Question about Philips 42PF9630A 42 in. Plasma Television
42PF9630A/37 Phillips Plasma HD
I cannot figure out how to get higher channels, past 98. Autochannel simply stops before going on to the higher channels.
  • James Peters
    James Peters May 11, 2010
    Is your autochannel set to Antenna or cable when autoprogramming ?
    Scholar:
  • 72 Answers
Possible you might have a bad tuner in your tv. But the sound blaring. Sounds like u might have a bad audio amp. But, there might be another reason ! 9630 tvs are very bad about being assembled with the speaker wires being pinched between the cabinets. causing no audio or the tv to shut down.
Posted on Apr 29, 2008
It is set to Cable.
There is no 'sound' of volume bar.
It is almost impossible to get any volume out of the TV sometimes, then it starts blaring.
Piece of junk.
Posted on Apr 08, 2008
I HAVE A PHILLIPS 42'' PLASMA 42PF9630A-37
The only thing I can suggest outside of taking the television to get repaired is a hail-mary firmware update. To be honest, the firmware update process is fairly complicated and lengthy. You can download the firmware and find instructions for it here.
http://www.p4c.philips.com/cgi-bin/cpindex.pl?ctn=42PF9630A/37&scy=US&slg=AEN
Look on the right hand side for firmware information.
This TV is likely outside of its 1 year manufacturer's warranty so you would have to pay any and all repairs. Before deciding to do a repair you might try calling Philips. For a while they were offering a service to customers like yourself with out of warranty units. They would offer to sell you a more up to date model at a discount. I'm not sure they still do this but its worth a shot.
Hope that helps!
Jul 19, 2011 | Philips Televison & Video
THE MENU KEEPS POPPING UP ON THE SCREEN CONTINOUSLY ON MY 42 INCH
I had an LG 37" LCD that did this to me. Turned out to be bad solder joints on the side button board. Just reflowed and it starting working fine.
But now that I think about, I had another set do the same thing, only it wasn't the button board. I had to upgrade the TV's firmware via the USB service port. Just needed a USB flash drive and downloaded the firmware from the mfg's website. There were easy to follow instructions there too!
Nov 29, 2009 | HP PL4260N 42 in. Plasma HDTV
Menu keeps popping up
check remote faulty batteries/take them out see if it stops doing it also depress menu button on tv might be stuck
Nov 10, 2009 | Philips 42PF9630A 42 in. Plasma Television
Phillips 37 in menu screen keep coming up?
Download the latest software from the Philips website and place it on a USB stick.On the Philips site you will find a manal how to go on with uploading the software to te TV set.
Nov 02, 2009 | Philips 42PF9630A 42 in. Plasma Television
Phillips 50PF9431D/37: Perfect Picture, inuadible audio
The audio or sound IC (integrated Circuit) on the TV panel maybe bad and need to be replaced.
Also, the speakers of the TV may have a weak connection from inside the panel.
But my best bet is the first solution i gave. If u are not a qualified electronics technician then take it to a service centre.
Joseph Asoh,
Abuja, Nigeria
Mar 12, 2009 | Philips 50PFP5332D 50 in. Plasma...
Resetting philips 42pf9730a/37 remote
Most of the problems with the Philps 42" plasma (other than fuses) can be fixed with a firmware update.
If you have a PC and internet connection you can download the firmware and tranferit to a 1 gig USB memory stick. turn off the TV insert the Memory st, turn on the TV and it automatically recognises the stick will go into upodate mode with on screen instructions for the user.
They have had problems in the past with HDMI and volume, HD pixel problems, all of which got fixed in these updates.
It is very intuitive and if you have the slightest PC savy, anyone can do it.
44hink
May 31, 2008 | Philips 42PF9630A 42 in. Plasma Television
'42pf9630a 37 philips tv only displays menu
Check the software and if is not BX23U-1.5.0.0_03531 upgrade it by downloading the software onto a usb stick at www.p4c.phillips.com if that don't fix the issue replace the SSB part number 310432842611
May 12, 2008 | Philips 42PF9630A 42 in. Plasma Television
Phillips TV- Plasma Model #42PF7220A/37
A tech will need to come out. When the tech do come out have him unplug the Y main and see if the led goes solid greem if it does have them replace the Ymain and the Y upper/lower boards. Most likely that will be the problem.
Feb 29, 2008 | Philips 42PF9630A 42 in. Plasma Television
Philips 42PF9630A 42 in. Plasma Television Logo
96 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
