Question about Linksys WRT54G Wireless-G Broadband Router (LS-WRT54G)
My computer deleted my router when i got it fixed and i dont have the disk to re-install?
Can any1 help me with this i need an installer for my router so i can use it again cuz this is makeing me mad some1 plz help me!
    Brigadier General:
  • 6,966 Answers
The setup wizard installer for a LinkSys WRT54G may be downloaded from here. Please select your version number.
Good luck and kind regards.
Posted on Feb 03, 2008
6ya staff
SOURCE:
How do I fix insufficient disk space when installing a game?
SOrry but noone I ever heard of has any luck demanding microsoft fix any compatibility problems . If it worked on win8.1 then do a recovery and go back to 1in 8.1 problem fixes itself .
Sep 06, 2015 | Microsoft Video Game Consoles & Games
Computer very slow
your System may be slow due to following reason
- Too many programs running at startup or in the background
- Data Corruption, hard disk fragmentation
- Missing Windows updates or outdated drivers
- Not enough hard drive space, too many unused programs
- Left over programs, old cached and temporary files
So Follow these steps to fix computer problem::
- Delete all the temp files
- Remove unused programs
- install latest drivers from the manufacturer site
- Install and run antispyware software
- Free up wasted space with Disk Cleanup tool
- Defragment your hard disk drive
If you are unable to perform above tasks then use a single utility tool like PC Fresher that will fix windows errors that cause of system slow
Sep 22, 2013 | Computers & Internet
Can not uninstall nba live ask me for a disk but I dont have it
Install the program Revo Uninstaller
http://download.cnet.com/Revo-Uninstaller/3000-2096_4-10687648.html
Use it to uninstall. After the installer finishes. It will scan the computer for leftover files and delete them. It will then delete the entry from add and remove programs list.
Oct 17, 2012 | NBA Live 08
I was given a router but i dont have install disk linksys model wrt54g how can i install it
no install disk is needed
Connect the Router (Up link to modem, Port 1 to computer) Boot computer, you should get an IP address in the range of 192.168.1.xxx Open a browser (IE/Firefox etc) on the address line type 192.168.1.1 press enter You will be prompted for a username and password. Leave the username blank, password= admin Once logged into the router, you can set the wireless settings then save and then you can connect via wireless. For Wireless security codes, you can use the default suggested by the router, or as I recommend, use an old 10 digit phone number as WPA key 8009993355 for example as it is generally hard to guess but easy to remember.
here is more info if needed
http://www.ehow.com/how_5133173_set-linksys-wrt54g-wireless-router.html
Dec 24, 2010 | Linksys Wireless-G WRT54GS Router...
I HAVE A LINKSYS wireless-B broadband router 2.4 Ghz 802.11 Model BEFW11S4, and i am on guest account and i do not have a disk for instilation so is there a way to instal it without a disk?
You dont need an admin account or installation disk to install the Linksys router that you have.
Just get an Ethernet Cable plugged in to 1 of the 4 ports at the back of your router and plug it to your computer.
Then Access your router via your computer by opening Internet Explorer and type 192.168.1.1 to the address bar.
if it would ask you for Username and Password, default should be the one below.
Username:
Password: Admin
As you can see you just need leave the password blank and put admin to the passowrd.
if this password doesnt work just press the reset button at the back of the router for ten seconds and restart the router.
After that try accesing the router again. It should now let you access your routers setup page.
Oct 05, 2010 | Linksys BEFW11S4 Wireless-B Broadband...
Lost install disk
You don't even need the installation disk! Just do these easy steps:
Plug in your PC directly to your router. And make sure it is turned on. Also plug in your MODEM into the routers modem port.
On your computer open up Internet Explorer. Then in the address box type in: routerlogin,net
User: admin Pass: password
if password for the password does not work then just leave the box blank. Then just complete the steps.
If this works or if you need help then PLEASE email me:
[email protected]
email me wither it works or not!
Feb 23, 2010 | NetGear WNR2000 Wireless Router
HELP! wont install
go my computer-c drive-programe files-and delete any programs you dont use and do disk cleenup in accessorys and defragg
Oct 05, 2009 | Microsoft LifeCam VX-3000 Web Camera
I dont have the installation disk anymore. Is there an online installation. Buying another or ordering one is not an option. thank you
Try this ....
Switch on the router
Switch on a computer with wireless capability
Ensure the computer has received an IP address from the router (DHCP)
To do this start a DOS session and type ipconfig -a and make sure the PC has an address like 192.168.1.x
Fire up a broswer window, ignore any errors about pages not loading
Type in 192.168.1.1 in the browser URL and hit return
This should give you the login page for the router. The username and password is usually "admin" and "netgear1" for NetGear routers, depending how new it is. If not try "admin" and "password".
Ripface.
Sep 26, 2009 | NetGear WGR614 Wireless Router
I BOUGHT FIX IT VERSION 9 TO REPLACE 8. MY PROBLEM IS I CANT DELETE VERSION 8 TO INSTALL 9. MY COMPUTER SAYS I EITHER DONT HAVE ENOUGH DISK SPACE OR FIX IT IS BEING USED BY ANOTHER PROGRAM. BOTH REASONS...
HI
You need to uninstall Fix IT 8 not by deleting it but by uninstalling it through the control panel remove programs.
then install Fix IT 9
It should work fine
Cheers
Nov 28, 2008 | Computers & Internet
Install D-Link wireless router to my computer
i got a d-link airplus =520+ wireless card from a friend but with no install disk. is there a way to download the install software?
Oct 06, 2007 | Computers & Internet
Linksys WRT54G Wireless-G Broadband Router (LS-WRT54G) Logo
244 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
