Question about Actiontec GT704WG Wireless Router (gs583ad3-01)
Seeing whose on my network
I'm trying to find out who else is logged into my wireless network.
  • 1 more comment
  • john mangrum Feb 15, 2008
    thanks a million
    thanks a megabyte
  • aidden mazey May 11, 2010
    what kind of wireless router are you using?
    for me you log into the router by going to your web browser and type 10.0.0.1
    type the username and password.
    and then click connected devices.
Log into the router (192.168.1.1, and select the "My Network" tab, that will detail who is on your router, and how they are there (LAN, wireless, USB)
Posted on Mar 18, 2008
Im using an actiontec GT704WG Wireless router
Posted on Feb 04, 2008
Am staying with a friend who has the same device and now we have them mixed up and are not sure whose is whose. How can we work it out as I am going home. Ridiculous I know. Thanks Fay
Check the numbers for each one, if you remember your own number, then you're done, if you don't remember your numbers, then log-in to AT&T.com with each number and try the passwords until you sort them out!
Oct 02, 2015 | HP At&T Sierra Wireless Mobile Hotspot...
Have problem going online, after inputting all info the first time it logged on fine and a atomatice update took place. But after that, the next time i switched on and the ps3 try to log online , a error...
Once you have all the wireless settings of the router, you are ready to connect the play station or the x-box to the wireless network.
Play Station
Now go to the settings page of the PLAY STATION
NETWORK SETTINGS ==>
INTERNET CONNECTION SETTINGS ==>
WIRELESS SETTINGS ==>
If you get confirmation screen displayed stating that you will be disconnected from the Internet. click YES ==>
select EASY ==>
select WIRELESS ==>
SCAN ==>
you will see your SSID ( wireless network name)==>
select the security settings ( router wireless settings)==>
enter the KEY ==>
select the IP address settings EASY ==>
save your settings ==>
Test the connection .
Jan 23, 2011 | Sony Playstation 3 (PS3) Console
It can not pick up the wireless signal in my house
there are several reason why that might explain it:
  1. if your wireless network is secured, try to remove the security. it is possible your wireless adaptor do not support WPA or WPA2 which I assume you are probably using. try to see if now it connects (with an open network)
  2. do you have another computer that is able to log in? if this is the case, it is possible one computer is set to work with a B network and the other is G. in this case you will need to log into the router using a LAN and force it to work with B (the G will continue to work)
  3. are you sure you are not able to log into the router via wireless connection? could it be that you cannot surf the Internet but you can log into the router? if this is the case, most likely you have a DNS issue. the best would be to contact your ISP support, in most cases they will be able to work with you on setting a fix IP and DNS resolver in your computer
Nov 23, 2010 | SMC EZ Connect g SMCWUSB-G (SMCWUSBG)...
I put in my Belkin usb adapter in my usb port and it says invalid UUID, What might be the problem?
Universally Unique Identifier (UUID) is an identifier standard used in software construction,
I think your network is secured by a partivular uuid whose duty is to secure from external devices
Just disable the firewall and try again
Thanks ....
With regards..
Priya
Sep 26, 2010 | Belkin N1 Wireless USB 2.0 Network Adapter...
When I opened the available connections I noticed that there were three other networks listed as available. It seems that people around my house have been logging into my network. How do I stop this
you can see 3 other networks in the list. that means there are 3 more wireless networks in your area. your neighbor might be having wireless router and you are abl to see their wireless networks.
This is the list of available wireless networks that your computer can see and connect to.
If your wireless network is not secured then make sure that you will put password on your wireless network.
click here for more information about wireless security.
Aug 09, 2010 | D-Link 802.11g Wireless Router WBR-1310...
How can i change my password in computer
If you are talking abt changing the passkey , go to the wireless network connection ( right click my network places and click properties ) . Once here , click on the wireless networks tab. choose the network whose password you want to change and click properties again.
hope this helps
Thanks
Ranjit
Dec 08, 2009 | D-Link DI 514 Wireless Router (DI-514)
I boiught a mini Insp. 3 mts ago and have been trying to log on to my net at home but it will not work. It sees my net and tells me signal strenths but will not log on I have checked every thing to do with...
Make sure you have the laptop reading the same type of encryption that your router is brodcasting. Also make sure you are using proper network key. I know that some network keys are case sensative. Good Luck
Nov 23, 2009 | Dell Inspiron 5100 Wireless Mini-pci...
Wireless card not detecting!!!!
I had simalar problems where I could not detect my wireless network even though I could get on the internet I could not see the other computer on my network. I finally after trying everyone else's advice which did not work, found a program called Network Magic. You can purchase it from www.purenetworks.com for $30.00. It took care of all of my network problems and even shows a nice map of how my network is setup and what computers are logged onto the network and even what software like Windows Xp or Windows Vista is on that computer. It will even generate daily logs if you want to show any problems with the network.
Mar 19, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Wireless problems
Go to wireless properties and removed preffered networks on wireless computer and then refresh the network list.If does not work log into router and configure wireless settings again. IF that does not solve problem upgrade firmware on router and that should fix any issue.
Aug 27, 2008 | D-Link AirPlus DI-524 Wireless Router
Playstation network problem
Wired connection or wireless? If you are using wireless, try switching to wired temporarily and see if the PS3 stays connected.
May 18, 2008 | Sony Playstation 3 (PS3) Console
Actiontec GT704WG Wireless Router (gs583ad3-01) Logo
185 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
