Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
Cannot put security on my d-link wireless router
I tried to put a security on my router, but everytime i tried to type the ip address it wont come out instead it will say cannot find the server or it will go to wikedpedia homepage what im gonna do??.
  • Anonymous Feb 06, 2008
    my d limk securaty is not working with my lap top any more it was but not any more and did it 3 dayes a go and it worekd fine for a day nexet day not any more can u plss hellp me
  • 145 Answers
192.168.0.1 correct. Also you have to do this from a wired connection, by default remote logins are turned off.
Posted on Feb 04, 2008
I am trying to find my password for my d-link di-624 router-i have wireless setup but i have lost my password to load on my laptop to connect to the internet. I have a qwest dsl modem with wireless...
First connect your router to computer with ehternet lan cable then go to network adapter property.For that press windows key +R so you can see run type in run "ncpa.cpl" then press enter then you can see network adapter property. go to your network adapter tcp ip property and enable "ip get automatic" then it will get ip from router if dhcp enabled.Then go to command prompt type "cmd" in run so you can see command prompt.Type in prompt "ipconfig" then press enter then you can see all ip address gateway ip is your router ip address .Note that ip then type that ip in address bar of internet browser then you can see your router page.Also the default ip address to access router is http://192.168.1.1 or http://192.168.0.1 Try these ip hen you can see router page .But if you are still not able to see router page with above ip then need to reset it.press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . After seeing router page type user as "admin" and password as "admin" or blank or "1234" or password. then you can see configuration page of routerThen click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password.If you have to reset router for access it then also need to configure WAN ,wireless,DHCP on router . Let me know if you need further assistance. Thanks for using FixYa
Oct 19, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
I stupidly changed a setting on my router configuration using the ip address in the address bar on my internet page , now i cant access it and change it back , i was trying to change my NAT type to open ,...
Press and hold RESET button for 10 seconds it is in the back side of router. Then all settings defaults. Then need to configure it with below method.
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then click on WAN settings set it as your internet service provider settings enable DHCP Then click on wireless and enable it. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Sep 09, 2011 | D-Link DIR-615 Wireless Router
My belkin N1 router when i plug it in it just flashes the security light and wont connect to the internet
You will need to double-check your security settings. Apparently, the modem is trying to tell you there's a problem regarding this.
The easiest way to be able to access the router settings in this case, will be to provide a direct connection between your PC and the Belkin router (using a network cable) and then type in that address.
If the address still doesn't work, double check the router's IP address by opening the Command Prompt (it's under Programs -> Accessories) and typing in "ipconfig", then hitting Enter. The IP-address you're looking for is listed under "default gateway".
(Also, make sure your computer isn't using a fixed IP, set it up so it's dynamically assigned an address by the Belkin router.)
Jan 20, 2011 | Belkin N1 Wireless-N Wireless Router
I have set up three devices to access thiswireless router and the way it was done before was by going throuugh my IP address and then adding the mac address. However now everytime I put my IP address it...
You may have used fixed IP addresses and then used MAC address filtering.
I recommend you let the Netgear issues IP address (DHCP) and use PA or WPA2 encryption plus MAC address filtering.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jan 07, 2011 | NetGear WGR614 Wireless Router
ILL LIKE TO PUT A PASSWORD ON THE WIRELESS ROUTER
You'll need to use the software you installed or find the directions which has the ip address. Type the ip address into a web browser such as internet explorer, press enter on your keyboard or click the green go.
You can then edit your security on that screen
Jun 16, 2010 | D-Link AirPlus DI-524 Wireless Router
I want the password to put the secure code
You can secure your wireless network wit WEP or WAP code.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
For belkin router http://192.168.15.1
or
http://192.168.2.1
Click on wireless settings WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
If you already set the code then if you can read it then you can ser it in wireless but if it is in 8 or # format then add new wep code .
Then you can connect your wi fi network with that code.
Jun 03, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
I reset my belking 54 wireless router and now I want to secure it again because I had forgotten password. Help
You will have to enter the router's control panel and change the security settings. Here's how you do it:
1. Find your router's IP Address.
  • To find the IP address, 1st open Command Prompt (Start>Run>type in: cmd)
  • Next type in: ipconfig
  • After executing the command (by pressing Enter), a list appears. We want the IP Address associated with the "Default Gateway." (Picture).
  • Next open up your Web Browser (Firefox, Internet Explorer, etc...), type in that same IP address, and visit the website (Picture). (NOTE: Do not add www. or .com! Just type in the IP Address.)
2. Visit the router's IP Address and enter the control panel.
3. Find the area pertaining to WEP or Wireless Security.
4. Enable Wireless Security, set a custom passphrase, then check to see if the same passphrase will allow you to connect to the router from a wireless computer.
I've had a belkin router in the past, so I'm going from memory. If you get lost, but are able to post links to screen shots, please do. I'm certain I can assist you if I see the options we're dealing with. However, I'm also convinced the simple explanation I provided above will also resolve your problem.
Let us know how things turn out, or if you require further assistance. Remember, every FixYa expert benefits from your ratings.
Jan 04, 2010 | Belkin (F5D7230-4) Router (587009)
How do I secure this router?
First go to the address bar and type in the default ip address of this router: IP address is 192.168.0.1 Then open this link for instructions on programming the wireless security settings. http://www.voiproblem.com/emulators/DLink/wbr1310/support_internet.html
Oct 28, 2009 | D-Link 802.11g Wireless Router WBR-1310...
How do I secure my DLink-524 wireless
In securint your wireless security try accessing the configuration page of the router. go the the window where you created your wireless netowrk connection.
On that Wireless window choose WEP for security.
By defaut WEP Encryption is 64bit.
Under Key1 erase what's on the box and type in the password for your wirelss network. It should be exactly 10 characters, You could use 0 to 9 or A to F then click on Apply >next.
Try Accessing your wireless networ.
Nov 19, 2008 | D-Link AirPlus DI-524 Wireless Router
D-link wbr-1310
First check to be sure the ip address of the router IS 192.168.0.1, do this by clicking Start/Run and in the Run window type CMD and hit the enter key, this will give you the MS/DOS command window, at the courser type ipconfig /all, then check the ip address shown for the gateway which is your router. If the ip is correct, put a cat 5 cable from the router to the computer and type http://192.168.0.1 if that is the correct ip address and if it does not give you the logon page for the router reset to router to factory defaults as per owners manual. if this works please rate the solution as a FixYa. Thanks BPCS
Jan 20, 2008 | D-Link 802.11g Wireless Router WBR-1310...
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
255 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
