Question about Canon Rebel XT / EOS 350D Digital Camera
Xti rebel 6 mths old - flash will not pop up
Can anyone help, with a solution. The external flash works quite well, but I did not spend 800 on a set up to have it mal-function...the internal flash does nothing, i can manually open the flash, however, it still will not fire
  • 3 more comments
  • Anonymous Feb 09, 2008
    i have the same problem,flash does not pop out
  • go nikon Feb 19, 2008
    Same problem w/ xti 1 yr old. Solution #1 had no effect
  • Weazdog Mar 25, 2008
    Same problem, This seems to be an issue with the xti. Flash works fine other than i have to manually get it to pop up by pulling it slightly then pressing the flash button. It appears to be a manufacturing issue as the flash seems like it may not be seated properly in its closed position pushing or angled slightly to the left when taking picture. Will eventually send the camera back to canon for repair. Spent to much money to have a broken product.
  • sailwithrob Sep 16, 2008
    the internal flash pops up but will not fire
  • Anonymous Sep 24, 2008
    same thing. 1 year old.
    Problem Solver:
  • 9 Answers
I found the answer and fixed my flash. Look on http://photo.net/bboard/q-and-a-fetch-msg?msg_id=00ODWf
This will describe how, if you have been using a speedlite alot, than the little tab under the shutter release side of the hot shoe can get bent down thus constantly pressing down (toward the bottom of the camera) the small button which deactivates the pop-up flash even when the speedlite is not attached. Just bend the tab up a little with a jewler's screwdriver, turn the camera off and on and voila!! Fixed!!! Dan describes pushing the tab down, but on the xti, the tab needs to be bent up to release the flash deactivation switch and fix the problem. Thanks to Dan D on photonet for saving me a service call.
Posted on Feb 19, 2008
I can't get my flash to stay the freak Down!! In mid day full sun shine that ****** pops up!!! It's rather annoying...to be honest with you..
Posted on Jul 19, 2008
I removed my flash plate and flash shoe by following these instructions: http://www.conraderb.com/flashrepair/
They're for a 20D, but they work for the XTi as well. There's a little black button that sticks up on the right-hand side; mine must have been stuck down, which is the indicator that you have an external flash on. I cleaned it up, put the flash shoe and plate back on, and my built-in flash works again!
Posted on Jun 18, 2008
Just grab the top with your thumb and finger on the other side and pull it up. you may have to turn off the camera before shooting to celar any erro message.
dip a Q-tip in alcohol and clean the sliding parts of the flash. this might clearn away from gunk that made it stick.
if flash is out but doesn't fire, try it in all modes....
Posted on Feb 11, 2008
How do I use this flash as a slave?
You need to set the flash to slave and the same channel as the master. If the flash doesn't have this function it may be able to be fired optically. Set the master flash to low power and set the off camera flash to optical.
Jul 15, 2015 | Sunpak DigiFlash 3000 External Flash
Internal flash won't work anymore
Try a factory reset. In the menu go to the third spanner and select 'Clear settings'
To pop up the flash put the camera in manual mode (M) and press the flash release button and it should pop up.
Oct 15, 2017 | Canon EOS 600D Rebel T3i Digital Camera
How to fix a trackpad that quit working as well as any external mouse
Have you considered doing a "System Restore"? You could just restore back just previous to the date when the mal-function began. I bet that would fix it, and you don't loose most personal stuff.
Start - All Programs - Accessories - System Tools - System Restore
If this has helped, please take a sec to rate me. Thanks!
Don
Mar 24, 2012 | Dell Inspiron E1505 Notebook
I have conon 60D it is brand new that i have often used but pop up flash does not work after using external flash also I do not have flash indicator light on. inside light meter in the build in flash...
The problem is under the hotshoe plate. There are extremely small hols where the sensor for the internal flash are positioned. These sensors tell the camera when an external flash or some other accessory is mounted on the camera and not to open the internal flash. What happens is because the alignment of these hols is so precise and critical any amount of movement or minute partial of dirt can upset or stick these sensors.
What has happened is that when you removed your external flash the sensors did not reset because of dirt or misalignment so show the setting as if the external flash is still mounted and that's why the internal flash won't pop up.
How to fix it, well for a repair person it may be a simple fix by slightly loosening the hotshoe and cleaning the dirt from under it and realignment. It'll work again until it gets dirt in there again or misaligned. This is one area that Canon shouldn't have been so precise.
I'm not suggesting you do this but when I had the same thing happen to one of my field cameras I took a hard plastic coffee cup and lightly started tapping on the edges of the hot shoe. After a few light taps around the shoe I the internal flash popped up. Once I finished my shoot I sent the camera to Canon to have the problem repaired properly. Repair and shipping to a Canon facility cost me $65.00 Canadian.
Apr 05, 2011 | Cameras
Laptop screen works in dos black in windows external screen always works
Can you clarify your question? I am trying to figure it out but I'm not quite sure what you are asking.
Oct 20, 2010 | Computers & Internet
Units flashes when turned on --won't stop
Here's my LMS 332c circuit board. I'm showing where the power source is on the lower right, and where I believe the first two ribbon cables that lead to the power switch on the front panel (upper left). Can anyone tell me how to disable the internal power switch and where? I want to install external switch and bypass the internal. I can solder and not afraid to try since this unit is out of warranty and is not functional as is with powering on/off and screen flashing randomly. Thanks!
Apr 08, 2010 | Lowrance LMS-332C GPS Receiver
Internal Flash not working-Canon Eos 40D
I've had this happen to me too and I've been researching about it. Aparantly it happens because the camera still think the external flash is attached. If you go into the menu and under flash control, try ot enter the settings for built in flash. If this is the problem it will tell you here that the external flash is still attached. From what I have read to far, I'm not sure how to fix it. I would reccomend taking it in somehwere. I dont htink its a hard problem to fix.
Dec 06, 2008 | Canon EOS 40D Digital Camera
Dark wiew
is it set to auto? if not i suggest you check the aperture and shutter speed setting :)
Sep 22, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
My built flash quit working!
Capacitor or tube blown- stick to the external flash a repair will be pretty pricey
May 25, 2007 | Canon Powershot PRO 1 Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
1,118 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
