Question about Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE FRAME
Setting clock How can I set the clock on my new 056-03-0209?
First select calender press enter. to set date press stop then use < arrows > to set year, up and down to set month, press stop to comfirm. Then use navigation buttons to select cuarrent date and press enter to confirm. To exit press menu button.
Use nav buttons to select clock, press enter to confirm the clock display will appear.
To set clock press menu for custom set up. Use down arrow key to find "set time" right arrow to kighlight set time press enter, then arrow keys to set time then enter then left arrow all the way to the left then down to exit, athen enter.
Hope this helps.
chuck32
First hit setup then find settings, then enter. Use arrow keys to change time, then enter
Posted on Feb 06, 2008
How do I set the alarm on my Sharp Accu-Set Model SPC452?
  • 1 Insert batteries into your atomic clock. Without these the clock won't work. The number of batteries required depends on the clock. There is usually a panel on the back of the clock where you can insert the batteries.
  • 2 Set the clock. Usually, this is done automatically, as the clock will seek out and receive the signal within 6 to 8 minutes. If this doesn't happen, you'll need to do it yourself. Hold down the "Set" button. A figure on the clock will start blinking. Adjust this by pressing the adjustment button. Press "Set" again to go to a new time. Continue until the clock is properly set. No matter what you put time you put in manually, the clock should adjust to the atomic setting within 48 hours.
  • 3 Set the time zone on your atomic clock. How to do this depends on your specific clock. On some, there is a time zone slider; you simply slide it to your time zone. Otherwise, you will need to enter the manual mode you used to set the clock. Switch the mode until the time zone starts blinking. Now, adjust until your current time zone is selected. If it goes by Greenwich Mean Time (GMT), the time zones in the United States are -5 for Eastern time, -6 for Central, -7 for Mountain, and -8 for Pacific.
  • Read more : http://www.ehow.com/how_6403731_instructions-time-zone-atomic-clock.html
    Jan 29, 2015 | Audio Players & Recorders
    How do i set my clock on my dashboard?
    Instructions Setting the Clock
      • 1 Turn the car on then hold the "Clock" button until the ":" begins blinking -- usually four to six seconds though some take up to a minute.
      • 2 Use the "1" and "10" buttons to set the minutes, "100" and "1000" buttons to set the hour
      • 3 Press the "Set/Reset" button to set the new time.
    Jun 25, 2014 | 1995 BMW 525i Sport
    How do set the time and date on machine
    Press and hold CLOCK until the message window displays C, and the default day is announced.
    To change the day setting, press MEMO/REPEAT or ANNC/SKIP until the correct day is announced.
    Press CLOCK. The current hour setting is announced. The correct day setting is saved.
    To change the hour setting, press MEMO/REPEAT or ANNC/SKIP until the correct hour is announced.
    Press CLOCK. The current minute setting is announced. The correct hour setting is saved.
    To change the minute setting, press MEMO/REPEAT or ANNC/SKIP until the correct minute is announced.
    Press CLOCK. The current year setting is announced. The correct minute setting is saved.
    To change the year setting, press MEMO/REPEAT or ANNC/SKIP until the correct year is announced.
    Press CLOCK. The new day, time and year are saved. The correct year setting is saved.
    To check the clock, press CLOCK.
    The above is from page 5 of the manual at
    http://att.vtp-media.com/ecp/documents/product_Product/223/UserManual/944/1739_manual.pt2_i6.pdf
    Jun 21, 2011 | AT&T ATT1739 Digital Answering Machine
    Need to set clock on oven
    Instructions
      • 1
        Check the oven to ensure that it is off and that the timer isn't running. The buttons used to set the clock are the same buttons that adjust the oven, and you may end up making unintended adjustments to the oven.
      • 2
        Press the "Clock" button to enter the clock setting mode. The LCD will show the current time set on the oven.
      • 3
        Use the "Set Temp/Time +" or "Set Temp/Time -" buttons to adjust the clock to the current time. Depending on your model of stove you may need to use the "Hour," "Min" or the "Temp/Hour" up and down arrow buttons to set the time.
      • 4
        Save the new clock setting by pressing the "Start" button. Depending on your stove model, you may need to press the "Clock" button a second time if the "Start" button does not work.
    Read more: How to Set the Clock on a Whirl Pool Stove ' eHow.com http://www.ehow.com/how_5692616_set-clock-whirl-pool-stove.html#ixzz1H3Wfexf6
    Mar 19, 2011 | Ovens
    How do I get my smart alarm clock to reset itself automatically since the goverment changed the daylight savings time? Or, if I buy a new one will it have the new time changes?
    The Daylight Saving Time settings are not user controlled, so you cannot convert the changeovers to the new schedule - you can only change the time manually. Any new clock or clock radio with automatic settings will work on the new schedule.
