Question about MPC Computers Envision EN 780e (White) 17 in.CRT Conventional Monitor
Envision EN 780e Monitor Vertical Problem
I was attempting to adjust the vertical on my monitor. As I was using the buttons on the front of the monitor to navigate, I relaized they weren't perfoming their designated tasks, if performing at all. The end result is a screen that is half black, half web page, with no tool bar visible. And best of all, now I can't open the monitors menu to readjust, none of the buttons work. Please HELP before this thing goes out the window. Thank you.
  • 983 Answers
U just give reset... the menus must be half visible atleast...
or just see the same type in option in other monitor and just write down how much time u must press navigation and iother buttons to go to reset option & to give reset...
once if u have done wit resetting ur screen will come normal to size then u can adjust height and width....
Posted on Feb 06, 2008
6ya staff
SOURCE:
Get rid of "Out Of Range" message on e218c1 monitor.
The device driving the monitor is exceeding the horizontal and vertical frequencies that the monitor can display .....thus the "out of range". The specs for this state that the Horizontal Freq. is 80Khz and the Vertical Rate is 75hz. If you are driving this monitor from a computer running Windows, reboot the PC and use the F8 key to put it in SAFE mode. This will cause the video driver to default to a rate that the monitor can handle. Then go into the screen resolution settings and reset them. The native resolution of the monitor is 1680x1050 at 60 Hz. Exceed that and you'll get the "out of range"
Sep 10, 2014 | Envision Peripherals 22"" envision e218c1...
The display does not fill the screen of the monitor. How can I fix this
It depends on the type of monitor you have. Generally you will have a physical menu button on your monitor. Depress this and look for Vertical and Horizontal adjustments using the arrow keys on your monitor. You can stretch the screen all you like to fit the diameter of your monitor.
Nov 19, 2013 | Envision H190L Monitor
One inch of the window is off the screen
you could adjust the vertical and horizontal adjustment through the main menu of the monitor. buttons on front of monitor. auto adjust may fix it but if it does not look for the vertical or horizontal adjustment fot the area effected. if this helps please rate with comment
Feb 03, 2013 | LG Computers & Internet
Will my Envision 19" monitor,
You will need to set the display resolution and vertical sweep rate on the computer to something the monitor can handle. The monitor works best at 1440 x 900 at 59.8 Hz vertical rate. If your laptop's graphics chip doesn't have this setting (available settings are listed in the Display control panel), then look on page 19 of the monitor's owner's manual to find something that matches a resolution listed in the control panel.
Sep 21, 2011 | Envision Computers & Internet
Monitor is blurrv
using buttons at the front bottom of ur monitor adjust vertical and horizontal moire..it will become shapr clear.
Feb 21, 2011 | Acer AL1711 17" LCD Monitor
Envision monitor EN-7100e color is screwd up.
Unfortunately this monitor has captived VGA cable, you cannot easily replace it. Try moving the cable around to see if you will get normal color back.
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000001218.pdf
http://s807.photobucket.com/home/budm/allalbums
Apr 12, 2010 | Envision EN-7100e 17" Flat Panel LCD...
I want to adjust my screen , its is streching vertically Please help
Look for "buttons" on the bottom-front or bottom-edge of the monitor.
One button will activate the OSD ("On Screen Display). Through the OSD, you can change the "vertical size" and "vertical position" of the display.
Feb 03, 2010 | HP L1955 19" LCD Monitor
I have vertical colorful lines on the screen just got a new computer with windows vista
the monitor is bad if your getting vertical lines on it. Anytime you get vertical lines on any monitor, LCD, laptop LCD, etc, then that means the screen is bad.
Your monitor needs to be replaced.
Aug 09, 2009 | Envision Computers & Internet
Monitor ENVISION EN985e with Vertical failure
If you are looking to take the monitor in to get it fixed, you can try Best Buy. They have an in-house repair team called Geek Squad. For a store in your location just go to www.bestbuy.com
Mar 24, 2009 | MPC Computers Envision EN 985e (Dark...
Vertical lines, colors not sharp, graphics fuzzy
could be the vga car4d problem, try to hook up with another pc if the problem remains then unfortunately the monitor is dying.
Jan 06, 2008 | Envision EN-7100e 17" Flat Panel LCD...
Open Questions:
See all MPC Computers Envision EN 780e (White) 17 in.CRT Questions
MPC Computers Envision EN 780e (White) 17 in.CRT Conventional Monitor Logo
215 people viewed this question
Top MPC Computers Computers & Internet Experts
Toby Lee
Toby Lee
Joaquim Martins
Thomas F. Schneider
Are you a MPC Computers Computer and Internet Expert? Answer questions, earn points and help others
