Question about Coffee Makers & Espresso Machines
Capresso c1500 grinder loud knocking, crunching, noise
We've followed the factory manual directions for emptying the hopper, including vacuuming it out, w/o resolution of the knocking, crunching noise when the grinder is engaged. The noise varies with the position of the coarseness dial and is least noticeable at the coarsest setting. Is there something we can do before we spend the time and large amount of money to send it back to capresso to be serviced. Thank you for your time!!
  • rizosa Feb 03, 2008
    Has anyone had any experience in disassembling the C1500 burr grinder housing to give step by step instructions? Thanks
    Genius:
  • 3,422 Answers
Here are the step by step instructions with the diagams and it will tell u how to fix it.This will solve ur problem just click the link below.
Click here
You need to have adobe acrobat reader to view the manual in pdf format.
Click here to download if u don't have..
Goodluck,
Please don't forget to rate me as fixya..
Posted on Feb 03, 2008
    Genius:
  • 1,067 Answers
Would u hav eto get inside cheak all the gears stats see if ones are off or bean stuck in back sumware if u dont know what your doing it is a tuff and tetest job but cabn be done u would need a servcie guide also wich im not sure if they would offer us one
  • 2 more comments
  • nick helpap
    nick helpap Feb 03, 2008
    ya u might need orginal remote they sell it onl;ine so u can adjust it using arrow keys ok
  • nick helpap
    Go with the Flow: Cleaning Your Capresso/Jura to Keep a Good Coffee Flow
    Have you ever had the coffee flow on your Capresso or Jura super automatic machine slow down to a dribble? How about having the display telling you to open the “Tap”(steam knob)? If you have, then you understand the stress and panic that can set in when the morning cappuccino is at risk. The sun may be shining with birds singing, but if the espresso machine goes down, its all for naught. The normal first reaction is to go right for the instruction manual, pull out a cleaning tablet, and run the machine through a cleaning cycle. Before you go through this trouble, try cleaning it by hand. This is a simple and quick process that cleans off the shower screen that gets pressed up against the coffee. Every once in a while, coffee can get stuck on this screen and inhibits the proper water flow through the coffee. This slow flow reduces the amount of water that goes through the boiler and causes it to heat up to a higher temperature than it would if the water was flowing through at the normal speed. The machine senses this higher temperature and prompts you to go through the same process that you would when cooling the boiler down from steam temperature to brew temperature. This slow flow combined with the old coffee on the shower screen can also make the espresso bitter.
    There are many machines that we are addressing here, and they fall into two different styles. The instructions for cleaning them are the same, but locating the parts you have to clean are a little bit different.
    Directions:
    1. Turn off the main power switch and let it run through any shut down cycle that it may go through.
    2. Unplug the machine.
    3. Pull out the drip tray and dump box.
    4. Look inside the machine and you will see a plastic flap hanging down. If you pull on this flap, you will see that it is spring loaded.
    4a. If your machine is Style A then the flap will be positioned in front of you. You will want to cup your hand and place it straight into the machine to locate the shower screen.
    4b. If your machine is Style B then the flap will be positioned to the side. You will want to cup your hand and place it sideways into the machine to locate the shower screen.
    5. Put your fingers at the bottom edge of this flap.
    6. Without pulling on the flap, move your fingers straight up behind the flap until your fingers bump into a round disc pointing down. This disc is the shower screen and will probably be covered with wet coffee.
    7. Take a wet paper towel, one that won’t leave lint or pieces behind, and clean this disc and its surrounding area. Wipe the disc as many times as necessary to clean it.
    8. Put the drip tray and dump box back in. Plug it in and turn it on.
    9. Push the rinse button (you may want to rinse it twice).
    10. You should now be ready to start brewing again.
    11. If this does not solve the problem, run a cleaning cycle according to the machines instructions.
    12. If none of this works, please call the manufacturer.
    Jura: 877.587.2872 Capresso: 800.767.3554
    If you have any questions regarding this procedure, please don’t hesitate to give us a call.
  • nick helpap
    please rate me as fix ya now ok thx nick
  • nick helpap
    sum of beans are slipery and will get stick in it
Grinder make a weird sound
Describe the weird sound. If it is very loud clacking like a machine gun type noise then vacuum our the hopper over the grinder and inspect for a stone jammed in there. The stones always look brown like a coffee bean, it is very common.