    Bill B
    Apr 04, 2010 | Emerson Smartset Clock Radio
    7:15 p.m., 10/6/09-I don't know how to set up the time & date on the machine. I need clear, step-by-step instructions. Help! AT&T digital answering machine model 1738. THANK YOU!! Barbara S.
    To set the clock. You must set the clock once so that the system announces the correct day and time with your messages. After this, if you subscribe to Caller ID, the system will automatically reset the clock each time new call information is received.
    Press PLAY/STOP to exit at any time while
    setting the clock.
    1 Press and hold CLOCK until the Message Window displays C, and the default day is announced.
    2 To change the day setting, press and release MEMO/REPEAT or ANNC/SKIP until the correct day is announced.
    3 Press and release CLOCK. The current hour setting is announced.
    4 To change the hour setting, press and release MEMO/REPEAT or ANNC/SKIP until the correct hour is announced.
    5 Press and release CLOCK. The current minutes setting is announced.
    6 To change the minutes setting, press and release MEMO/REPEAT or ANNC/SKIP until the correct minutes setting is announced.
    7 Press and release CLOCK. The current year is announced.
    8 To change the year setting, press and release MEMO/REPEAT or ANNC/SKIP until the correct year is announced.
    9 Press and release CLOCK. The new day, time, and year are announced.
    To check the clock, press and release CLOCK.
    If you need futher instructions for your answering machine you can download a copy from:
    http://phone.manualsonline.com/manuals/mfg/att/1738.html
    Please rate this solution. Thanks..
    Oct 07, 2009 | AT&T Lands Phones
    How to set time with new control board?
    You may set the clock on your Microwave per page 6 of the User Guide by following the steps below. We've included the link for the User Guide below.https://www.whirlpool.com/content/dam/global/documents/200105/owners-manual-8300610.pdf
    This is a 12 hour clock and does not show a.m. or p.m. To Set: Before setting, make sure the oven, Timer and Timed Cooking are off. 1. Press CLOCK. 2. Press the HR or MIN "up" or "down" arrow pads to set the time of day. 3. Press CLOCK or START/ENTER. To Disable: The clock time can be disabled so that it does not show on the display. To disable, press and hold CLOCK for 5 seconds. To display the clock time again, press and hold CLOCK for 5 seconds and the time of day will show on the display. The clock time should not have to be reset.
    Nov 03, 2017 | Whirlpool GMC305PD Electric Single Oven
    I NEED THE INSTRUCTIONS ON HOW TO SET THE CLOCK ON MY MICROWAVE
    To set the time just press CLOCK, then press CANCEL, then enter new time setting and press CLOCK again.
    Apr 07, 2009 | Microwave Ovens
    Model 1739 answering machine
    Set the clock
    You must set the clock so that the system announces the correct day and time with any incoming messages. After this, if you subscribe to the caller ID service, the system will update the clock eac h time new call information is received. Press PLAY/STOP to exit at anytime while setting the clock.
    1. Press and hold CLOCK until the message window displays C and the default day is announced.
    2. To change the day setting, press
    3. Press CLOCK. The current hour setting is announced. The correct day setting is saved.
    4. To change the hour setting, press
    5. Press CLOCK. The current minute setting is announced. The correct hour setting is saved.
    6. To change the minute setting, press
    MEMO/REPEAT or ANNC/SKIP until the correct minute setting is announced.
    7. Press CLOCK. The cu rrent year is announced. The correct minute setting is saved.
    8. To change the year setting, press
    MEMO/REPEAT or ANNC/SKIP until the corr ect year is announced.
    9. Press and release CLOCK. The new day, time and year are announced. The correct year setting is saved.
    Jan 08, 2009 | AT&T 1717 Digital Answering Machine
    RCA,RP9328A,Audio System
    I did the following to set the clock:
    1. Press the Timer/Clock button until "CLOCK" shows, blinking, on the display.
    2. Press Set/Demo. The hour indicator on the clock should start blinking.
    3. Use the "Track/Tuner Forward" and "Track/Tune Backward" keys to
    set the hour.
    4. Press Set/Demo. The minute indicator on the clock should start blinking.
    5. Use the "Track/Tuner Forward" and "Track/Tune Backward" keys to
    set the minute.
    6. Press Set/Demo twice. (Pressing once moves to the timer set mode.)
    Feb 09, 2008 | Audio Players & Recorders
    Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE FRAME Logo
    265 people viewed this question
    Top Tao Photography Experts
    Phillip Hicks
    Phillip Hicks
    Vuk B
    Tony Parsons
    Tony Parsons
    Are you a Tao Photography Expert? Answer questions, earn points and help others
