Question about Marantz DV4001 DVD Player
DVD stuck inside
Our player suddenly had a disk error now the power wont turn on and the dvd is stuck inside..
    Genius:
  • 1,175 Answers
Turn over the case. There should be an access hole under the player assby. and a plastic screw mechanism with some kind of turn symbol.
Posted on Apr 11, 2009
Open the case and take it out manually.
Posted on Jul 21, 2008
Power button keeps blinking dvd player wont turn on
the disc or mechanism may be jammed and the unit knows this, someone (most shops do this) needs to open the unit and safely cycle the disc out of the unit---many times with this done the unit will suddenly work again.
If not and it is not a expensive unit you have the disc back and time to go shopping as most of these are throw away units.
Sep 03, 2012 | Televison & Video
My dvd player is stuck on one dvd and wont let me eject, change disc, or even stop the current dvd. display reads "locked" whenever i press any buttons. can only turn on and off the device.
Hi, For some reason the disk will not play. You push the eject button over and over again, but the disk slot will not open. Here's one solution...
* 1 Turn off the DVD player. Wait a few minutes, turn the DVD player back on, and
then press the "eject" button. If this does not work, turn it off and unplug
the DVD player...while you keep pushing EJECT button plug the DVD and turn it on (your hand still on the eject..) is should come out..
* 2 ..if it does not eject , unplug the DVD player again, Remove the screws off DVD on the sides and take off the DVD casing.
* 3 Look for the DVD holder inside the DVD player. This device holds the DVD in
place while the DVD player reads the disk.
* 4 Push the stuck DVD disk toward the front of the DVD player until the DVD
ejects. Remember the DVD player is not on and some force ( gentle ! ) must be applied.
* 5 While it is open,plug it on and place a DVD disc just to see if mechanism works properly..
* 6 Replace the casing and the screws. Plug the player in and turn it on. Put
another DVD in to test whether the player is finally working ..
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
Jul 09, 2011 | Televison & Video
I got a denon 2930 when i press eject all that happens is draw doesnot open and it says demo mode
At the player stop condition, press 2 buttons for DVD operations (play and skip fwd) until until "INITIALIZE" appears and disappears in the FL
Dec 04, 2009 | Denon DVD 2930 DVD Player
Can't open the DVD door. Wen I turn on the DVD Player, it starts reading a DVD that's stuck inside, and after a while e turns off alone. The door doesn't open and it seems to have some process runing that...
you'll have to remove the top and remove the disk that way. there's a top bracket on the dvd drive to remove before you can get to the disk. and unplug the unit first!!
Aug 12, 2009 | Philips DVDR3330H DVD Player/HDD Recorder
Won't power up. Disk stuck inside. Can i open that tray to rescue my rental?
take a small flat head and pry the door open if not the only other way is to unscrew cover and manually push tray open
May 13, 2009 | Panasonic DVDS97S DVD Player
E1 (rear) error. DVD tray will not open.
there might be a possibility that as soon as the tray closed the dvd shifted inside the machine. the dvd is stuck yes which means that the tray wont open because the dvd is blocking the gear turning. if so you are going to have to take it to your Dealership to open up the player and remove the disk. you can try it yourself but it's not recommended. tray gears will have to be tested to see if the tray will open once the disk is out though
Mar 29, 2009 | Philips Magnavox DVD/VCR Dual Player
Dvd player combo
uncompatable disk?if not try cleaning the lens of the player by using a cd/dvd lens cleaner...the cd thing with the two brushes stuck onto it...with some cleaning fluid
Apr 25, 2008 | JVC DR-MV1S DVD Recorder/VCR
No Disc Shinco DVD-833
Basic DVD, CDrom Troubleshooting
wrong disk ,disk error,
First Clean the lens:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
wont open, wont close, makes clicking/grinding noises etc.
http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
Jan 25, 2008 | Shinco DVD-833 DVD Player
Marantz DV4001 DVD Player Logo
314 people viewed this question
Top Marantz Televison & Video Experts
Marvin
Marvin
 Grubhead
Grubhead
Are you a Marantz Televison and Video Expert? Answer questions, earn points and help others