May 30, 2015 | DeLonghi Esclusivo Magnifica ESAM3300...
I can't brew coffee, when machine is turned on it makes a loud noise like endless spinning. sounds like it is coming from the brew/tamping area
foreign element perhaps the grinder is bad though. First try using a small vacuum that will allow adequate control of vacumming up the bean container. remove all the beans etc. the bean container must be emptied. then look at what the vacuum removed, any foreign objects? if you see 1 or more it's likely fixed. otherwise remove any inside cover/guides in the bean container you should now look directly at the grinder wheels with flashlight, as there may instead be a foreign substance or a defect preventing the grinder from processing the beans. if a defect then it may require factory service. gl
May 28, 2015 | Jura Capresso Impressa Z5 Espresso/Coffee...
My Rancilio Rocky Burr coffee grinder w/doser is not grinding the beans they simply remain in the hopper
It is most likely that something is blocking the pathway to the grinder. As the Rocky is a direct drive grinder there is no gear that could be broken.
Try to remove the beans from the hopper and inspect the pathway, move the beans that might be under the 'disk'. If that is not working you might have to open the grinder;
  • remove all coffee beans
  • unscrew the three screws in the bottom of the hopper
  • remove the hopper
Now you can see the grinder wheel and tell if it is turning normally.
This might be a good opportunity to give the grinder a thorough cleaning.
Do not soak it in water, just a stiff small brush (e.g. a toothbrush) is the best tool. And perhaps accompanied by a vacuum cleaner :)
If you have been using very 'oily' beans for a long time they might have clogged the grinding wheels.
Good luck,
Villi
Mar 02, 2015 | Rancilio Coffee Makers & Espresso Machines
Machine says beans are empty and will not brew.
Try adjusting the grinder coarser when it is running. Either the grind is too fine or the grinds chamber is blocked, remove the brew unit and check the gate to the grinder on the inside right.
Jul 30, 2010 | Saeco Magic De Luxe Espresso Machine
Coffee beans empty but not
Could Be one of 2 things, the grind is set too fine and the beans are not getting to the millstones, or there is something blocking the chute for the grounds.
Dec 31, 2009 | Gaggia Titanium Espresso Machine
My Jura Ena 5 gives a 'fill beans' message even though the hopper is full and it won't grind the beans even though it seems to be operating. Help.
Same thing happening to me right now. I think this has something to do with having used flavored beans (which I was warned not to do). Supposedly they gum up the machine.
Nov 27, 2009 | Jura Capresso Impressa S9 Coffee...
Fill beans message keeps coming up on jura capresso impressa s9
You need to open the grinder, it`s probably packed with old fine powdered coffee that blocks the outlet. Clean this out and try again. Since it works normal when you use pre-ground coffee, there shouldn`t be any problems with any other parts.
Let me know if you want a description for have to open and clean the grinder.
Jun 01, 2009 | Jura Capresso Impressa S9 Coffee...
I need a new manual for my Capresso 452 coffeegrinder/maker
Fantastic deal! I'm jealous. I'm on my second one and I paid about $200 each time! Here's the manual
http://www.capresso.com/pdf/inst_coffeeteam_s.pdf
Aug 17, 2008 | Jura Capresso 452.01 Coffee Maker
Bean hopper is full, grinder is grinding...but NO COFFEE!
Sometimes the chamber between the grinder and brewer will clog up. Try: Open the grind all the way up to the highest number. Push the grind button and while grinding move the dose knob (the one with the + - sign toward minus. If it does not kick in and dose try it again. If it does take off then leave it on the high number for 3 coffees. Then while the grinder is turning move the two knobs back to whre they were. If this does not work you can reomve the brew unit and right above where it sits in the machine there is a trap door that you can open. Open it and shove someting like a straw up toward the grinder and you should get a bunch of grounds droppiing down. Then try the above procedure a couple more times. If this does not work you may need to google "Saeco repair" and send it to an authorized repair center.
Aug 15, 2007 | Saeco Vienna Digital Coffee Maker,...
Coffee Makers & Espresso Machines Logo
193 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
