Question about Xerox Phaser 7400/DXF Laser Printer
Xerox phaser 7400
Hi am anthony am living in jamaica have recently buy a phaser 7400 printer from xerox and i would like some help with a problem that am having
I am geting eror mesage saying tray # 1 feed roler is out of place, can you give me some advice please?
  • Anonymous Feb 13, 2008
    error 917
K TAL SEñORES MI POBLEMA ES K LE CAMBIEL EL TONER Y ME MARCO ERROR 942 LE BOLBI APONER EL TONER K TENIA Y SIGUIO ASIENDO LO MISMO ME PUEDEN ALLUDAR ASABER CUAL ES EL POBLEMA.
Posted on Aug 29, 2008
    President:
  • 2,072 Answers
Remove the tray, first look for a piece of paper that has come out of the tray inside the tray area.
Make sure the rolllers are snapped into place. The easiest way to verify that is to remove another tray and compare them.
Look to see if all the switches and actuators are in place.
Make sure you hear the tray up motor running when you close the tray.
Also inspect the paper tray itself for broken items. Compare it to another tray.
Posted on Feb 04, 2008
  • Rick Kasper Feb 19, 2008
    I am inquiring where I have failed in responce to your issue.
    I am just looking how to improve the responce I can give to people who have issues with priducts.
    I take a "thanks for trying" as a failure and am looking for ways to improve the resolutions I offer. If you can provide me with feedback, I can offere better answers in the future.
    Thanks.
    FAULT 917
    Testing the sensor in service diagnostics may be inconclusive when using a separate magnet.
    Cause:
    The sensor is polarity sensitive and may not be activated by some magnets.
    Solution:
    Fixed! Did not fix.
    The Belt Hole IC (belt rotation) sensor can be tested using the magnet on the Transfer Belt that actuates the sensor during normal. The following describes the process for doing this.
    Location of the Belt Hole IC sensor in the printer. Only the black plastic shroud is visible; the sensor itself cannot be seen.
    Magnet on the Transfer Unit that actuates the Belt Hole IC positioned at six o'clock for testing the sensor.
6ya staff
SOURCE:
I have a phaser 7400dx and the color alignment is off, I've heared people talk about that it is set in the main board and can be fixed. I was wondering how it is fixed?
Below is the link to 7400 documentation, the user guide on this page provides good info on color and image misregistration problems and some potential fixes ...
http://www.support.xerox.com/support/phaser-7400/documentation/enus.html
Alos, if it is a problem wioth your main PWB you may want to contact your Xerox service technician for assistance ......
I hope this helps.
Mar 09, 2015 | Xerox Phaser 7400/DX Laser Printer
Xerox phaser 7400
You can download the Xerox printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :-http://www.support.xerox.com/support/enus.html
Feb 24, 2012 | Xerox Phaser 7400/DXF Laser Printer
On power up the xerox phaser 7400 displayed.
HI there check the fuse on the xerox machine and let me know its ok or not.
Jan 24, 2011 | Xerox Phaser 7400/N Printer
What is error code 941 on a Xerox Phaser 7400?
www.support.xerox.com -phaser 7400- support -fault code-941 says cyan or magenta toner failure, but the solution says to
1. remove & reinsert the cyan or magenta imaging units.
2. replace imaging units .
check out the site to see if helpful
Jul 01, 2010 | Xerox Phaser 7400DN Laser Printer
Xerox 7400 toner superposition problems
When the colors do not align properly you need to clean the LED printheads. Full instructions on how to do this are located at:
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=110,E=0000000001181486662,K=5398,Sxi=19,Case=obj(1219)
Sep 30, 2008 | Xerox Phaser 7400/DXF Laser Printer
Xerox Phaser 7400 printing
Reinstall the latest print drivers. This issue has been resolved previously
Apr 22, 2008 | Xerox Phaser 7400/DXF Laser Printer
Xerox phaser 7400
There really isnt an easy way to do that.
The transfer belt assembly starts off with a fuse on it to blow immediatly on install, and a counter that is internal so that it will end of life and have to be replaced. It's really not a convience counter but an obsolence counter.
Mar 06, 2008 | Xerox Phaser 7750B Laser Printer
Phaser 7400
The closest I can find to your description is a U6-0 and the suggestion is to replace the transfer belt assembly,
Feb 11, 2008 | Xerox Phaser 7400/DXF Laser Printer
Xerox Phaser 7400/DXF Laser Printer Logo
1,576 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
