Question about Honeywell Programmable Thermostat Heater
Honeywell RTH230B I've just replaced my old thermostat with a new honeywell RTH230B but it didn't work. I installed it exactly as the instructions guided. The fan is supposed to run when switching to 'ON' position but nothing run. My furnace is using gas. Please advise. Thank you so much.
  • 2 more comments
  • matkieng Feb 04, 2008
    Thank you so much for your advice. I did as you guided and finally I could make it! Both heater and A/C are working perfectly after burning 3 transformers :-) I am wondering why Honeywell did not put a simple advice like this in the User Guide Manual.
    Again, I greatly appreciate your help.
  • Anonymous Sep 05, 2008
    thermasat doesn't show digits or numbers
  • Mike_Schwin Oct 23, 2008
    I am replacing an old non-digital Honeywell dial thermostat with the Honeywell rth230b thermostat. I have Y- G- W- R- B wire coming out of the wall. On the old thermostat the blue wire was not used, it was wrapped up and tucked into the wall space. The rest of the wires when to their corresponding colors:
    Y = Y
    W = W
    G = G
    The red wire was stripped bare in two places and wrapped around both red (h & c) terminals.
    I put the red wire in the Rh and used the jumper provided to the Rc and connected the other wires to their corresponding colors. I put fully charged batteries in the unit and actually tried 2 sets. The only thing that I can get to work is the fan while in manual mode. The thermo shows the little flame and snowflake when switched in too heating and cooling modes but nothing happens. The furnace worked fine before the change.
    Any Ideas?
  • 168 Answers
Normally, you should have 5 color wires: W-White, Y-Yellow, G-Green, R-Red and C-Blue.
The Blue wire is a common from the transformer on older systems, which is probably hooked to RC terminal.
Try this: Remove the blue wire and jump the RC to RH with the red wire and you will be fine. Blue wire should not be needed with the new thermostat.
This should also be stated in the instruction manual.
Hope this helps.
Posted on Feb 03, 2008
  • Thank Oct 17, 2010
    Thank you so much. I was with out heat for for Three months. Not knowing what to do with that Blue wire. LMAO. I did not have the money to pay someone. I tell you, I feel so good in this house right now. LOL. Once again,Thank you so much. You the best.
  • Ruth West Sep 30, 2013
    Thank you! I've been trying to figure out what that blue wire is for!
The MacGyver solution above worked PERFECTLY. The blue wire is not needed in older systems and the problem can be solved by using the red jump wire. Just place the red jump wire around the red RH wire and insert the other end in the RC terminal and it will work. Great Forum!!!!
Posted on Apr 06, 2010
I have a similair problem with this controller. I have a 5 wire coming from my wall. 2 of which goes to heating which runs fine. The 3 wires (red, white, and green) should somehow go to cooling but thus far I can only turn the fan on and off. Any help??
Posted on Jul 01, 2008
2 Suggested Answers
  • 5523 Answers
SOURCE: thermostat won't keep furnace fan running
You probably have a loose or broken wire to the fan relay. Check the wires on the thermostat first. Pull up on the bottom of the thermostat to remove it from the wall plate. You should see several screw terminals and the conductor wires that should be connected to them when you look at the wall plate. Check if any of the wires are disconnected or broken. If a wire is broken, strip a portion of the unbroken section of the wire and secure it to the appropriate screw. (The fan relay terminal is G for most setups.) If none of the wires are loose or broken, then you have to check for damage to the wires between your heating system and the thermostat or at the heating system. It could be a bad wire going to the jumper on control board or damage to the board itself.
I hope this helps. If the problem is not at the thermostat, you may need to have a professional diagnose and fix the problem. However, if you post additional comments about your heating system, Fixya experts may be able to help you diagnose the problem.
(we had the broken wires at the thermostat keeping the fan from working in the past. It's an easy fix if you are willing to handle small wires carefully.)
Posted on Jul 06, 2013
New instruction manual for RTH230B
Do you mean the Honeywell RTH230B programmable thermostat? Most of the Honeywell thermostat manuals are available here: http://yourhome.honeywell.com/en/faqs/thermostat . Scroll through the pages to find the RTH230B or use the search feature. The search engine found the installation and user guide in three different languages, see https://yourhome.honeywell.com/en/supportsearch#q=Rth230b . The direct link to the manual in English is https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-1800.pdf .
I hope this helps.
Dec 07, 2017 | Heating & Cooling
I installed a Honeywell RTH230B model thermostat. The heat works fine, but the AC is blowing warm air. Wires from old system are as follows: Y=yellow; G=green; R=red; O=brown; C=blue; E=white (it looked...
the colors of old system are for heat pump.if you have a heat pump you need heat pump thurmostat and colrs will make more sense.if not,then you need to go into furnace to see what colors go where.yellow is cool, goes to compressor contactor,usually another wire going from furnace to outside unit.green is fan relay rh is heat call rc is cool call
Jan 01, 2011 | Honeywell Programmable Thermostat Heater
Batteries died on my honeywell RTH230B replaced but furnace won't
you will have to reprogram it according to the operating manual.
The manual is available on www.manualnguide.com
Feb 02, 2010 | Honeywell Programmable Thermostat Heater
New honeywell thermostat on new gas furnace not working
sometimes there's a differential setting anywhere from 1-3 degrees, see if you can make sure it's down to 1
Nov 12, 2008 | Honeywell Programmable Thermostat Heater
Honeywell rth230b thermostat doesn't work
On most Honeywell Digital T-stats there is a 5 min delay built in
Oct 23, 2008 | Honeywell Programmable Thermostat Heater
Honeywell RTH230B
This my situation exactly.  Changing from a 6 wire manual round Honeywell thermostat to a 5 wire Honeywell programable.  Is there a way to maintain all functions?
Sep 21, 2008 | Honeywell Programmable Thermostat Heater
Model RTH230B uses a lot of batteries
THIS TYPE has been deemed defective! changeout to a different type.
Sep 04, 2008 | Honeywell Programmable Thermostat Heater
Problem with Honeywell RTH230B Thermostat
Sounds like you have it wired wrong..   Pop the top off and give me to color of the wires and tell me which letter each color wire is on.. that will tell us right away if you have it wired wrong
May 27, 2008 | Honeywell Programmable Thermostat Heater
I can't program my thermstat
go to www.honeywell.com. There you will find a search tab. Type in the exact model number of your thermostat. You will be able to download the installation/owners manual.
Nov 29, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
1,864 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
