If you have a bicycle with a deraleur system (chain with a lot of different-sized sprockets in the rear), is is possibly because the sprockets are worn combined with a slightly stretched (worn) chain. The best solution is to replace the offending sprockets (they are always the smaller ones) and the chain. You should be on your way. (Before doing ANY of that, however, MAKE SURE that your gears are adjusted properly. A deraleur that is trying to stay between gears will cause just this same symptom.)
