Question about Clarion DXZ475MP CD Player
Driving lights When I turn my car on my driving lights are no longer working; however, when I lock/unlock my car they blink on and off. Because of this I am assuming that it has nothing to do with the wiring. I have checked the fuses and they seem to be okay (will change them out anyhow just to be sure). Do you have any other suggestions?
  • 24 Answers
You have a bad light switch
Posted on Mar 08, 2008
    Problem Solver:
  • 8 Answers
I would not change out the lights because they work for a minuet showes you that tey work. it is very unlikely that all lights would be intermitent, since there more than one power wire you should check power with a meter and see what wire turnes on then off with the simtom, possibly the light switch wire @ the plug-in connector.
good luck stereo tech
Posted on Feb 03, 2008
6ya staff
SOURCE:
I have changed 4WD Actuator on my 2007 Toyota 4Runner. Now the Central Differential Lock isn't coming off when pushing(but don't know if before it was working). I push to Unlock the Differential but i
Put back on H2 or all normal, remove both battery cables from the battery, without touching the battery, hold the positive and the negative cables together for 30 seconds, then return the cables to the proper posts on the battery. This will drain all memory at the ECU, the next 10 or so miles , under normal driving will re- teach the computer. I hope this improves the issue!
Dec 03, 2013 | 2007 Toyota 4Runner
2005 buick lacrosse doors lock and unlock while driving and headlights cut off while driving
I think you should go for manual first after that it would be easy for you to solve your problem. I had visited this site past 2 months before for my vehicle and find it quite helpful may be you will also get something useful here
Buick Allure LaCrosse Workshop Service Repair Manual 2005 2006 2007 2008...
Dec 02, 2017 | 2006 Buick LaCrosse
My 1999 Ford Windstar keeps lockng the doors and blinking the interior lights while driving.
You need the dealer to scan the Body control module while this is happening, i think you have a defective door ajar switch here.
Jun 12, 2012 | 2000 Ford Windstar
ABS light turns on a 1998 dodge grand caravan and the guages stop working
You definately sound as though you have an electrical short. I would have a mechanic do an electrical test.
May 16, 2012 | 2001 Dodge Grand Caravan
My automatic headlights stopped working on my 2009 Jeep Liberty. I can turn them on manually.
My 2008 jeep liberty's headlights flickered when I was just driving down the road in the dark and then completely shut off on me. My fog lights are the only lights that work now and my lights continue to blink off and on a couple times and then completely off. Now that this has happened my jeep will continue to lock and unlock itself and also my blowers for heat and cool air will not blow at all...
Feb 02, 2012 | 2009 Jeep Liberty
How do i manually release the rear door on a ssab 9-3 2003 as the door module has failed
Trunk Lock After Closing
Desc.: What happens to the trunk lock when closing it.
Settings:
Yes: Automatically lock Boot on closing
No: Boot can be reopened using micro switch button located on the trunk/boot
* Trunk Lock After Drive Off
Desc.: Should the trunk be locked at drive off or after 30 sec.?
Settings:
Yes: Trunk/Boot will automatically lock when vehicle increases speed
No: Trunk/Boot will remain closed, however will be in the unlocked
condition if No was selected in the previous option.
* Door & Trunk Unlock at Key Out
Desc.: When the is removed from the center console should door/trunk
be unlocked?
Settings:
Yes: All Doors & Trunk/Boot will Unlock when the Key is removed from
the Ignition Switch If Driver frequently locked all Doors when
driving
this feature would be beneficial.
No: Doors and Boot will remain in the same condition as they were
prior
to Key removal
* TSL Locking Logic (Theft Security Locking/Deadlock)
Settings:
TSL at first Press: Default Setting. All Doors will lock in Deadlock
Mode
TSL at Second Press: All Doors will lock in Deadlock mode at the second
press of the Remote.
* Lock /Unlock Acknowledge
Settings:
None : No acknowledge will be visible
Indicators: Indicators will blink as acknowledge
* Follow Me Home Function
Settings:
Tail Light: When selected Tail Lights will be illuminated
Back Up Light: When Selected Reverse Light will be activated
Tech 2 Body Exterior Lighting & Horn
* High Beam Follow me home Active Time
Desc.: Follow Me Home Active Time can be adjusted between 0- 10 minutes
Settings:
This Feature can be turned on or Off .Yes / No can be selected.
Low Beam Automatic / Low Beam also in Position 0 (light switch)
Yes / No
- Daytime Driving Lights can be activated
* Parking Lights
Settings:
Act as Lead Me To the Car Light.
* Park Light On Reminder
Settings:
On / Off
If Ignition is turned Off and the parking lights are active, Driver will
be warned if set to on.
* Show Trailer Light Outage
Desc.: REC will detect blown trailer light and display on SID
Settings:
Yes or No
* Trailer Light / Fog Light off
Settings:
Yes: Fog Light Rear will be disabled When Trailer is connected Yes
No
* Horn Lock Unlock Acknowledge
Settings:
On: Horn will honk when car is locked
Off: Horn will not honk if car is locked
Tech 2 Body Locking
* Panic Alarm Activation (Vehicles fitted with /Alarm only)
- Panic Button / Locking Switch
Central Locking Switch Driver /Passenger
Settings:
- Panic Button on Remote and locking switch inside vehicle will
activate alarm
- Panic Button will activate Alarm only
- Locking Switch inside vehicle (driver /passenger will activate
alarm only
- No Panic Alarm function required.
* Unlock Logic
Settings:
All at first press : All Doors will open & Fuel Lid will unlock if the
Driver or Passenger Door Switch is activated
Driver Door & Fuel Lid at first press : Only the drivers Door will unlock
& Fuel Lid will unlock when door
switch is activated
* Remote unlocking One Press
Settings:
All at first press: All Doors will open & Fuel Lid will unlock if the
Remote is pressed
Driver door & Fuel Lid at first press: Only the drivers Door will unlock &
Fuel Lid will unlock when the Remote
is pressed
Dec 17, 2010 | 2003 Saab 9-3
Flashing interior lights, battery wont keep a charge, power locks activating while driving?
You have a loose or shorted wire someplace, all that you can do is start looking for it. It could be inside a door, or the harness that feeds the door.
May 24, 2009 | 2001 Ford Windstar
Doors unlock when driving
ON THE DOME LIGHT : you will test if the light is ok by turning the dimer for the dash light all the way up until it clicks, if the light come on, then this mean the fuse the circuit and the bulb are ok. also try by opening other doors, if the light come on by opening other door that means than the switch at that specific door is not good, if nothing of this work check all the fuses and make sure they are ok, specially the lighter fuse.
and on the unlucking doors make sure to check for a previous aftermarket alarm in your car, most of the times you wil see a little red light blinking, or have some one with little knowledge to tell you if the car does have one, and have it remove, this might be unlucking the door when you don't want to
May 28, 2008 | 2001 Ford Taurus
Clarion DXZ475MP CD Player Logo
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
