Question about Samsung ML-3051ND Laser Printer
Blank papers comes when the print given
Dear team,
Blank papers comes when the print given. Meanwhile it shown the error msg is: LSU Hsync error cycle power
pls give me the solution
v.manigandan
  • nhpcpkt Oct 13, 2008
    Yes I have the same problem blank papers comes when the print given.
  • Anonymous Mar 14, 2014
    error hsync LSU
D ear team, Blank papers comes when the print given. Meanwhile it shown the error msg is: LSU Hsync error cycle power pls give me the solution NHPC Ltd.
Posted on Oct 13, 2008
Lsu hsync error cycle power
give back cover of the printer, which is located Fuser Fuser is carefully removed after it opened by pressing the two side screws to remove out.Se Fuser notice printed contacts are clean and in particular an electric tab located somewhere in that cloud right des.Reinstall Fuser ... success!
Apr 12, 2011 | Samsung ML-3051ND Laser Printer
I just replaced the cartridge in my ML-2850. I have an error LSU Hsync Error . Cycle Power
LSU is your laser assy. Sounds like you have a major problem. Laser usually needs replacing with this fault.
Dec 02, 2010 | Samsung Office Equipment & Supplies
There's a colour lazer printer 510 in my office, but when, one day, i come to work, the printer screen displayed, PRINTER LSU ERROR. And what can i do about this? Please guide me. thank for your time and...
First just turn it off for ten minutes and then restart it,
There is a fault in the LSU unit.
1. Use EDC mode to test the HSYNC signal and LSU Motor.
2. Check the Harness connected to the Engine Controller and LSU.
2. Check the Harness connected to the Engine Controller and LSU. --> Refit the harness or replace it if it is damaged.
1. Use EDC mode to test the HSYNC signal and LSU Motor. 2. Check the Harness connected to the Engine Controller and LSU. --> Refit the harness or replace it if it is damaged.. 3. Replace the LSU
If the problem still happens call a repair tech.
Dec 01, 2010 | Office Equipment & Supplies
I have put in a new toner in my hp 1000 laserjet and the paper comes out blank when i print my jobs .....helllp!!!
hi
the cover that pritect the laser unit is closed; the release lever of LSU is not actuated; try to open the front cover and look inside is the lever ok , if broken block it with plastic parts to get the LSU on. if LASER beam does not reach te drum unit you have a blank page because the drum was not scanned.
Oct 28, 2010 | HP LaserJet 1000 Printer
Hp 1040 ran out of paper/after restocking now prints blank pages
Even though the toner was shown at 1/2, I had the fax machine operator install a new cartridge. Problem solved!
Aug 24, 2009 | HP Office Equipment & Supplies
Have lsu error also.
Hi ...
LSU stands for Laser Scanner Unit ... you normally get 2 different kind of errors with LSU ...
LSU Hsync or LSU Motor Error ...
If you get this error, it means that the Laser Scanner Unit has gone bad and the only way to get it fixed is to get the printer repaired ...
Cheers ....
Jul 28, 2009 | Samsung SCX-4100 All-In-One Laser Printer
Samsung ML-3051ND Laser Printer Logo
2,933 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
