Question about Sony STR-DA3ES Receiver
Noise and popping on Sony STR-DA3ES
No problem on this unit since it was new. Tonight it started some strange behavior. When ever the sound input changes, like from menu to main movie there is a loud pop. Then during a movie when certain sound are present there is noise like rain on a roof. When the sound disappears so does the noise. Can detect some weak clicking and popping during quiet periods. Seem to just be coming from surround speakers. Wondering if it is just some dust on the circuit board. Any help would be appreciated. It appears I need to get a service manual.
Thanks,
Russ
  • 1,512 Answers
Sounds like its going to square wave clipping and poking a dc offset at your speakers. Happens when the amp reaches power supply ceilings. Pink noise such as "rain sound" will push the output stages and power supply to limits. If its on all channels, check power supply caps and check for dry solder joints. also look for that crappy brown hold down glue that goes conductive/corrosive. check all output stages particularly about discrete output devices that are attached to heat-sinks. They have a bad habit of dry jointing also. Good Luck
looked for a free manual on line for you
http://www.nodevice.com/manual/Sony/page139.html got heaps... but not your exact model. You may be able to cross reference one
Posted on Feb 03, 2008
Service Manual for STR-DA3ES is available here -> http://www.eserviceinfo.com/download.php?fileid=51499
Posted on Jun 13, 2010
SW-910, blown speaker or ? makes rattle/buzz sound. replace speaker and/or change to passive type sw?
i would suggest replacing it rather than fixing. The cost of the repair will be about the same.
if you went to a passive sub/seperate power amp setup you could get a much higher quality unit, but it would cost you considerably more cash.
Feb 01, 2015 | Sony Audio Players & Recorders
Sony STR-DG1000 HDMI video not displayed
That's strange, does the monitor work with regular av cables or and s-video cable ?
Dec 27, 2007 | Sony STR-DG1000 7.1 Channels Receiver
I have a Sony STR-V444ES receiver that is receiving what I believe to be a static discharge. When I turn on all components, I will receive a random loud popping sound that usually happens in the first 15...
The AVR have problem in its pre amplifier stage. Normally this type of cracking noise will hear because of faulty op amp (operational amplifier) ics. To repair such problems you should have through knowledge in electronics. And also need SMD rework stations Beacuse all the op amp ics are SMDs. If yo have such knowledge then i have added here the link to the service manula for your AVR.
Refer the page number page number 13 first. Its the Audio section blaock diagram of the AVR. you can see the the suspected ic in the top right corner marked as IC410. Which is the pre stage op amp for the frond left righ amplifier. You have to replace this ic( integrated circuit).
You can find the position of the ic by refering Page number 27. Its the input board . On the board you can see three ics with 8 legs(four in each side) On the left side. You have to replace the ic marke as IC410. You can find the schematic for the input board in page number 26. the The part number of the ic M5218AFP-T .
Refer the sevice manual to know how to carefully to remove the input baord.
http://sportsbil.com/sony/STR/STR-V/STR-V333ES_V444ES_V555ES_v1.2.pdf
If you need any more assistance feel free to conatct me through fixya.
Ajin
Feb 08, 2012 | Audio Players & Recorders
Sony receiver made pop noise and all sound systems went mute.what are my options? STR-DE425 sony receiver with surround sound, dvd player,cd player and tv all connected thru receiver...
It sounds like the output ic's may have failed, because of the complexity of system I would have a professional come and look at the unit for an evaluation, chances are he will need to take it back to the shop for service.
Dec 30, 2010 | Sony STR-DE425 Receiver
Popping noise from speakers
sounds like the digital input and the component input are casing inteference , try removing the component video and see what happens
May 23, 2009 | Sony STR-DE695 Receiver
Receiver misinterpreting IR signals
There can be a few causes of this. Since it happens with a number of remotes, we can state that the problem is inside the receiver. In the front of the receiver (inside) you should see a small silver box. Inside that is the InfraRed receiver. This is a 3 pin device. Check to be sure that the pins have good solder joints. A bad joint can cause problems. Also, after the receiver comes what is called a digital switch. This is similar to a transistor except that it makes the transitions more steep, like a step rather than a ramp. If this part is bad you can get these results. The digital switch will be marked c124 (perhaps or somehting close).
Check these out and keep us posted.
Dan
Apr 09, 2008 | Sony STR-DA3ES Receiver
Sony STR-DE825 Receiver Digital "Noise"
Make sure you have fib/opt cables are securely inserted in right ports. Switch through "input modes" on front panel; opt, anal, auto. This unit is tricky and unecessarily complicated. Read through manual carefully!
Jan 28, 2008 | Sony STR-DE825 Receiver
Remote Volume Control Not Working
MEtten,
Flip the top cover, just above the "AV MENU" there is a round boll kind of switch, it has to be pressed when you want to function top cover button, so may be it is warn out or the nob has been broken. if you press that switch with pen nob it will function...
It is bad design...
Surendra
Jan 05, 2008 | Sony STR-DA3ES Receiver
Protector is flashing with the words under it saying"please power off" about 5 secs after I turn on my receiver
this happened to me.  one of the speaker wires had become unplugged and was touching another one... causing a short.  glad to know this unit is "smart" enought not to fry itself.
Oct 01, 2007 | Sony STR-DA3ES Receiver
Sony STR-DA3ES Receiver Logo
321 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
