Question about Clarion DCZ625 6-Disc CD Changer
Clarion 635 disc will not egect when you push eject
I just fixed mine and the problem was one of the cartridge trays that holds cd's had come out and was sitting outside the cartridge and over the top of the assembly that "collects" the disc to play.
If you can easily remove the entire unit from it's mounting brackets, then I have a solution. It might sound tricky, but it's actually pretty easy.
Once you've removed the entire unit, place it on a table to work on. Remove the front plate (this is the part that has the hinged door on it to protect the cartridge and inside mechanisms) by carefully sliding a thin flat screw driver along the plastic edge where it connects to the metal box. There are several tabs that just have a friction fit holding it in place. Be gentle as to not break the top plate.
Once the front plate is removed, you'll find two very small black screws on each side of the metal box/case containing the cd player. (The top half of the case.) Once you've removed the four small screws, you can lift off the top of the metal case and expose the cartride and cd player. At this point, you'll probably see that 1 or 2 of the cartride trays has come out of the cartride and are sitting over the top of the cd player. Gently push the trays back inside the cartridge.
Once the trays are back inside, you can take the entire back over to the power card, plug it in and see if when you hit the eject button if the cartridge pops out. If it does, you're almost done.
Go ahead and slide the top half of the metal box/case onto the unit. Replace the 4 small black screws on the sides. Replace the front plate carefully. Remount the unit in it's original location. Plug it in and you're done.
Posted on Jun 09, 2009
Clarion caa 397 not ejecting the cartridge
Try here: Recommend contacting a local car audio professional or Clarion customer support directly here:
https://clarion.com/xe/en/user-support/inquiry/contactus
Aug 27, 2014 | Clarion Digital Audio/6-disc Car Cd...
Jaguar Clarion CD Error code E5
google jaguar clarion cd error code e5
Aug 09, 2014 | Clarion Car Audio & Video
Clarion ohm107vd in car DVD won't eject disc
It not the disc, it won't take a disc ...... if I go to put one in it Makes noise but won't actually take the disc. Would this be the loading gear and can it be fixed or?
Jan 08, 2012 | Clarion Car Audio & Video
I have a 1997 Ford Explorer purchased new with te
is there a coin holder in front of the changer? if so, there may be a coin lodged inside the changer preventing the carrier mechanism from moving. look on the bottom of the changer to see if a coin might be stuck.
Mar 11, 2010 | Clarion DC625 6-Disc CD Changer
Magazine not ejecting when press eject button on my clarion peugeot 6 cd disc changer
Sounds like a fuse, if not then the motor to eject is not working, you can fix these yourself easy to open up and identify the fault.
Hope this helps
Regards
Dan
Jan 26, 2010 | Clarion DC625 6-Disc CD Changer
Clarion 6 cd changer cassette will not eject
Don't waste your money and buy those repair manuals. There is an easy fix for this. The rootcause is most likely related to your disc tray (crooked carrier or broken spring). Just get a small screwdriver and take out the two black srews of the inner faceplate, covering the cassette tray itself. Please make sure you do not drop those tiny screws. Use a magnetic tip screw driver. Take the faceplate off. You will see a litlle lever in the center. Just push it aside and your cassette will pop out with no problem. That simple. So don't waste your money!!!
Mar 28, 2009 | Clarion DCZ625 6-Disc CD Changer
Disc won't insert properly
it couses rusty brushesh take ear bud with water wet and insert into the cd player and movr horizontaly 2or 3 times
Mar 05, 2009 | Clarion DB245 CD Player
No ejection
hi does it make any noise or clicking?
you may have a cd dislodged or mag dammaged.
Mark
Sep 05, 2008 | Clarion DC625 6-Disc CD Changer
Clarion dc 625 cartridge
yas long as all the trays are still loaded in the cart/mag then you should be able to release it with a long flat peice of stiff card. push it under the cart/mag and kinda wiggle it this should trip the catch and pop out your mag
Mark
Blue ICE
Dec 11, 2007 | Clarion DC625 6-Disc CD Changer
Clarion DCZ625 6-Disc CD Changer Logo
253 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
