Question about Sentry Fireproof Safe
Green proceed light goes on but door does not depress lock
I have a combination/key Sentry safe. I opened it and when I went to close it, the door handle was up and would not depress the lock. So, with the door open and the key turned to the right and pulled out, I entered the code and got the green proceed light. I tried to open the door handle but it would not work. Does anyone have any advice? Thanks!
  • 1 more comment
  • SYLVIAH Feb 11, 2008
    New batteries worked! Thanks!
  • Anonymous Dec 04, 2008
    We have same problem and found another site that list out many others with same problem. they were told by Sentry to change batteries, pull off cover to check for wiring problems, and in final solution, get out a rubber mallet and wack the handle carefully (downward). Basically, we have a piece of poo for a safe and nothing we can do beyond the first year of ownership.
  • Anonymous Mar 16, 2014
    Key door will open with the key only. The digital code is not required
I have a different model but I had the same problem. Called customer service and they had me push up on the handle and enter the code. That didn't work but then they had me tap the safe with a rubber mallet 5 times above the panel and 5 times to the right of the panel. That worked for me. Hope one of those works.
Posted on Jan 22, 2009
    Problem Solver:
  • 9 Answers
Https://www.sentrysafe.com/customerCare/retrieveCombination.aspx.............
Try new batteries??
Posted on Feb 08, 2008
I have sentry safe ,lost key but I know the combination i have sentery safe wthih combination lock but i do not have key ,i do have combination. how can open the safe
Put the combination in and open the door. You only need the key if the battery goes flat.
You can get a new key here
Key Replacement
How to open without a key
open sentry safe without key Google Search
This kid shows you how to open one by bouncing it on a bed! If it is fixed, you hit it with a rubber mallet on top.
How to open digital safe without any tools or keys IN 2 SECONDS
Feb 18, 2018 | Sentry Home Security
How to close an SW3750 safe (by Sentry Safe)
To close and lock
You can relock the safe in two ways. With the door
closed, depress the key lock (if equipped) with your
finger, or spin the combination dial one full turn.
For greatest security, do both. (Make sure the door
handle is in the horizontal position.) There is a link to the manual at the bottom of this page...
http://www.sentrysafe.com/Products/380/SW3750_Electronic_FIRE-SAFE_
May 17, 2014 | Home Security
How to set up th ebatteries in my sentry safe DSW5781?
Locksmiths agree
1. Remove and discard the screw (if
equipped) at the base of the lock case.
2. Turn the electronic lock case to the
right (clockwise), from 12 o’clock to
2 o’clock, and remove.
• Insert 4 new AA batteries (not included) to power
this lock.
• Replace the electronic lock case and turn to the
left (to 12 o’clock) to reassemble.
NOTE: The yellow LED will light when the batteries
need to be replaced.
3. Turn the key (if your safe is equipped with a key
lock) to the right so the lock cylinder pops out.
4. Enter the factory code. When the green light appears, you
have four seconds to turn the handle down to
open. Try this several times before proceeding to
the next step.
To unlock safe:
Enter the 5-digit factory code, a pre-programmed
user code, or a pre-programmed user pin
programming instructions. When the
green LED lights you have 4 seconds to turn the
handle and open the safe.
To lock safe:
Close the door and return the handle to the
horizontal position. For greatest security, depress
the key lock (if equipped) with your finger.
Aug 15, 2010 | Sentry Fireproof Safe
How do I open the combination lock to my sentry home safe?
Locksmiths advise these Opening instructions for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open.
sentry safes opening instructions for 4 # combo locks
Turn the dial to zero.
Turn the dial to the left (counterclockwise) four times to the first number of the combination (pass the first number of your combination three times, stopping on it the third time).
Turn the dial to the right (clockwise) three times to the second number of the combination (pass your second number twice, stopping on it the third time).
Turn the dial to the left (counterclockwise) two times to the third number of the combination (pass the third number of your combination one time, stopping on it the second time).
Turn the dial to the right to the last number (stop the first time on your last number).
Pull the handle down to crack the sentry safe open.
Oct 28, 2009 | Sentry Fireproof Safe
I have a sentry SO500. I know the combination but
A locksmith would try to replace the batteries. Sometimes you will get the green light but the batteries still will not have enough power to retract the latch.
Jun 12, 2009 | Sentry Fireproof Safe
Safe SENTRY S3877 can not open the door
The door lock could be jammed try shacking briskly to losen lid and latch! akso it may have reset itself and the combo is no good no more and back to the origanal setting it had when you bought it ! ( if its a 911 you can put a screwdriver in where key goes and turn hard counter clockwise)
Good Luck!
Jan 02, 2009 | Sentry Fireproof Safe
My sentry safe will not open after entering the code it reads "err"
You have to press the program / enter button after you enter the code How to open electronic sentry safes.
Locksmith opening instructions manual for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open
Aug 10, 2008 | Sentry Fireproof Safe
How to open my safe with the code
Apr 18, 2008 | Sentry Fireproof Safe
Sentry Model 1610 Won't Open
I am a Safe Specialist i have been reading some of your problems and this should help there is no code if you have lost yours only the default code for the model 1610 the default code is: 77,22,09,11,64 try that if you havent changed it and with this problem with people not getting the handle open with the green light happening i suspect this is a issue with the lock mechanism i have had many of the same problems with people bringing them in when you get you safe open it and where the lock is put some lubricate on the lock regulary as the lock sticks and wont open if you havent done this then you cannot get it open see you local safe specialist and tell them what i have said and they may or may not be able to get your safe open i hope this has helped Rob Safe Specialist World.
Mar 29, 2008 | Sentry Fireproof Safe
Forgot how to open my fireproof lockbox
Locksmith opening instructions manual for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open.
Nov 03, 2007 | Sentry Fireproof Safe
Sentry Fireproof Safe Logo
628 people viewed this question
Top Sentry Home Security Experts
Hannah Johnson
Level 1 Expert
ray012965
Michael Galve
Michael Galve
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
