Washer will not agitate, took belts off and it will only spin one way.
Is it normal without the belt on that the drum will only spin one way... I'm no expert but i was thinking it should spin both ways freely without the belt. Any feedback would be much appreciated. Thanks
  • nenarekd Feb 04, 2008
    We just went out and bought a new one... we have 4 kids one of them a baby plus i'm remodeling our upstairs so i didn't have ample time to fix this... Thank you very much for your help though!
    Scholar:
  • 90 Answers
Only one direction seems fine. On some machines there is a solinoid connected to a lever that either disengages or engages the drum brake to keep the drum from rotating during agitation. Some units reverse the motor direction when agitating and spinning. (one direction for spin the opposite for agitation. Most generally when the motor works in only one direction, say it spins fine but not agitating the culpret is the control dial. There are several combinations of electrical connections that must all make to go from one cycle to the next. On some other models there is a plastic cog that is moved by the solinoid to make the change. Without other info such as make and model, I can't really be sure how to tell you to diagnose the problem..The main thing is one direction is probably right on the turn question.
Posted on Feb 03, 2008
Washer will not spin or agitate
Can you move the agitator freely by hand?
Jun 26, 2013 | GE WJRR4170E Top Load Washer
My ge wpsf4170 top load washer agitator spins but the drum itself stays stationary.
If the drum spins but the agitator doesn't agitate then its the dog(lil arm things) that grab the agitator ridges to work. If the drum doesn't spin at all its the belt under the drum. it's either broke the belt or has worn and slipped off or the drum was way off balance and kicked it off(belt) . way cheaper to fix either than buy new and most new ones have no agitator anymore so how does it clean better? In my opinion, they don't so I get the parts online at repair clinic and do it my self. Sorry Maytag Repair man. But I saved a lot
Sep 05, 2017 | GE Washing Machines
Washer will not agitate spin or drain only makes a squealing noise but will agitate if we hit the drum
Without having the actual washer make the sound so I can hear it, my guess is that the timer (which is the part connected to the dial you turn to select a cycle) may need to be replaced. Squeals can also come from the belt that connects from the motor to the drum. If you are at all handy and can open the back, a broken belt is obvious. If you are not familiar with tools then someone will most likely have to be called to diagnose the problem.
Jan 27, 2011 | Washing Machines
Noise when agitateing wash only
Remove the belt, and spin drum by hand from inside, there should be little or no noise, if there is then it is possible the drum bearings are failing.
I f no noise, but there is when you put belt back on, then possibly bearing in motor noisy
Mar 06, 2010 | Hotpoint WMA66 Front Load Washer
The washing machine belt will move to agitate, but will not move to spin. The spin action burns up the belt. This is an Amana LWA50AW
open rear cover , see if belt slips. then remove belt and rotate empty drum if its jam than drum bearings need to change. if drum is free then belt might be loose and needs replacement.
Nov 05, 2009 | Zanussi FJS1225W Front Load Washer
Replaced broken washer belt, but drum still won't spin.
you may have a bad bearing in a pulley,could be motor coupling. Take belt off and spin motor shaft and pulley both ways if it's free, then its more than likely not the motor. Now spin the drum with belt off and see if it does the same as with the belt on if it does it has to be a bad bearing or coupling to the drum. hope this helps
Aug 24, 2009 | Amana ALW480DA Top Load Washer
Won'i\t spin or agitate. was working fine-went
Hi..
if agitator movement is weak or moves in only one direction check the following:
  • Inspect the agitator
  • Inspect the motor coupler
  • Inspect the drive belt(belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • Inspect the pump coupling
If drum does not spin check this:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the drive belt (belt drive only)
  • Test the motor
Good luck !!!
Regards
PCmania
Jul 11, 2009 | KitchenAid Washing Machines
My washer wont agitate or spin
If this machine is a drum type and NOT A TOP LOADER (There was no mention of the model) then the overload has possibly caused the drive belt to either break or jump off the drum pulley.
IMPORTANT: THERE ARE LIVE SWITCHES AND MAINS SUPPLIES WHEN THE COVER OF THESE MACHINES ARE REMOVED, DO NOT TOUCH OR TAMPER WITH ANY PART, UNLESS THE POWER IS OFF AND THE PLUG REMOVED FROM MAINS SOCKET.
If the belt has slipped off or has broken, it can be replaced by fitting the (new) belt around the motor drive pulley (small end) and refitting around the drum pulley, you can do this by feeding the belt around the drum pulley, by holding the belt in place and feeding onto the pulley (IT IS EASY TO GET YOUR FINGERS NIPPED BETWEEN THE BELT AND LARGE DRUM PULLEY WHEN ATTEMPTING TO FIT BELTS BACK - SO BE VERY CAREFUL)
Best of Luck!!
Jul 04, 2009 | Whirlpool LSR5132PQ Top Load Washer
The drum does not spin. the agitator works normally, then when time to empty the pump works, but an odor of the belt slipping is noticed and the drum will not spin. When lifted up to inspect the belts,...
seems to be a transmisson problem, the pump is driven by the motor also. so the motor should be ok. and the agitator works ok. believe it would be a transmission gear failure.
Jun 08, 2009 | Maytag Performa LAT2500A
Washing Machines Logo
115 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
