted some electrical part on the bottom of the drum. please help.
  • mfranks Apr 01, 2008
    I have a 5 year old machine and its starting to leak water. Look like water is dripping arount a little motor with fins on it. Can you give me some advice? How much is that motor?
  • dob48 Apr 13, 2008
    I just replaced my Fisher Paykel washer after only four years of use. It was leaking, and apparently shorted something out. It was smoking and I could smell something electrical burning. It's history. What a disappontment!!
  • 125 Answers
The pump is most likely leaking, if you need a part check with your dealer or email me and I can ship it out. mbenham@rea-alp.com
Posted on Feb 23, 2008
Replace fisher paykel iwl 16 mother board with gwl 11 motherboard
I cannot find your mothers IWL16 model, but I have found various similar machines that are the same phase as your GWL11 machine, the electronics in there although different are compatible, you can swap the drain pumps, there almost universal, avoid the drive shaft machine, fix the other one If you want further help, post a photo of both pcb's (the electronics) After swapping your machine will stil require programming which is simple enough
Sep 14, 2012 | Fisher and Paykel GWL11 Top Load Washer
Tasciugo dehumidifer about 10 years old has started to leak. I have cleaned filter and spout water drips from is there anything else I should do. ?
Drips from where?
Find the source of the drip and seal it with rubber or waterproof tape.
If there is no pressure at the leak, this should cure it.
If you have trouble locating the leak, dry off everything and operate the
dehumidifier while you watch for the appearance of the moisture. Where
it first appears is probably the leaking location.
Aug 29, 2011 | DeLonghi Dehumidifiers
My washer is not thoroughly spin drying the clothes. I have to run it through 2 or 3 times on the spin cycle to get the clothes not to be dripping. It is 19 years old and just now started doing this.
it may be your agitator. 1
Unplug the washing machine, and turn off the water supply to the machine. If necessary, remove the water hoses from the back of the washing machine because they may be in the way of the access panel.
Check that the agitator is seated correctly by opening the lid of the washing machine. If it's loose, pop off the top of the agitator--if there is one--and tighten the bolt that holds the agitator in place. Or, in some models, simply pull straight up and then reseat the agitator.
Remove the access panel located in the back of the washing machine by unscrewing the screws holding it in place. This allows access to the drive motor.
Press on the drive belt that works the agitator. If the belt moves more than 3/4 inch, tighten the belt to fix the spinner problem. If the belt is worn or cracked, replace the belt.
5
Replace the drive motor, if tightening or replacing the drive belt doesn't fix the agitator. Purchase a new drive motor at a wholesale retailer. Disconnect wiring, remove screws holding motor in place and insert new motor. Screw into place, and connect wiring.
6
Check for any black substance leaking under the washing machine. This might indicate a clutch problem, if the washing machine spinner is not working. Contact a professional repairman to replace the clutch.
Jan 31, 2011 | Kenmore Washing Machines
Water dripping 1/2 thru wash cycle
I'm just guessing here, but if those spots you mentioned are heater supports and the heaters come on during cycle # 6, then the heat may be deforming the seals so that they leak. It would appear that the fix is to replace those seals, but I would try to build up the outer area with silicon glue (clean the area with rubbing alcohol or acetone first) to see if it would hold the water first. It could be a fairly extensive process to replace the seals (if you can still buy them!). Hope this helps some!
Jan 16, 2010 | Washing Machines
Fisher Paykel gwl11 washer leaking and squealing
Set the machine on its side and started taking it apart til the problem was obvious. Called Fisher for the parts. A big black seal is out and a bearing above the impellor that cools the motor, we ordered a pump assembly that is on the bottom side of the motor. I am still going to replace the water pump in the drain side, that is a no brainer. Will update on the repair when the parts arrive
Jun 01, 2009 | Fisher and Paykel GWL11 Top Load Washer
GWL-11 Fisher Paykel wont turn on and water on the floor
hi
if you are sure the power outlet is ok then it can only be the lead or the electronics in the machine, if it has no life at all it can be a fuse on the main module but you need tobe qualified to play with those parts and it is not something that you can just pull out as they are soldered in in most cases
chers grantsreps
Oct 02, 2008 | Fisher and Paykel GWL11 Top Load Washer
Bosh Washing Machine leak
Regildg,
No, I have not fixed it. I can see the water dripping off what appears to be electric motor plates hanging low on the bottom of the washer.
It does seem to leak most right after I have used the machine.
The drip is not getting worse and appears to be about the same.
Jun 29, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
97 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
